badmojo wrote:Hi Weeds! I was playing around with QM yesterday and decided to try out your stuff - should the zip contain icon files too? It only seems to contain the .DEF file? Apologies if I've missed something simple, like the icons are IN the .DEF file
Yeah, all of the icons are contained in the single "QM_COLOR.DEF" icon library file. You'll need to unzip that file to your main/base QM3 directory on your hard drive.
NOTE though, this will wipe out ANY custom icons that you may already have in your EXISTING icon library file (so you might want to back it up first!). But, that being said, if all you ALREADY have are the stock icons, as well as the official icon pack mentioned previously, you should be good to go... as all of MY custom icons are near the bottom of that file
(Edit) P.S. Sort of on-topic, a trivia question: Does anyone know what the screenshot was from; that I used as a QM3 wallpaper in my previously uploaded QM3 screenies <grin>?
Bear in mind... the original game's screenshot had to be downsampled to 16 colors, and then palette matched to the QM3 default 16-color palette... THAT is why it looks quite crappy
(HINT: Think "3D Realms"
