Reply 12580 of 27504, by derSammler
One thing though, I believe you usually can label the bios images in the modchip's loader. Can it be another bios that's just been incorrectly labeled perhaps?
Certainly not, as it has an animated splash screen saying "IND-BIOS". 😉
Reply 12581 of 27504, by SpectriaForce
Daniël Oosterhuis wrote:
SpectriaForce wrote:
imi wrote:
I'm sure someone would have use for the remains...
If someone is interested in a free Diamond Monster 3D Voodoo with a missing capacitor, then let me know. I still have it.
If you're serious on that, I'd be on that immediately, sounds like a fun repair project to me!
It's on your way.
Reply 12582 of 27504, by Hamby
I bought a Roland PMA-5 portable MIDI synth a couple weeks back (like an SC-55 only small and portable).
229.18 KiB
PMA-5 MIDI synth, 1996, similar to SC-55
Turns out the MIDI - IN port was loose. I figured I'd fix it some day when I worked up the courage, but it was working fine.
Yesterday I got a Roland MIDI-USB adapter cable.
Couldn't get it to work with either my Windows 7 or Linux machine. Figured the cable was bad.
Then, today as I was fiddling with it, trying to get it to work, I would get occasional snippets of sound as I moved or bumped the cable.
So I screwed up my courage and opened the PMA-5 up... it was remarkably clean inside...
161.05 KiB
Inside, 3 circuit boards MIDI, power, sound out on the right
So I got out my soldering iron, which was brand new, only used a few days ago for the first time to solder a USB connector to my Raspberry Pi. Probably not a good one, I got it fairly cheap...
While it was heating, I took a look at the circuit board.
3 of the through-hole contacts looked to have no solder in them. I could wiggle the MIDI port, and the leads would rattle, almost.
So I resoldered them carefully...
148.16 KiB
The three large through hole contacts that had to be soldered are circled in red
I closed it up, connected it to the Linux box... success! Connected it to my Windows 7 box... more success!
It's interesting comparing how the same midi songs and games sound on it compared to the MT-32.
Reply 12583 of 27504, by oeuvre
OPL3 gangnam style. Okay I used an SB Pro in 86Box but whatever.
http://k007.kiwi6.com/hotlink/trbziuucb3/GANGNAMOPL3.mp3
Reply 12584 of 27504, by Caluser2000
Replaced the screen on my Transonic TC-1598LCD 15.6" TV. Normally I'd have thrown it away if it wasn't for the amount of input ports.
1.28 MiB
1.47 MiB
1.25 MiB
Unsure why the last pic is rotated in preview mode.
Reply 12585 of 27504, by gdjacobs
Caluser2000 wrote:
Replaced the screen on my Transonic TC-1598LCD 15.6" TV. Normally I'd have thrown it away if it wasn't for the amount of input […]
Everything but SPDIF.
Reply 12586 of 27504, by bjwil1991
@oeuvre: is there a MIDI file somewhere?
Reply 12587 of 27504, by Caluser2000
I picked the TV a couple of years ago for $NZ10. For some reason the screen developed some dark areas, not sure why as if dye was running through it. The great thing is the new LCD panel comes with a three year warranty. Well worth it.
Reply 12588 of 27504, by bjwil1991
$10 NZD? That's equivalent to $6.44 USD, give or take a few coppers.
Reply 12589 of 27504, by Caluser2000
Yeah I don't think the seller knew how useful it is. Also bought an Android 7" tablet that was advertised as an Ebook viewer quite cheap.
Reply 12590 of 27504, by bjwil1991
A lot of people would say an Android tablet is just for eBook reading. They aren't wrong on that part. I use my Nexus 7 2012 (rooted and custom AOSP 7.1.2 ROM loaded, 32GB storage over the 8GB board it had installed) for car diagnostics (BlueDriver OBD2 scanner), getting the torque specs for every part on every vehicle, watching my shows, and other things.
Reply 12591 of 27504, by Cyrix200+
Jed118 wrote:
Cyrix200+ wrote:
kaputnik wrote:
<snip>
Those 7 segment displays are usually standard off the shelf stuff. Shouldn't be hard or expensive to find a replacement 😀
If you can't find a 2 digit one, I'd guess two 1 digit ones would be fine too. The pin configuration on those displays seems to be pretty standardized.
I have been looking for a replacement last night, the pinout seems standard, and so does the voltage (if I pick the same color). Now finding one (or two) for a decent price (including shipping) is a bit harder. Replacing it with two 1 digit displays seems impossible, it has 2x 9 pins. Will continue the search today.
If you're in the GTA, I know where to get these for pennies. Old school ones too.
GTA?
1982 to 2001
Reply 12592 of 27504, by Daniël Oosterhuis
It's on your way.
Thanks! Looking forward to recapping the missing one and using it in my MMX 😀
Cyrix200+ wrote:
GTA?
I assume he means Greater Toronto Area.
Reply 12593 of 27504, by kaputnik
Ah, well, guess that's proof enough 😀
There's a mirror of the xbins ftp server here, if you want to dump the bios and compare against other images.
Reply 12594 of 27504, by Cyrix200+
<snip>
Cyrix200+ wrote:
GTA?
Or Greater Tokyo Area. Or Grand Theft Auto. 🤣
1982 to 2001
Reply 12595 of 27504, by GigAHerZ
<snip>
Cyrix200+ wrote:
GTA?
Maybe Greater Tallinn Area? 😉
Reply 12597 of 27504, by Mister Xiado
Item 131867610900 on ebay. About 9 EUR total, ships worldwide from Taiwan. Had I the need for one, I'd get one right now. Seems like it fits the bill.
Reply 12598 of 27504, by Tiido
That particular one seems to have muxed digits so it isn't gonna work on the turbo displays that I know of.
Reply 12599 of 27504, by imi
I tried setting up a 386 from scratch today... been a while since I worked with old hardware so I need to ease into it again... at first it didn't boot at all, so I went through touching the cpu... warm... gpu... warm... then I accidentally slipped my finger over the cache... ouch!
there were only two cache chips on the board, but both of them were scorching hot, it took me quite a while to remove them because the cache sockets are right in between the simm sockets and the first isa slot, and one of the chips was jammed in so tight it was hard to get anything underneath to pry it up with.
without cache it bootet up... decided to sort out the cache situation later.
then I hit the next roadblock... I didn't really know how to set up a hard drive from scratch anymore... so I skipped that for now too and tried to boot from my new gotek to just try stuff out a bit...
but that didn't work either, I just couldn't get the gotek to work... a normal floppy seems to work fine, but all my old DOS floppys don't boot, could boot with a win95 start disk and switch to the dos floppy and it seems fine, so idk what's up about that, but since I didn't set up the CF drive yet I couldn't install anything anyways, but I couldn't figure out how to format the usb stick for the gotek, the format function on the gotek itself didn't seem to work... press both buttons and turn on? flashes a number very shortly but doesn't do anything, then I tried the tool from the gotek website but that didn't seem to do anything either... reading around a bit I realized how many different versions there are, I apparently bought a SFR1M44-FEL-DL... so yeah need to figure that out too now.
so all in all I realized I have to re-learn a lot of this stuff and I didn't really get very far 🤣
