Reply 12240 of 19656, by Mister Xiado
For quick reference:
OEMINFO.INI wrote:
[general]
Manufacturer=Company Name
Model=Custom
[Support Information]
Line1=" For technical support and service,"
Line2=" buy a new computer."
Your logo image, at least in Win9X, 2K, and XP, should be 180x114, and 8 bit color if you want transparency. Palette index 0 will be your transparent color. If you use Paint Shop Pro to create and edit your logo, you can change palette settings under Colors, Edit Palette (in in PSP X, Image, Palette, Edit Palette). Double-click palette index 0 and change it to a color not used in your image. I usually use bright green (#00FF00) or bright purple (#FF00FF). The filenames I use for my images are:
9X: oemlogo.bmp
2K: oemlogo-2k.bmp
XP: oemlogo-xp.bmp
The batch file below handles renaming the files after they've been copied to the appropriate directory. This just allows you to use different images for different Windows Versions, so you can make era-appropriate logos, if that's your fancy.
And for easy-peasy installation of your custom logo and information:
OEM.BAT wrote:
echo off
copy oemlogo.bmp %systemroot%\system32
rem ***************************************************
rem Script for deploying OEM INFO and OEM LOGO to
rem different operating systems
rem Simon Butler, Amset IT Solutions Ltd. 12-12-03
rem see http://www.amset.info/netadmin/oemlogo.asp
rem Requirements
rem And oeminfo.ini file.
rem
rem All three files should be placed in the same
rem directory as this batch file
rem If running from login script, place all three files
rem in your "netlogon" share on the domain controllers.
rem Remember - if you are running from a network share
rem it must be a mapped drive!
rem Get the OS and dump to file
ver >%systemdrive%\ver.txt
Rem now find the operating system and act accordingly
findstr "4.0" %systemdrive%\ver.txt
if not errorlevel 1 goto nt4
findstr "5.0" %systemdrive%\ver.txt
if not errorlevel 1 goto win2k
findstr "5.1" %systemdrive%\ver.txt
if not errorlevel 1 goto winxp
findstr "5.2" %systemdrive%\ver.txt
if not errorlevel 1 goto win2003
goto win9x
:nt4
set OpSys-NT4
echo %OpSys% >>%systemdrive%\result.txt
rem Windows NT4 settings
copy oeminfo.ini "%systemroot%\system32"
copy oemlogo-2k.bmp "%systemroot%\system32"
rename "%systemroot%\system32\oemlogo-2k.bmp" oemlogo.bmp"
goto next
:win2k
set OpSys=Win2K
rem Windows 2000 settings
goto next
:winxp
Show last 43 lines
set OpSys=XP
rem Windows XP settings
copy oemlogo-xp.bmp "%systemroot%\system32"
rename "%systemroot%\system32\oemlogo-xp.bmp" oemlogo.bmp"
goto next
:win2003
set OpSys=Win2003
rem Windows 2003 settings
goto next
:win9x
set OpSys=9x
rem Windows 9x settings
copy oeminfo.ini "%systemroot%\system32\"
copy oemlogo-2k.bmp "%systemroot%\system32\"
rename "%systemroot%\system\oemlogo-2k.bmp" oemlogo.bmp"
goto next
:next
echo done >>%systemdrive%\result.txt
echo Cleaning up!
del %systemdrive%\result.txt
del %systemdrive%\ver.txt
rem if problems, put REM in front of above two lines
rem to read the results files.
Put all of these on a floppy or flash drive, insert, and run the batch file.
Reply 12242 of 19656, by bakemono
It was hot upstairs so I reorganized some stuff down in the retro room. Decided to hook up my MSX2 system and verify it was still working (been a few years). It still showed the correct date! But it had a 1.4GB HDD connected to a Sunrise IDE cartridge. I had to smack it a few times to get it to spin up, and then some files wouldn't read so I guess it's dying. Time to salvage some data while I still can (of course I probably have all the same files on my PC somewhere)
new retro game on itch: https://90soft90.itch.io/glamorous-zombie-flakes
Reply 12243 of 19656, by Jed118
I found a virus on a diskette I installed a game onto a client from.
Naturally, 400+ diskettes were scanned today.
Then I organized them, why not, from this lot:
to this lot:
I took the opportunity to format a handful of diskettes and put them in the "to use" pile while I was at it.
Certified <2006 virus free!
What's for sale? my eBay!
Reply 12244 of 19656, by TheAbandonwareGuy
Jed118 wrote:
I found a virus on a diskette I installed a game onto a client from. […]
to this lot:
What type of virus that would be found on a floppy would be any sort of threat today?
https://www.youtube.com/channel/UCuFY6ZVlYOXA12tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
#Bernie2020 #FeelTheBern
Reply 12245 of 19656, by MMaximus
It certainly is if you use this floppy on a vintage machine with an older OS!
Reply 12246 of 19656, by Warlord
ThinkPad 770x w/ SelectaDock II
300Mhz P II
512 Ram
Trident 975 8MB
440BX Laptop 🤣
SB64G, Voodoo2,Intell 100s Installed in the Dock
IBM DEVA Mpeg2 Decoder + IBMVCAP Only 30% CPU utilization on Pentium 2 300 MHZ
MDK Performance
Reply 12247 of 19656, by Deksor
What executable do you use for MDK with voodoo 2 ? The only 3dfx patch I can find only works right with a voodoo 1
alternative
Reply 12248 of 19656, by Warlord
MDK 3DFX VOODOO2 working
http://www.mediafire.com/file/6nyan5pcpnkoout … 363d17.zip/file
and not sure if it makes a difference I was also using
3D Control Center V1.0
(Direct3D control & switching Utility)
https://3dfxarchive.com/downloads/3dcc.zip
Reply 12250 of 19656, by cyclone3d
Sorta retro activity related.
I had a really trashed PCChips motherboard box that I was going to throw out.
Then I was working on my John Deere 285 Lawn tractor and needed a gasket fore the oil filler tube.
Noticed that the top layer of the corrugated cardboard for the PCChips box was the perfect thickness for the gasket so I made myself a gasket instead of having to wait at least 2 business days to be able to get one if I ordered it. Just enough silicone glue to make a super thin layer on each side of the gasket when installing and it is as good or better than a stock gasket.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 12251 of 19656, by wiretap
Got a new XP rig test booted and partially built.. bought the motherboard as broken, found out that the only problem was a dead CMOS battery. Other than that, it looks brand new. Weird that it wouldn't boot with a dead CMOS battery. Might have been due to not being able to save memory timing/voltages because it kept throwing the bad memory beep code with everything I put in it.
Specs:
ECS KN1 Extreme
AMD Athlon64 FX-57
Thermaltake Big Typhoon CL-P0114
2GB (4x512MB) Crucial Ballistix Tracer DDR500/PC4000/CL2.5
Nvidia GeForce 7800GTX
Coolermaster Mystique "Xoxide/Kikboxes High Roller Case" I won off an Xoxide contest
Next up:
- Install WD Raptor X
- Install DVD-ROM
- Sound card, maybe (DMX6fire or SB Audigy2 ZS)
- Install Windows XP
Circuit Board Repair Manuals
My Project List
Reply 12252 of 19656, by TheAbandonwareGuy
wiretap wrote:
Got a new XP rig test booted and partially built.. bought the motherboard as broken, found out that the only problem was a dead […]
Specs:
ECS KN1 Extreme
AMD Athlon64 FX-57
Next up:
- Install DVD-ROM
What sense would a TerraTec DMX card make for gaming? An X-FI would make much more sense for a build from that era.
Reply 12254 of 19656, by wiretap
I don't believe I said it would be used for gaming. I had some other uses planned for it, such as audio/video work - I mentioned the TerraTec card and Audigy2 ZS since I have those on hand with convenient front I/O panels.
My Project List
Reply 12255 of 19656, by bjwil1991
Cleaned all 14 of my Nintendo 64 game cartridges with DeoxIt and cotton swabs (Q-tips) and the console itself (cartridge slot and left controller ports). I also oiled the heatsink fan for the Socket 5 build a fellow Vogoner sent to me.
Planning on replacing the left controller ports, the cartridge slot, and the casing as it's been broken for a long time. Might do an RGB mod on it.
Reply 12256 of 19656, by kalm_traveler
Trying to get this new retro setup going... out of ideas on why it won't POST with the Corsair HX1000 but works just fine with this ancient VPower 400w hunk-o-junk.
285.02 KiB
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 10980XE, 64gb DDR4, 2x Titan RTX | i9 9900KS, 32gb DDR4, RTX 2080 Ti | '19 Razer Blade Pro
Reply 12258 of 19656, by kalm_traveler
canthearu wrote:
The HX1000 probably doesn't have enough 5 Volt power for it. The Vpower 400W hunk of junk is probably a 3.3V/5V focused PSU, which is why it can handle it better.
I thought that as well, but after looking at the numbers I don't think that's the problem...
There are 4 pins in the 20 pin ATX connector which are +5v, and each pin per spec is only rated for 6A, so 24A of +5v total. This VPower LC-B400ATX has 28A on +3.3v, 40A on +5v, and 17A on +12v rails while the Corsair HX1000 has 30A on +3.3v, 30A on +5v and 100A on +12v.
Given that the VPower has 10A more on its 5v rail I also assumed that to be the reason, though pulling over 30A just to boot up seemed a bit outlandish (I was trying with only the CPUs, 1 RAM stick and an AGP card installed).
However... since 24A is the max possible to pull over the 20 pin ATX connector, I am fairly certain that lacking amps on the 5v rail is not the problem.
Reply 12259 of 19656, by ODwilly
kalm_traveler wrote:
I thought that as well, but after looking at the numbers I don't think that's the problem... […]
Could also be with the giant distance of ATX specs. Like say for example. . .1.3 vs 2.0 or something. The way the PSU delivers power may have something to do with it, like the 12v rail not getting enough usage.
Main pc: Asus ROG laptop. I7-6700HQ, GTX 960M 4gb, 16gb DDR4.
