Reply 13180 of 19656, by CBM
I am still pushing forward with GZDoom mods 😁
Back in the late 90s I remember creating levels (wads) and dreaming about the modding potential of GZDoom... We did have DeHacked back then though... That did allow for SOME funny experiments atleast, like a rocket launcher that shoots barrels 😁
Main PC SPECS:
CPU: AMD Ryzen 5 2600
GPU: Powercolor Red Devil Radeon RX 5700 XT
RAM: 8GB*4 Corsair Vengeance LPX DDR4 3200MHz
Motherboard: ASUS Prime B450M-A
PSU: Corsair RM850
Reply 13181 of 19656, by dkarguth
Thanks! You're mistaken in the assumption that EGA does not overlap with CGA in memory. MDA resides at memory locations B0000 to B0FFF, and when EGA is in mono mode it overlaps with that area. Similarly, CGA resides at location B8000 to BBFFF, and EGA in color mode overlaps with that memory area. The PGC resides completely out of the way of everything else at C6000. However, it has onboard CGA emulation, so you have to turn that off with a jumper if you want it to coexist with a separate CGA card.
The possible combinations of these cards are:
MDA/Hercules + CGA
MDA/Hercules + PGC (cga emulation enabled)
MDA/Hercules + CGA + PGC (CGA emulation disabled)
MDA/Hercules + EGA (restricted to color modes only)
MDA/Hercules + EGA (color only) + PGC (cga disabled)
EGA (mono modes only) + PGC (cga emulation enabled)
EGA (mono modes only) + CGA + PGC (cga disabled)
For all intents and purposes, EGA in the above combinations can be replaced with VGA. However, you are limited to having a ROM less than 24Kb, as anything larger than that encroaches on the PGC's memory space.
While as shown in the above combinations, you can have a CGA card and an EGA card in the same system, the EGA card would be limited to only mono modes. You'd basically have a glorified hercules card. There's not that much of a point to it unless you don't have another card to put in there instead.
An interesting sidenote is that you can use a Hercules InColor card in place of the regular hercules in all of the combinations, making it possible to have three color monitors instead of two color monitors and a mono one. However, I've never personally seen an incolor card, and would be surprised if much software supported it. Somthing to note about the Hercules card in dual monitor systems is that CGA overlaps with the second graphics page, so you can only use programs that don't use that part of the Hercules card's memory.
As for four monitors, I believe it is possible. I've heard that the early 8 bit TIGA (Texas Instruments Graphics Adapter) cards don't overlap with MDA, CGA, or the PGC. The TIGA is more similar to the PGC than MDA or CGA though.
The PGC does get quite toasty while running. If I remember right, the specs say it draws a whopping 25 watts. Once I source the transmitter card for my 5161 expansion chassis, I plan to keep it in there so it can get better ventilation. I have six IBM Professional Graphics Controllers, so I am trying to learn how to program for them efficiently so that I can make some neat programs that can run on all my systems with PGCs installed.
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 13182 of 19656, by Bruninho
appiah4 wrote:
bfcastello wrote:
Just installed Grand Prix 4 and Grand Prix Legends for a spin. Next, I will install my favorites: F1GP and Grand Prix 2.
In the next days I will have to get back to the basics about the modding in these games. I remember in 1996/97 I was almost an expert in GP2 Modding. Now I can't barely remember how to tweak the f1graphics.cfg for GP4 to achieve a great performance.
I love me some Crammond games but GPL trumps all.
Also why no love for GP3?
I had no luck in getting GPL to run. Oh well. It’s not like I will play all the games I’ve installed...
Tbh GP3 was the shortest time I have spent with. I dunno why. I was considering giving it a spin. My plan is to get GP1 vanilla and GP2 updated on dosbox. Gp3 updated and gp4 with some other season mod on my windows 10 VM.
For GP4, I’m between 1998, 2001, 2005 mods. I will probably go for 2005, if I get GP3 graphics great since it also has the 1998 season.
JOBS, Steve.
List of ALL Android vulnerabilities
Reply 13183 of 19656, by bjwil1991
Opened the belly of the beast, aka, the IBM ThinkPad 380D so that I can test my 2GB CF card using the Dual CF to 44-pin IDE to make sure it works in there and it does. The HDD requires the ODD/FDD to be connected to the board in order for the HDD to get detected. Now that I know how to dismantle the laptop, I can finally order a TFT active display assembly for the laptop to replace the ghosting DSTN color display.
Has a Crystal sound chip and it does FM for DOS games very well, even though the chip is crap. I am still awaiting for the arrival of my newly purchased Toshiba Satellite Pro 410CDT and attempt to install Windows 3.11 on the CF card, then install 95 upgrade with all of the drivers and utilities.
I also found out what was causing the rattling when I was moving the laptop around and found a retaining spring and a piece of plastic that held the spring in place. I still have said parts and I am planning to find the source of where they go to. The keyboard assembly is one interesting piece. I thought the keyboard and mouse (ThinkPoint) buttons would come out of the chassis, however, it's an all in one piece, which is pretty cool and weird.
Reply 13184 of 19656, by FAMICOMASTER
dkarguth wrote:
Huh, I always thought EGA had it's own address space, or that it could be mapped to a different location in order to prevent interfering with other cards.
You have six PGCs? Do you also have six monitors to go with them? How much would you want for a monitor/card, if you were to sell them? I'd be very interested, that's something on my IBM bucket list
Also, did you post something similar to this on Reddit a while back? I could have sworn I saw someone else with a triple monitor XT on there using a similar setup. If so, I was the guy who asked you about your MFM disk drives in the corner of the picture.
Reply 13185 of 19656, by PTherapist
Replaced the drive belts in my 2 Commodore C2N Datasettes with brand new belts and now both units are working great again. Been loading a few game cassettes with them and they've both ran everything I've chucked at them, not even any head alignment or dirt issues. 😎
I'll probably not be using cassettes much with my C64, but it's nice to have them working again and for nostalgia sake I'll probably dig out my full tape collection later and give some of them a go.
Reply 13187 of 19656, by Thermalwrong
Figured out the pinout for the FIC VA-503A! Hooray 😀
I also recapped the whole board while trying to troubleshoot some issues with running applications on this FIC VA503A motherboard:
1.88 MiB
That turned out to be pointless - the board won't work properly with the K6-2 500, but it does work nicely with the K6-III+ 450? So now I've got it stable I'm setting it up with Windows 98 😀
Every single 1000uf cap replaced with Rubycon 10v 1000uf caps with very low ESR.
Also if this helps anyone, here are the capacitors on the FIC VA-503A, only around 4 of them turned out to be actually bad:
272.09 KiB
The extra large capacitor is only what I've seen from the board version that was fitted within an oscilloscope, so I think it would help with stability?
Reply 13188 of 19656, by xjas
Over the last couple days I tried to get some early emulators going on my P3, after watching Modern Vintage Gamer's video on UltraHLE. Unfortunately I didn't have a whole lot of success. I'm running a fairly similar system to the one MVG used (Dell XPS P3/500 + Win98 + Voodoo3 + basic SB PCI 128) and a good analog to the hardware these early emulators were developed on, so I'm not sure why I'm running into so much trouble.
On Original UltraHLE & a few of the pre-source hacked versions (using the Voodoo3 fix), I wasn't able to get any game to run. A few of them looked like they were going to start, but then just sat at a black screen indefinitely. Others that were supposed to be compatible just refused to start.
Using UltraHLE 2064, a later update that was made after the source was released, with an updated games INI from 2017(!), I was able to get a couple games to boot and play, but even those have problems. Doom64 has glitchy graphics, San Francisco Rush 2049 shows no textures on the cars and crashes after a minute, etc. I am aware this emulator has a pretty small compatibility list, but even though I've been sticking to the games that are "known playable", I was only able to get a tiny fraction of them to work.
Still, here's Waverace 64 on UltraHLE 2064 running at reasonably good speed. There was some slowdown but not too bad.
263.99 KiB
On the other hand, Project64 1.6 "just worked" and seems to play most games fine. I played a lot of Ridge Racer and Wipeout 64 on this emulator years ago, and I remember having a pretty good experience with it. This system is too slow to run it at full framerate though; it seems to hit around 35-40 FPS instead of 60, which I'd actually be fine with if the sound weren't chopped to all hell. It'll probably go great on my Athlon 1.4/GF3.
Next I gave ePSXe 1.80 a try, but had similar lack of success to UltraHLE. Lots of black screens, crashes, etc. Eventually when I started switching around video & sound plugins trying to get something to run, I was able to get it to boot the PSX BIOS using an early D3D renderer. (I never did get anything to display on the popular Glide plugin from back in the day.) After getting Valkyrie Profile to boot to the menu once, it just started crashing on launch - deleting the whole program and all the registry keys & reinstalling from the original archive doesn't fix this. I suspect it will never run again, and have no idea why. "Fun" times.
Reply 13189 of 19656, by BetaC
After finding some 80 wire IDE Cables, I decided to attempt to upgrade my Xbox to a semi-SSD via an SD-to-IDE adapter. While I managed to get the cable going, and to overwrite my TSOP with EvoX M8+, I wasn't able to get the adapter to be seen at all. So, instead of doing that, I went and cheated on the Xbox.
440.99 KiB
For whatever reason, my Fat PS2 has zero issues reading the adapter, and, well, who am I to deny that console some much needed quiet storage?
I also managed to use a Wii to copy the save off of my Pokemon Emerald cartridge. I'll probably inject all those events that are almost 15 years out of date.
Reply 13190 of 19656, by FAMICOMASTER
I'm most interested in hearing how you pulled this off.
Reply 13191 of 19656, by PTherapist
Going through and sorting my Commodore 64 games collection today. Only managed to find about half of my collection so far, the rest is buried somewhere in my loft, I'll have to try and find them at some point in the future.
Been having some fun going through a few of these, with at least a 90-95% success rate. I guess I stored these well enough:
Lots without covers unfortunately:
Also found a couple of copied multi-game tapes with no info, so I'm going through and seeing what games are on those for nostalgia sake alone. 🤣
Reply 13192 of 19656, by liqmat
If you have time, maybe check Moby Games to see if all your games are archived. You might have some rare titles that have yet to be recorded. I still run across DOS games, once in a great while, that have yet to be submitted at Moby.
Reply 13193 of 19656, by McBierle
I had an interesting time over the last days with my DX2-80 machine.
At one point i noticed that i had no upper memory, no matter what i did with config/autoexec. After reinstalling dos i got hangs at ramchecks and/or starting games like duke3d. I changed ram and cache. I tried to find ripplevoltage with the PSU and changed it. At one point after i reinstalled dos it seemed that there were no more errors, so i put everything back together...
Next day at one point after a reset i got crazy beepcodes and nothing worked (black). Without hdd it would boot. Well after some reinstalling and frickkeling around i thought to myself "How about starting some AV-software"... 😁
TNT Antivirus got me this: https://malware.wikia.org/wiki/Barrotes
Now i have my first floppy with a big "VIRUS" written on it...
Reply 13194 of 19656, by Caluser2000
Congratulations your first born.
Reply 13195 of 19656, by derSammler
Finished my Compaq Deskpro EP 6400 today. Tried to keep it mostly original. Pentium II 400 MHz with passive cooling (original), Matrox G450 (was: G200), 128 MB RAM (was: 1x 64 MB; added another one), ESS 1868 sound card (original). Also added a Voodoo 2, a Terratec Cinergy TV/AV capture card, and an SSI 2001 clone to listen to the HVSC using a real SID. 😁 (also for the game port)
Nice thing about this machine is that it has a very powerful internal speaker, which sound absolutely great and makes external speakers obsolete.
Running Windows ME because I like it. 😉
Reply 13196 of 19656, by Caluser2000
Scouting the local action and come across this https://www.trademe.co.nz/computers/vintage/l … 25bd9299fef-007
392.83 KiB
Not working.
Reply 13198 of 19656, by xjas
"Does it go? No, but that's not to say it couldn't be resuscitated :-) " == "The battery leaked all over the board and it's irreparable, but I'm hoping one of you suckers is desperate enough to give me $1000 for it anyway :-) "
I'm still kicking myself for not buying a WORKING one of those for $375 shortly after I moved to this area. I'd probably have sold it by now, but I would've made bank.
Reply 13199 of 19656, by liqmat
I used to have a love affair with Amiga back in the day, but emulation is so incredibly good now. Not to mention how easy it is to switch back and forth between the different models for games I just could never go back to the real hardware.
