Reply 11620 of 27696, by mikeyp
I've ordered replacement BIOS chips for my Toshiba T1850C notebook, PLCC 32 pin sockets and have put an offer in on a fairly decent hot air soldering rework station. This is phase 1 of the project to resurrect it with a new hard drive. I want to make the soldered BIOS chip socketed and modify the BIOS to support more than just the whitelisted ones. This will be easier if I can use my programmer rather than utilities in DOS with a (potentially) unreliable floppy drive.
Reply 11621 of 27696, by brostenen
Just cleaned a Commodore64 keyboard that I have in spare.... Never mind the yellowing, still clean enough to "use as a dinner plate".
599.9 KiB
468.64 KiB
Reply 11622 of 27696, by Murugan
I am working on my Tandy 1000 TL case (the bay cover was fixated with tape so I try to glue it since it doesn't stay put).
I fired up my latest buy: IBM 5162. Swapped the MDA (which I found weird to find that inside) with a Hedaka OTIVGA card.
The MFM HD is so loud and doesn't sound healthy 😀
Will add a 3,5" floppy in the future and probably a working MFM drive.
Such nice weather outside so enough for today.
Reply 11623 of 27696, by PTherapist
brostenen wrote:
Going 8-Bit my self today.
Testing a new SD2IEC drive and a new Epyx FastLoader Redloaded. Load times are reduced dramatically. One cracktro loaded in 11 seconds with the Fastloader, and 53 seconds without the Fastloader.
That's what I'm hopefully aiming to do also later this year. I never did find my old Commodore 64 in storage so I'm gonna have to buy another one and then get the SD2IEC etc for it.
Reply 11624 of 27696, by PTherapist
Imperious wrote:
I just received a DDI5 From Zaxon at "Sell my Retro" 2 weeks ago, has 512k ram, USB and floppy interface, and an OLED display, and 3D Printed case.
Overall very happy with it. It's the only way You can get the most from these machines.
Only problem He includes no documentation whatsoever, but a bit of research or asking for help on cpcwiki will get You running quickly.
Yeah that's exactly what I'm going to order today. I was originally looking at just the DDI3 without the 3D printed case, but I thought I may as well pay the slight extra for the DDI5 & it's case.
I've seen a YouTube video review of the device so already have some idea of the headaches I'm going to face re- the lack of documentation. But it'll certainly be worth it, as you say, to get the most out of these machines.
Reply 11625 of 27696, by brostenen
Make sure it is a PAL version. 😉 Right now I am reading up on how to extract PRG files from D64 files, and how to save them on real tape. It is easy if you have Windows or OsX. Yet I am on Linux exclusively, so the options in tools/programs are extremely limited, yet I have found a way that are called "DROID64". It is a Java application, that looks like a crossover between Norton Commander (Dos version) and Directory Opus (Amiga version). Then I have found a guide that explains on how to transfer to tape, using a real C64.
Reply 11626 of 27696, by SpectriaForce
McBierle wrote:
So after soldering new caps and reassembling the 5,25 Floppydrive i mentioned earlier, it is living again, which was the last mi […]
So after soldering new caps and reassembling the 5,25 Floppydrive i mentioned earlier, it is living again, which was the last missing part in my DX2-80 system:
- Soyo Sy-025J2 with 16MB Simm-30
- (Octek) Machspeed VGA Gui 2300 (VIO 2300) CL GD5424
- SB16 CT2890 with a Dreamblaster Module
- Aska SST-2946 (UMC Enhanced) VLB-Controller
- 2GB Hdd, CDROM, 3,5" and the mentioned 5,25" Floppydrive
Greetings!
That's one nice generic beige box 😊 You've got to remove the Pentium sticker though 😉
Reply 11627 of 27696, by rick6
Went to play a few games on my retro PC and....
Say goobye to a fallen hero 🙁
611.55 KiB
758.01 KiB
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 11629 of 27696, by rick6
Most likely age. Thermal compound was not old and it was of good quality.
Never took the Geforce 6 series longevity seriously, they seem to fail a lot with age. This one actually lasted a good while.
I don't think this is a bga soldering issue but most likely it's the bondwire from the chip to it's pcb that fails with thermal expansion over time. i read a while ago that the Geforce 6/7 series suffer a lot from this kind of fail.
Reply 11630 of 27696, by x0zm_
Easter long weekend, time to get stuff done! I felt like working on a little bit of everything over the last couple of days, some of which was retro PC related.
One of the things I did was write some simple software to download magazine scans off of Google Books since I wasn't happy with the ones available online in terms of flexibility, options and performance. I enjoy reading magazines, and reading old computer related magazines on old computers & OSes is great fun since printing physical copies isn't viable. So I made a copy of PC Mag from 1995 - 1997 as a test and it worked a treat.
I also tidied up some design on the Pentium III replacement backplate for a 20th Anniversary build I'll be doing later this year. Using a dead 450MHz Pentium III as my dummy, and the SECC Mechanical Guide document from Intel as my reference.
Still have two whole days left so I hope to get more things done. 🤣
Reply 11631 of 27696, by Arctic
Id try to fix it with a heat gun before giving up on it.
rick6 wrote:
Went to play a few games on my retro PC and.... Say goobye to a fallen hero :( […]
Reply 11632 of 27696, by wiretap
I've found that Google Books downloads often are missing pages -- usually you can download from different regions and combine them sans the dupe pages in order to get the full copy. How did you get around that? Another alternative is using "Archive Downloader" Chrome plug-in on something like Archive.org where there are magazine scans uploaded.
https://chrome.google.com/webstore/detail/arc … enmngphliikoace
My Github
Circuit Board Repair Manuals
Reply 11633 of 27696, by Murugan
Changed the HD in my Presario 5130 for the original type hence being 4GB instead of the original 6GB (Quantum Bigfoot).
Fresh install of W98 SE and only thing left is installing the vga driver and find out what the unidentified device is.
Again a sunny day so no more retro.
Reply 11634 of 27696, by oeuvre
got in trouble for connecting to a windows support channel through mIRC In windows 95
Reply 11635 of 27696, by brostenen
How come? Is that not legit or are they taking things too close?
Reply 11636 of 27696, by FuzzyLogic
Played ZeroPaige's C64 port of Super Mario Bros. It's an amazing port and the SID music is excellent. The only problem is the slowdowns. But I think I remember the NES Mario Bros slowed down at times. I know Zelda slowed down a lot.
https://www.lemon64.com/forum/viewtopic.php?p … 2bf0e1a2#867127
Now I have to find out how to rig an NES gamepad to the C64.
Reply 11637 of 27696, by RandomStranger
I decided to reassemble the K5 PC from HERE and I remembered why did I hate it so much. The case was probably made for some OEM PC for a specific motherboard. The boards I have are too low and too far from the back so whatever I do, the cards stay loose. Could be the cause of the stability issues.
I guess I'll use a different case and sell this one since I have no use for it.
Reply 11638 of 27696, by liqmat
Yeah, I've been following that thread as well. Amazing work for sure.
Reply 11639 of 27696, by Vegge
Spent the last 3 nights putting together 3 systems.
K6/2-475 running at 6 x 75, in an old at case as a sort of sleeper.
1.01 MiB
Ppro 200/256 in one of the Aopen HX45s I picked up.
1.16 MiB
An without picture a 200mmx just because.
And today I made another shelf for my closet.
1013.3 KiB
1002.92 KiB
963.1 KiB
I think I need some more room. Got several more system that don't fit 🤣
