First post, by foey
Hello,
I have a number of games still on CD/DVD which I've got the urge to play. So I thought I would put together a XP Rig. Back in 2004 I used to have a Abit NF2 with a Athlon XP 2800 and a ATi 9800 Pro. So this time I thought I would go over to the other side 😀 P4/Nvidia for this era. Not "retro" enough for some of you guys, sure - but I enjoyed it and thought I'd share 😀
My main aim to play the following...
Halo
Unreal Tournament 2003, 2004
Grand Prix 4
Quake 3 / Quake 3 Team Arena
Doom 3
So I managed to get hold of a old DELL Dimension 4600i from a client of mine which was in a bad state. It had been sitting in the floor in an office for years power on 24/7. I decommissioned it last year sometime.
Pentium 4 Prescott 3.0Ghz
1Gb of DDR333 Ram (Mix and match)
O/B Sound
O/B Intel Graphics
DVD-ROM
160Gb WD IDE Hard Drive
The CPU being a prescott, which roughly puts it in the same area as the Althon XP 3200. It also has Hyper Threading which was disabled in the bios, I've re-enabled it but will carry out some benches with it disabled.
Here she is, full of dust. My hands were filthy once I finished cleaning this out with an air line.
So onto the upgrades...
Creative Sound Blaster Audigy
Onto the graphics card, I wanted something top end, around the time of the 9800 Pro/XT, So it had to be the Nvidia FX 5950 Ultra. I managed to pick up a Asus branded one on ebay
Since I'm going to be running a few upgrades, I thought I would upgrade the PSU. Antec Earth Watts 380w which has done next to no work.
I then decided to take off the heatsink, clean the CPU and apply some Artic Silver 5 thermal paste. It was in need of it
I added a DVD-RW Drive, here she is all scrubbed up
The Cards, note the PCI Network card in the middle. The O/B Nic fails to work.
I updated the Bios from DELL to revision A12 and ran Mem test to ensure the memory was stable.
So there it is, all built!
Final Specifications
Intel Pentium 4 (Prescott, 800FSB) 3.0Ghz
1Gb DDR400 Ram (Running Dual Channel @ 400mhz, 1:1)
256mb ASUS Geforce FX 5950 Ultra AGP 8x Graphics Card
Creative Audigy SB0090 Sound Card
WD 160Gb Hard Drive
Antec 380w Earth Watts PSU
10/100 NIC PCI Card
DVD-ROM / DVD-RW Drives
Running Windows XP SP2
Benchmarks
3DMark 2001 - 14995
3DMark 2003 - 6411
Final Thoughts
This machine is quick! It flys through games as you would expect. Windows XP runs snappy.
The Graphic card fans are noisy, they spin up to full speed but you can hear their bearings are on the way out - which is common with these types of fans. I've been looking at the Artic Cooler NV4 which fits the 5800/5950 Ultra.
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 1 of 19, by foey
Update on the graphics card.
I was monitoring temps on FurMark, just checking everything was OK. The card was idling at 52-54c, I clicked on the burn in test and the temps soared up to 80, 85, 90, 95... at which point I pulled the power and had a further look...
This is what I was greeted with...
Most of the paste on the memory chips was dried out paste. I cleaned the GPU and each memory chip with some Akasa TIM Cleaner. I then reapplied Artic Silver 5 to the GPU and all memory chips.
I connected it all back up now idles at 41c and tops out at 68-70c max 😀
Reply 2 of 19, by archsan
It actually makes a great Win98 rig 😀
You'll be able to max out pre-2002 Win9x games with it -- FX series actually has great compatibility with older DX5,6,7 and OpenGL games, as has probably been mentioned a million times on this forum, so good choice on that 5950 Ultra.
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 3 of 19, by rfnagel
Funny you should mention your 4600i for a 'retro gaming' rig... hehe, my *MAIN* rig is (mostly) a Dell Dimension 4600 🤣! 😀
The "mostly" part: Added RAM for a total of 2GB, added an ATI 9600 Pro AGP video card, and a Sound Blaster Live Value Edition. Still has the same Seagate Barracuda 80GB hard drive, original 3-1/2" floppy drive, albeit a replacement CD-ROM drive 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 4 of 19, by NJRoadfan
One word of note on these systems. Make sure you set the "Hard Drive Acoustic Mode" in the BIOS to "Performance", otherwise it slows down disk I/O by quite a bit.
Oh, and congratulations on owning PC World's #10 worst PC of all time
http://www.pcworld.com/article/129857/article.html?page=2
I remember back in 2004 when the power supplies on these started dropping like flies. We had 4 of them on the bench in one week at the computer shop I worked at. The power supplies were the usual failure, but some took out the motherboard too.
Reply 5 of 19, by obobskivich
Very neat rig; I always liked the look of that style Asus cooler (shame to hear it's noisy). Temperatures don't look bad at all with AS5! On the NV4, I'd double-check on the compatibility - the 5800 and 5950 don't have the same board layout and afaik their OEM heatsinks aren't interchangable as a result. I know the Zalman VF700 did a very good job with my 6800GT (and that it's a pretty universal heatsink), so I'd assume it should work with 5950 too, as long as you have ramsinks in addition to it.
Reply 6 of 19, by zstandig
Neat, I have that same exact model (mostly). Except I went all out and upgraded it to the best I could get. 4GB of DDR3200, a Velociraptor HDD, Soundblaster XFi, P4 Extreme, and an HD4670. Replaced the PSU too. I wanted to put on a different CPU cooler, but never could figure out how.
I used that as my main machine until I gave into the XP doomsday and switched to a laptop with win7 about half a year ago.
Reply 7 of 19, by chinny22
Always nice to see old unloved office workhorses getting a new lease of life, well done.
As mentioned It makes a nice Duel boot 98/XP machine (You'll have to disable HT for 9x) for those days you want to go even older or drop back to pure dos which you can do with an Audigy.
Reply 8 of 19, by rfnagel
I'm wondering if something was changed in the latter versions of this model. Mine was manufactured in 2005, and still has the original power supply... no problems at all.
Albeit, last year I worked on one for a customer of mine. Although the power supply in her 4600 had quit, it was due to a lightning strike near her house (a common problem out here in this neck of the woods).
Rich ¥Weeds¥ Nagel
Reply 9 of 19, by foey
I've ordered the NV4, which says it fits the 5800/5950. Trying to find if people had successfully got it to fit on the Asus version was hard, I managed to find a guy who fitted it to his 5800 reference which looked pretty much the same. I thought I'd take a chance. My only worry if there is enough clearance on the rear power molex.
NJRoadfan wrote:
One word of note on these systems. Make sure you set the "Hard Drive Acoustic Mode" in the BIOS to "Performance", otherwise it s […]
Mine must of been a later one, as it was still on the original PSU, just caked in dust 😀 I replaced it just in case, considering I was putting in a power hungry Geforce FX 😀
What model processor did you upgrade to? Yeah, the cooler is a Custom DELL Job, I looked and you can remove it which leaves 4 mounting holes, but unsure if you can mount the standard P4 bracket to it.
Reply 10 of 19, by retrofanatic
I used to have one of these and i have heard of the psu in them failing readily but it doesn't really take much to replace the psu though.
that sounds like a killer early xp system....p4 extreme editions are hard to come by.
I'm surprised you wanted to replace the cpu cooler...When i had this type of Dell back in the day I found that the cpu ran on the cooler side for a p4...I had a 3.2ghz chip at that time....I find these cpu cooling designs are efficient since it directs heat directly out of the case...and the heat sink and fan were relatively large for the time for an oem system.
I did end up getting rid of this dell because I did not like the case design at all..but that's a personal preference of course...at least by this time dell got smarter and used typical atx psu and other connectors (finally) so one could just upgrade using aftermarket parts.
Reply 11 of 19, by obobskivich
[quote="foey"]
Reference 5800 has a different board layout, see:
http://www.ixbt.com/video2/images/gffx-2/asus … -scan-front.jpg
(note the positions of RAM chips and caps)
Arctic's website shows "NV Silencer 4 Rev 2" as supporting 5900-5950; not 5800. I'm wondering if the "Rev 1" isn't the model for the 5800 series; I would guess they're not universally compatible as a result. 😊
Reply 12 of 19, by foey
I received my NV4 Rev2 today, it fits perfectly...
Looks pretty epic!
Help!, the fan refuses to spin. The only thing I can put it down to was the old heatsink fan was powering two fans. So question is can I cut the plug and connect it into a full size molex @ 12v?
Edit Its the fan, refuses to work. I connected it up to a 12v fan connector and refuses to work. Tested the same connector on another 6600GT with a Artic Cooler (NV6) and works perfectly.
Further Edit Seller is sending me another unit tomorrow. I don't have to send the old one back, I sense some ghetto modding 😀
Reply 13 of 19, by foey
Seller sent me out another NV4. Tested the fan quickly and its working. I pulled the other apart but could not find any issues. Appears to be dud.
Artic Cooler doing a fantastic job of keeping the 5950 Ultra cooler, I've not seen any temps above 64c after a long session with the case on. The DELL case does not provide much cooling with the only extract being the CPU & PSU fans. Without case side on, the graphics card never gets above 55c.
I just need some more RAM and its complete.
Reply 14 of 19, by vetz
You are aware that the fan only starts to spin if the card is hot enough?
That is the behavior I'm seeing on my NV Silencer 4 rev2.
Reply 15 of 19, by foey
The Geforce 5950 Ultra I have, when powered on - there is a second delay then the fan spins. With the first NV4 rev2 I had the fan never come on, I even left it running on the desktop and the temps were increasing.
I also tested the fan directly plugged into 12v 3pin > molex adapter, nothing - you can just hear a click. When I got the replacement NV4 rev I tested on the adapter and the fans spins, likewise fitted onto the cards plug. I'm guessing its the card that yours is connected to which controls that as the NV4 rev2 does not have a RPM sensor.
Reply 16 of 19, by obobskivich
Good to hear you got a working fan - always nice when sellers take care of things. It does look very nice installed on that card, and I'm glad it fits! Can you unplug the molex connector without removing the heatsink?
Temperature performance looks to be improved as well - about on par with the original Flow FX, but probably somewhat quieter.
Reply 17 of 19, by zstandig
The CPU is a 3.2 P4 Extreme (socked 478), I was a bit wary because of the Pentium 4's reputation for being a space heater. But... the urge to try to upgrade it...I couldn't ignore it. So naturally I did it anyway, any potential negative consequences be damned. I was going to attempt to put in a new heat sink and fan, but I got one of those feelings that "If you remove this part you'll never get it back the way it was" You know that ominous feeling that leaves you staring at the mess for a while before giving up on something risky.
So, yeah apparently 3.2Ghz wasn't all that much hotter than 2.8Ghz, so it worked out okay.
Oh, yeah, the cooler is fine and all, nice copper base, really heavy too. Problem was, I was worried about the "shroud" covering, One of the hinges it was attached to, got a crack in the plastic (it was a little flimsy). I feared it wouldn't be stable, naturally the shroud thing was custom by Dell, couldn't replace it. So the next step would have been to replace the heatsink. So to clarify the heatsink was hunky dory, it was the green shroud thing. Eventually I realized couldn't find a guaranteed replacement, due to worry that the design was Dell custom.
Amen on the standard ATX PSU, If I hadn't been able to get one, I wouldn't have had the power to run the HD4670.
The extreme was a nice surprise, I managed to find it for about 60 dollars or so. I'm glad I was able to find it. The L3 cache probably helps out quite a bit.
Reply 18 of 19, by foey
I don't think I have enough room to remove the molex, the fan casing practically sits on top of it.
Dammit, you got me looking for extremes now! 🤣
Reply 19 of 19, by zstandig
I knew it worked when the Pentium 4 logo in the BIOS changed to an extreme edition logo. I made sure to get the latest BIOS updates before I did the install just in case.
