Reply 11940 of 19656, by buckeye
oeuvre wrote:
https://i.imgur.com/uyAi9p7l.png […]
chkdsk out
Bah! Waiting on the Win 3.1 link! 😵
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
MSI x570 Gaming Pro Carbon Ryzen 3700x 16GB DDR4 Zotac RTX 3070 8GB WD Black 1TB 650W
Reply 11941 of 19656, by PTherapist
Attached a new plug to one of my old C64 joysticks. I used one of those extension cables as the donor plug, but that was no easy task as all the wire colours were different. So I had to saw into the plug at the other end of the cable to find the correct pinout, then open up the joystick to find it's pinout by following the traces on it's circuit board. Extremely tedious but I managed it and the joystick is now working great. Tested on my Amstrad CPC 464. 😎
Also received the Everdrive cartridge I ordered for my Sega Mega Drive. So for the rest of the day I've mostly been playing Mega Drive & Master System games. Almost completed Sonic Chaos, but couldn't quite make that final hit on the last boss, frustrating argh!!! 🤣
Reply 11942 of 19656, by Caluser2000
Setting up networking between my linux box and wfw 3.11 box. Working quite well.
117.98 KiB
Reply 11943 of 19656, by LunarG
Added a PS/2 port to my Pentium 233mmx.
So nice not having to use serial port, seeing as my systems are hooked up to a kvm which uses PS/2.
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 11944 of 19656, by looking4awayout
Not strictly retro related, but it can apply. I've developed a new version of the UOC Patch, which is a patch for Mozilla-based browsers that lets them run a little bit faster and more efficiently on old computers, as long as they support a 128-bit buss DirectX 9 capable graphics card and beyond.
Neverthless, with the patch, Roytam1's Firefox 45 ESR SSE runs fast and snappy on my overclocked Tualatin RDD.
More info here: https://msfn.org/board/topic/178306-experimen … r-old-machines/
My Retro Daily Driver: Pentium !!!-S 1.7GHz | 2GB PC166 ECC SDRAM | Gecube Radeon X1950 Pro 256MB OC | 128GB Lite-On SSD + 500GB WD Blue SSD | Creative Sound Blaster Live! CT4620 | Windows XP Professional SP3
Reply 11945 of 19656, by PTherapist
More cleaning of retro stuff today. I opened up a Sega Master System Model 3060 Control Stick and used some isopropyl alcohol to clean the contacts on the buttons. Prior to cleaning, the buttons weren't responding properly and now it's working fine once again. Not my favourite controller by any means, but good to have it back up and running.
Also tested out a 2nd NES gamepad that I just received. A bit yellowed externally, but functions fine. I can now play 2-player games on my NES! 😎
Reply 11946 of 19656, by gdjacobs
appiah4 wrote:
That card has no MIDI wavetable so you should NOT be using MIDI for music or sound effects in those games. For Prince of Persia just select Adlib for music, for day of the tentacle it should be 100% compatible with SB Pro for Music and Sound. If it crashes on using digitized SB Pro sounds, try using regular SB option, if that also fails it may be a weird IRQ or DMA conflict, would need to know more about the setup.
It does have a standard MPU-401 interface for connecting MIDI devices through the game port or waveblaster header. This is solid and bug free -- a great option as your primary or secondary sound card.
However, as Appiah noted, by default it doesn't have any hardware for turning MIDI messages into sound by default. Cards that do have MIDI synthesis onboard usually say they support wavetable, general MIDI synthesis, or words to this effect. This one needs extra hardware to make it happen.
Reply 11947 of 19656, by RandomStranger
In the morning I decided to reorganize my collection. I took everything out of their boxes, sorted them and labelled the boxes to make it easier to find what I look for. Also that made my storage space less chaotic.
Then I thought it's time to do something with the Pentium dream build I put away for a couple of weeks. As a reminder, ►this is the PC in question◄.
The "new" ASTEC PSU arrived to replace the crapy one, so after testing it with more expendable parts, I installed it.
First time turning it on It showed only a black screen, and second time all kinds of graphical artifact. I shat my pants that the Voodoo died from boredom while waiting for the new PSU.
I moved it into my test motherboard, and everything seemd to be alright:
I moved it back and now it booted with no issue first try. Sadly the Windows 95 it has on now doesn't seem to like my Logitech M-SBF90 PS/2 mouse with a PS/2 to serial adaptor. In the device manager it sees that there is a mouse, but it just doesn't work. Since the PC doesn't have any external USB ports (yet) and I don't have driver CDs for most of the pieces I just installed the AWE64 driver and let it some rest.
Next step is replacing the Trio64V+ with a Matrox Mystyque, find an 8pin USB backplate like ►this one◄ and replace the CPU fan and maybe find a bigger hard drive. After spending some time with the ►3GB drive of my notebook◄, it really doesn't seem that spacious. Though a much bigger would make it less period correct.
A question from last time:
retardware wrote:
This JTS "CHAMP" hard drive gives me an even more uncanny feeling than the L&C power supply. The design was done by infamous Kal […]
The design was done by infamous Kalok.
Never seen a working drive of this brand.
Does the drive actually sound "Kaaaaaa-looooookkkk" as some people suggested back then?
It really doesn't seem that loud. The Seagate from my test PC (picture above) is much louder. Also some of my Quantum Fireballs.
Reply 11948 of 19656, by keenmaster486
Last night I was up until 2:00 in the morning programming a "neural network" in Quick Basic.
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 11949 of 19656, by brostenen
Yesterday I attended at the local annual carneval, and as it was a tiny bit cold then it was perfect to drink beer.
Today I resumed my K7S41/GeodeNX testing. As it turns out, then most soundcards have trouble regarding Dos titles. The average Sounblaster-Live/PCI-128 and so on, are in no way compatible with anything dos. Yet an YMF-724 gives both OPL3 and XG-MIDI in Dos through Win98. Though most titles are not compatible with this setup. This setup are for Win98 gaming only, and if it can play a few Dos titles, then it is pure luck. Who needs such a fast system for Dos anyway?
692.98 KiB
Reply 11950 of 19656, by appiah4
Use a Fortemedia FM-801 card.
Reply 11952 of 19656, by brostenen
What makes it a better choice compared to the other cards that I have when running Win98-only software?
Reply 11953 of 19656, by appiah4
It works much better than YMF-724 in the PCs I used it with, bot has an OPL3/Win9x card as well as a pure MS-DOS card through its great implementation of DDMA.
Reply 11954 of 19656, by dionb
Was playing around with sound cards. Wanted to give my Cx5x86 both SBPro and SB16, so stuck my AudioExcel AV310 (C-Media 8330 chipset) in it. Various reviews call it "the least problematic ISA PnP card ever". Well, YMMV it appears. Somehow it manages to get its own WSS and SB (low) DMAs in a twist. DMA 1 doesn't work in any event and if choosing 0 and 3, it works on the one (WSS or SB) until the other is used, then neither works until a reboot.
First thought was a conflict, but there are no other devices using DMA and a non-PnP SB16 happily works on DMA 1 or 3 in the same system if I swap cards. So seems like either the card is misbehaving or ISA PnP prayers have failed. Oh well, time to find some different drivers/init progs for it and try again.
Reply 11956 of 19656, by PTherapist
Sort of retro related today. I received a cheap spare power adapter for my Sega Master System. Plugged it in and noticed it was emitting a high pitched whistle. I went ahead and tried it on the Master System anyway and whilst it did work, there was a faint scrolling band of interference over the RGB connection. Safe to say that power adapter is not getting used, I'm not risking it!
Reply 11957 of 19656, by keenmaster486
FINALLY got a WPA2 enabled WiFi card to work in Windows 98 after suffering in driver hell for hours.
(thanks dr_st for the tip about the RT2561 chip!)
Reply 11958 of 19656, by appiah4
You could always use a cheap Chinese mini wifi bridge instead; no drivers no headache.
Reply 11959 of 19656, by keenmaster486
This is what I do for my desktops (house not wired for Ethernet 😢 ) and for DOS/Win3.1/Win95 laptops... but for Windows 98SE I like a more integrated experience if possible. Plus those Chinese bridges are very flaky to configure.
