Reply 10380 of 27687, by bjwil1991
Who uses that stuff for thermal compound and leave it on there for years? I change my thermal compound at least every 2-3 years (I have a big tube of Arctic 5 Silver Compound that does wonders). Glad you got that 486 to work, man.
Reply 10381 of 27687, by dionb
What thermal compound? That's just simple glue by the look of it - glue that adhered better to the lettering than the lettering did to the ceramic CPU.
Reply 10382 of 27687, by LHN91
Been fighting with an HP DC7100 Compact Minitower the last few days.
It was being used as a very basic Windows 7 machine by my wife's aunt until about 2 weeks ago, and it was working fine in that configuration.
Base Specs:
Intel 915 chipset
Pentium 4 540
Geforce 6800
By rights, it should be possible to run either 98SE/ME or 2000/XP on this machine. I brought the machine down to 512 MB of RAM for this purpose
Apparently I'm just not having any luck.
I suspect that part of the issue is that I haven't figured out how to disable the onboard video.
In Windows ME, the chipset drivers install fine. The GPU will only install if I force it to do so, at which point it does mostly work. I attempted to use an SB Live! SB0220 with the drivers on VOGONSDRIVERS, but couldn't get that working, and some other things would only install if I manually forced a driver install.
In Windows 2000, the chipset drivers also install fine. The GPU, again, only installs if forced - and even then, while showing as instaled, Windows 2000 seems to treat it as if it's not there, despite it being the card used to display the desktop.
Reply 10383 of 27687, by leileilol
Alpha channel bilinear study fun. Check out those taps! (the numbers are a 6-bit color range. this is a rgba4444, rgb is all white, the top portion is being modulated away)
    508.3 KiB
long live PCem
Reply 10384 of 27687, by ultra_code
Merovign wrote:
It probably doesn't help but those look *exactly* like the standoffs in Power Computing mac clone towers from the mid 90s. […]
the_ultra_code wrote:
Edit: I forgot to ask. What would you call these type of motherboard standoffs that "clip" into a PC case? I have to replace at least one of them if I intend to "keep" the system.
I could use one myself, one was broken in one of my machines.
If I find one I'll post the info here (and I'll keep a look out in case one of you finds one).
Awesome! Thanks!
On to what I have done today/yesterday. I received in the mail a PNY Nvidia GeForce 6800 GT with an aftermarket Arctic Cooling blower-style cooler on it.
While the card works correctly, and works as it should under XP (haven't tested it yet under Win98, but I expect the same positive result), it runs hot, with it idling at around 50C on the XP desktop, at hits at its worst nearly 70C when playing some Hot Wheels: Stunt Track Challenge (the most demanding game I have installed under XP; it's a good game, even though it's clear it's a child's game; please don't judge 😀 ). Mind you, this is with me taking apart the card and cooler completely to clean it and apply new layers of Arctic MX-4 and thermal pads where needed. Installing MSI Afterburner (which for some reason I can't seem to access the RivaTuner Statistics Server; need further research into how to access it in XP) and putting it place a super-aggressive fan curve doesn't help at all.
Edit: Forgot to ask - does any one have any good aftermarket cooler recommendations for this card?
I also went ahead and desoldered the problematic PS/2 connector off my Asus P3B-F motherboard (as detailed here). For the first time at desoldering something, I don't think I did too bad.
Finally, I received from Great Britain a replacement Cirrus Logic 2D PCI GPU for the one I had unintentionally somehow damaged earlier, and, well, things did not go as I hoped. For one, the seller sent me the card, wrapped in a layer of cardboard, without anything protecting the card, so the pins were all bent. 😠 It didn't help that the card was dusty, either. After bending the pins back as best I could, taking the VBIOS chip out to dust it, almost breaking the pins off in the process of removing it, and having to take it out again, because I put it back in reversed ( 😜 ), and cleaning the add-in RAM chips, this is what it looks like:
Sadly, that effort went to waste, as the card already had one foot in the grave, with artifacting right out of the gate, as shown here.
At this point, I'm thinking about getting either an S3 card, since my luck with Cirrus Logic cards from ebay has been piss-poor, or getting an early Nvidia or ATI 3D card to pair with the Voodoo1, since I'm getting tired of dealing with faulty 2D PCI GPUs.
Builds
Reply 10385 of 27687, by brostenen
After a recap some time ago, I thought it would be fun to see how a Lumafix64 will behave in my Commodore64. And it is actually working as intended now. I did not see the big difference before recap, but now... Oh boy.
Then I played some pakman, supercycle, 1942 and great giana sisters. The picture looks 100% brand new, and all details are sharp in the picture. I have set the colour intensity on the lumafix, so it is slightly warmer than the stock C64-c model, and the result is a picture that are somewhat the same as the original breadbin. I can highly say good for a C64 recap and a lumafix64.
Reply 10386 of 27687, by badmojo
Yes I thought the Lumafix was a winner but I found that its effectiveness was variable depending on the VICII - i.e. worked on some better than others. I also found myself re-tuning it constantly and decided that a) it was hard to get it perfect for all games and that b) the length of time my C64 and / or CRT display had been running for also impacted the tuning. In the end I took it out but it definitely had potential.
Reply 10387 of 27687, by brostenen
Those pots. They are variable resistors right?
So finetuning to ones liking and measuring the resistance, and then swap for some standard resistors with that value. Should actually result in a good solution for that specific machine?
Reply 10388 of 27687, by bjwil1991
Oy. At least you know what processor is installed via the BIOS. What are your plans for that machine?
Reply 10389 of 27687, by dionb
Not sure, I'm in the unusual situation of having more 486 stuff than I know what to do with right now. This board is beautiful, but probably the least interesting one I have, as is the CL-GD5426 1MB (with expansion sockets) VLB card in it. I might see if I can swap them for something else - or just sell outright. The case is the best early 1990s one I have, so that's not going anywhere 😉
But before I decide anything hasty, I'm working my way through the rest of that pile. The Pentium 1 system had a dead CR-2032 (and downright refused to boot without working battery), but after replacing that it was 100% working, dual-booting into Linux and Win95. CPU was a lacklustre P90, which made the 50ns SIMMs even more out of place. I also briefly tested the PC-Chips M789. It seems OK, although I need to stress it a bit more before I'm satisfied it's working. The PSU in that case though... I fired it up with a HDD for ballast, and straight on cue it loudly popped two caps. No surprise that's getting a one-way ticket to the bin.
Next up the Slot 1 systems - but might not get round to that for a few days, as it's my youngest son's birthday tomorrow.
Reply 10390 of 27687, by SpectriaForce
Played Tomb Raider: The Last Revelation using my newly built (Windows 95 / DOS hybrid) Pentium II 300 with Riva 128 and SB16 cards. The game runs pretty well, but I noticed that the Riva 128 struggles with fast moving scenes in maximum graphics settings. Interestingly this (patched) game only runs on this system, non of my newer systems can run it (even a GF3 Ti500 with a PIII 500 seems too new for the game).
Reply 10391 of 27687, by Shagittarius
Tomb Raider: The Last Revelation (Steam) runs fine on my Windows 10 RTX 2080ti machine. With the exception that full screen has a title bar.
Reply 10392 of 27687, by oeuvre
Set up triple boot on my Optiplex 745... Windows XP, 7-64, and... 2000!
Thanks to blackwingcat, I was able to run the last version of Firefox ESR for XP on 2000, as well as HexChat. Even found patched AMD drivers for my FirePro V3900. Watching YouTube on Windows 2000 in late 2018 is surreal.
Reply 10393 of 27687, by Murugan
Removed the dead MFM drive from my Olivetti M290 and booted it with a DOS floppy. Tried Leisure Suit Larry 1 and everything works as intented except it doesn't have a HD now.
Cleaned the 2 drives of my 5160 with a floppy cleaner disk but still they don't read all the time.
I will need to look into this since I never worked on this hardware. Might be bad floppy's and/or bad drives?
Cleaned the case of my Commodore PC30-III since I had to open it anyway to install the 287XL.
Just ran some benchmarks to see if it was working since it was bought as not tested.
While it was open, I saw that the HD led was not working. The previous owner connected the header to the SCSI controllercard but the wires were in the wrong sockets of the header.
Received my VLB IO card so this weekend I start my DX2-66 build.
Enough for now 😀
Reply 10394 of 27687, by Vegge
Got this EGA CRT up and running.
1.23 MiB
Bought it function unknown. Found it to be non working with signs of someone trying to get it working, screws missing and so on.
Need to find a place to set it up with a fitting machine 😀
Reply 10395 of 27687, by oeuvre
Here are some screenshots of Windows 2000 on a Q6600.
Programs + specs
Firefox 52.9 ESR, which works with blackwingcat's kernel extensions (and crashes often).
Reply 10396 of 27687, by liqmat
oeuvre wrote:
https://i.imgur.com/fUWa4x0m.jpg […]
Programs + specs
Nope, nope, nope. He-Man will not do. Skeletor please!
Reply 10397 of 27687, by bakemono
I use MyPal 27.9.4 in win2k (with ext kernel) and don't have crashes. One problem is that downloads fail anywhere other than mypal's own directory. I suspect there is a fix for this as Palemoon Portable had the same problem and could be fixed by editing one of the config files. dom.messageChannel.enabled had to be added for craptchas to work, and 1-2 checkboxs under content-video had to be altered for youtube.
I'm surprised that FF 52 can still display the menu bar, I thought they had already done away with it to fit in with the current (reprehensible, IMO) fashion.
Is RAM beyond 3GB usable?
Reply 10398 of 27687, by vmr_
SS7 playground - playing with Rise MP6 333 / 240MHz
SS7 playground - Rise MP6 333 / 240Mhz peculiar results Quake2
Quake 2 tests are puzzling - any ideas?
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 10399 of 27687, by KCompRoom2000
Really cool. I have a Dell Optiplex 745 desktop as well (actually a GX520 upgraded with a 745 motherboard, also a small desktop rather than a tower so it has slightly lower specs), it just runs Windows 7 (64-bit) since it's being used for video editing/transfer purposes.
I have an HP DC7800 SFF desktop with the same CPU as your 745 tower. Since it currently doesn't have a specific use, I might try to install Windows 2000 on it just for fun. I've managed to find drivers for its hardware (save for the AMD Radeon HD6450 GPU which only supports XP+, but if it doesn't have unofficial drivers, I might just stick to its integrated Intel GPU if I decide to do this experiment).
By the looks of it, he used a 3rd party theme on his browser (I've spotted the Home button icon from Firefox 2). The menu bar is still there on the latest Firefox version (although it's optional), but its appearance differs with the Windows version.
