Reply 11780 of 27457, by jaZz_KCS
- Oldbie
Yes, if the HDD is not on the list, but you are able to boot with the HDD in place (although wrongfully detected), it means that you at least can use this HDD in your system. And do not have to tamper with the BIOS, as in patching it with XT-IDE or use other boot cards. The fact that it cannot be correctly allocated with the correct size would mean that you just set it to standard and use overlay software (I recommend EZBios), like brostenen mentioned.
--snip--
Spent the last hour to reorganize and rebuild the Vectra VEi8. Changing cable management, replacing the PSU, and also inverting the airflow. The side venting PSUs they used, the air gets sucked in and vented out inside in direction of the slot 1 CPU. But back then it ran Katmais and lower end CopperMines and they had only passive cooling, ergo did benefit from the exhaust of the PSU traveling by, taking a bit of heat with it. But the higher end PIIIs all use active fans on them, and basically need no airflow besides that. Ergo I flipped the PSU fan around, so it sucks the air out of the case instead. I added a ultra low noise fan on the front, which takes air in and blows it directly towards the expansion card area. This area gets rather hot now, because of all the Yamaha synth and DSP cards.
