Reply 13460 of 19657, by Horun
Tested a bunch or 3.5" floppy drives, two were toast but the other dozen work well. Odd part is that the two dead ones are exact same make and model 🙁
Reply 13461 of 19657, by bakemono
Tried to install ReactOS on a Toshiba Portege M200. It didn't go really well.
My biggest beef with ROS has always been that it isn't setup to install FROM harddisk (which is how I always install Windows). You can't start the installer from DOS. I was entertaining the idea of trying to write my own util to start it, but it seems pointless at the moment. The situation has somewhat improved because they now have the INSTALLFREELDR program to create a boot sector that can start their installer. Except this program doesn't run from DOS, and it only creates the boot sector IN the actual boot sector, which means I had to immediately use a sector editor to capture the ROS boot sector and restore the NT one. Because according to their wiki, their installer will save the old boot sector but it won't add it to their boot menu, so when you get a non-working ROS install (like I ultimately did) then you can't boot NT/DOS anymore and you have an unbootable system which is dumb.
With that out of the way, I went through the text mode installer. The files in their boot ISO are in a directory called ReactOS and the default install directory is also ReactOS. So when I hit enter a cryptic error message came up saying I can't install to the same directory and that I had to reboot. But it didn't actually reboot. So I entered a different name and moved on. Later I get a prompt about installing a boot loader, which I don't want for reasons already mentioned, so I chose to skip it. As a result the FREELDR.INI didn't get updated so I couldn't move ahead to the second phase of the install until I edited it manually to boot ROS instead of the text mode setup program.
Trying to boot the second phase froze at SWENUM. Apparently they have big problems with their USB drivers right now that cause this. A suggested fix is to remove/rename the USB?HCI files in the SYSTEM32\DRIVERS dir. On this laptop, going into the BIOS and disabling legacy USB kb/mouse/floppy emulation also seemed to work. The rest of the install was able to complete then. But the OS doesn't actually work, as it reaches a screen that says "press ctrl-alt-delete to begin" where pressing ctrl-alt-del (or any other keys) does nothing.
Aaaand the ReactOS forum is now unusable as it has captchas on it, so I post my story here instead 😀
Reply 13462 of 19657, by lolo799
Played around with my XT for a while:
234.82 KiB
39.91 KiB
47.83 KiB
Then removed the scanner interface to put in a network card, which is way more useful!
176.1 KiB
89.2 KiB
Working fine with the mTCP utilities, but had some problems with bobcat, some misconfiguration somewhere...
Reply 13464 of 19657, by Bruninho
Created a Win98SE and a Win 2k VM (with all the updates and blackwingcat's kernel extension). Tried numerous browsers. Eventually gave up on Win98. Focused on Win 2k, finally got the KEx to work and installed Firefox 52.x ESR, Pale Moon 28.x, then changed desktop color and icons to look like Win 98. Youtube works now. I feel at home now. I wasted a whole weekend for that... the only thing that annoys me is the font quality in my browsers, they are not smooth.
But I feel at home. Dunno why.
JOBS, Steve.
List of ALL Android vulnerabilities
Reply 13465 of 19657, by ragefury32
Went back to the year 2000...
44.83 KiB
To do a set of comparisons between my Pismo G4 Powerbook and my Thinkpad T21...
745.67 KiB
679.28 KiB
666.75 KiB
923.72 KiB
Details to come, but they are fairly evenly matched.
Reply 13466 of 19657, by Bruninho
ragefury32 wrote:
Went back to the year 2000... […]
Happy New Year 2000!!!
JOBS, Steve.
Reply 13467 of 19657, by TheAbandonwareGuy
Isnt the Pismo a G3 PowerBook not a G4?
On my own activities, I diassembled (and ultimatily reduced to parts) BOTH of my 2nd gen I3 powered Toshiba Laptops. One had an unobtainium keyoard that was totally fucked and a non-functional trackpad and numerous other chassis issues, and the other just didn't boot. I pulled the CPUs (both i3 2330's), RAM (all 2GB modules, 4 total 2 per laptop), Optical Drives, Hard Drives, Mounting Hardware, and the keyboard that was good and burned the chassis parts and screens (both of which had scratches). I also kept the batteries one of which is an extended 8800MaH battery. I plan to order a Toshiba of similar age since I have 2 extra batteries, and the experience with the one that worked showed it to perform half-way decently aside from the user interface devices all being FUBAR'd.
Right now I'm using the X200 Tablet as my main laptop and I LOVE this thing. It is everything a laptop should be and more. I think I might also need to pickup a Thinkpad X220 (i3 version of the X200). I love this full size 12.1 laptop/Tablet form factor. Why did this laptop form factor disappear for the stupid ultrabook 2-in-1 form factor anyways?
https://www.youtube.com/channel/UCuFY6ZVlYOXA12tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
#Bernie2020 #FeelTheBern
Reply 13469 of 19657, by Peter Swinkels
pan069 wrote:
Was playing around with my 286 today. Not having touched QuickBasic for close to 30 years, I wondered how long it would take me […]
Was playing around with my 286 today. Not having touched QuickBasic for close to 30 years, I wondered how long it would take me to make analogue clock. Turns out, about an hour or so, had to look up a bunch of stuff I'd forgotten about. Still heaps of room for improvement. 😀
DECLARE SUB drawClock ()
DECLARE SUB drawHour (t$, c%)
DECLARE SUB drawSecond (t$, c%)
CONST PI = 3.141592654#
CONST ORG.X = 640 / 2
CONST ORG.Y = 480 / 2
LET prevTime$ = TIME$
SCREEN 12
CLS
drawClock
ON TIMER(1) GOSUB displayTime
TIMER ON
DO
LOOP UNTIL INKEY$ = CHR$(27)
TIMER OFF
END
displayTime:
LET currTime$ = TIME$
drawHour prevTime$, 0
drawSecond prevTime$, 0
drawHour currTime$, 7
drawSecond currTime$, 15
prevTime$ = currTime$
RETURN
SUB drawClock
LET a = 200
' Draw seconds dots
FOR i = 0 TO PI * 2 - (PI * 2 / 60) STEP (PI * 2 / 60)
LET s = SIN(i)
LET c = COS(i)
LET x = ORG.X + (s * a)
LET y = ORG.Y + (c * a)
LET sd% = s * (180 / PI)
LET cd% = c * (180 / PI)
IF sd% <> 0 AND cd% <> 0 THEN
PSET (x, y), 15
END IF
NEXT i
' Draw hourly dots
FOR i = 0 TO PI * 2 - (PI * 2 / 12) STEP (PI * 2 / 12)
LET s = SIN(i)
LET c = COS(i)
Show last 43 lines
LET r = 1.5
LET k = 7
IF sd% = 0 OR cd% = 0 THEN
r = 3
k = 15
END IF
CIRCLE (x, y), r, k
PAINT (x, y), k
NEXT i
END SUB
LET hh% = VAL(MID$(t$, 1, 2))
LET mm% = VAL(MID$(t$, 4, 2))
LET a = 120
LET f = PI * 2
LET x = ORG.X + SIN(-(f / (12 * 60)) * (hh% * 60 + mm%) + PI) * a
LET y = ORG.Y + COS(-(f / (12 * 60)) * (hh% * 60 + mm%) + PI) * a
LINE (ORG.X, ORG.Y)-(x, y), c%
END SUB
LET ss% = VAL(MID$(t$, 7, 2))
LET a = 190
LET f = PI * 2
LET x = ORG.X + SIN(-(f / 60) * ss% + PI) * a
LET y = ORG.Y + COS(-(f / 60) * ss% + PI) * a
END SUB
Impressive, however you forgot the minute hand! 🤣 Add this to your drawHour procedure:
LET a = 180
LET x = ORG.X + SIN(-(f / 60) * mm% + PI) * a
LET y = ORG.Y + COS(-(f / 60) * mm% + PI) * a
Here's a digital clock I wrote:
DEFINT A-Z
DECLARE FUNCTION GetHours (Seconds#)
DECLARE FUNCTION GetMinutes (Seconds#)
DECLARE FUNCTION GetTime$ ()
DECLARE FUNCTION IIF (Condition, Result1, Result2)
DECLARE FUNCTION TranslateDigit (Digit$)
DECLARE FUNCTION Trim$ (Text$)
DECLARE SUB DisplayTime (x, y, Size, ColorV, Angled)
DECLARE SUB DrawColon (x, y, Size, ColorV, Angled)
DECLARE SUB DrawSegment (x, y, Size, Angle, ColorV)
DECLARE SUB DrawSegments (x, y, Segments, Size, ColorV, Angled)
CONST FALSE = 0
CONST NONE = 0
CONST TRUE = -1
CONST H1 = &H1
CONST H2 = &H2
CONST H3 = &H4
CONST L1 = &H8
CONST L2 = &H10
CONST R1 = &H20
CONST R2 = &H40
CONST C0 = H1 OR H3 OR L1 OR L2 OR R1 OR R2
CONST C1 = R1 OR R2
CONST C2 = H1 OR H2 OR H3 OR L2 OR R1
CONST C3 = H1 OR H2 OR H3 OR R1 OR R2
CONST C4 = H2 OR L1 OR R1 OR R2
CONST C5 = H1 OR H2 OR H3 OR L1 OR R2
CONST C6 = H1 OR H2 OR H3 OR L1 OR L2 OR R2
CONST C7 = H1 OR R1 OR R2
CONST C8 = H1 OR H2 OR H3 OR L1 OR L2 OR R1 OR R2
CONST C9 = H1 OR H2 OR H3 OR L1 OR R1 OR R2
CONST SECONDSPERHOUR = 3600
CONST SECONDSPERMINUTE = 60
SCREEN 7: CLS
ON TIMER(1) GOSUB Tick
TIMER ON
DO UNTIL INKEY$ = CHR$(27)
LOOP
TIMER OFF
END
Tick:
CLS
SCREEN , , 1, 0
DisplayTime 50, 50, 15, 11, TRUE
PCOPY 1, 0
RETURN
STATIC Blink
DisplayedTime$ = GetTime$
CurrentX = x
FOR Index = 1 TO LEN(DisplayedTime$)
Show last 88 lines
      Digit$ = MID$(DisplayedTime$, Index, 1)
IF Digit$ = ":" THEN
IF Blink THEN DrawColon CurrentX, y, Size, ColorV, Angled
CurrentX = CurrentX + (Size * 2)
ELSE
DrawSegments CurrentX, y, TranslateDigit(Digit$), Size, ColorV, Angled
CurrentX = CurrentX + (Size * 3)
END IF
NEXT Index
Blink = NOT Blink
END SUB
Angle = IIF(Angled, -5, 0)
DRAW "C" + STR$(ColorV)
DRAW "BM" + STR$(x) + "," + STR$(y + Size)
DRAW "S" + STR$(Size) + "TA" + STR$(Angle)
DRAW "BU1 F1 G1 H1 E1 BD1 P" + STR$(ColorV) + "," + STR$(ColorV)
DRAW "BD" + STR$(CINT(Size / 2))
END SUB
DRAW "BM" + STR$(x) + "," + STR$(y)
DRAW "BL1 BM-1,-1 R4 F1 G1 L4 H1 E1"
PAINT (x, y), ColorV
END SUB
DrawSegment x, y, Size, 0, IIF((Segments AND H1) = H1, ColorV, 0)
DrawSegment x, y + (Size * 2), Size, 0, IIF((Segments AND H2) = H2, ColorV, 0)
DrawSegment x, y + (Size * 4), Size, 0, IIF((Segments AND H3) = H3, ColorV, 0)
DrawSegment x - Size, y + Size, Size, Angle + 90, IIF((Segments AND L1) = L1, ColorV, 0)
DrawSegment x - Size, y + (Size * 3), Size, Angle + 90, IIF((Segments AND L2) = L2, ColorV, 0)
DrawSegment x + Size, y + Size, Size, Angle + 90, IIF((Segments AND R1) = R1, ColorV, 0)
DrawSegment x + Size, y + (Size * 3), Size, Angle + 90, IIF((Segments AND R2) = R2, ColorV, 0)
END SUB
GetHours = INT(Seconds# / SECONDSPERHOUR)
END FUNCTION
GetMinutes = INT((Seconds# - (GetHours(Seconds#) * CDBL(SECONDSPERHOUR))) / SECONDSPERMINUTE)
END FUNCTION
FUNCTION GetTime$
Hours$ = Trim$(STR$(GetHours(TIMER)))
Minutes$ = Trim$(STR$(GetMinutes(TIMER)))
IF LEN(Hours$) = 1 THEN Hours$ = " " + Hours$
IF LEN(Minutes$) = 1 THEN Minutes$ = "0" + Minutes$
GetTime$ = Hours$ + ":" + Minutes$
END FUNCTION
IIF = Result2
IF Condition THEN IIF = Result1
END FUNCTION
Translation = NONE
SELECT CASE Digit$
CASE "0": Translation = C0
CASE "1": Translation = C1
CASE "2": Translation = C2
CASE "3": Translation = C3
CASE "4": Translation = C4
CASE "5": Translation = C5
CASE "6": Translation = C6
CASE "7": Translation = C7
CASE "8": Translation = C8
CASE "9": Translation = C9
END SELECT
TranslateDigit = Translation
END FUNCTION
Trim$ = LTRIM$(RTRIM$(Text$))
END FUNCTION
And an analog clock:
DEFINT A-Z
DECLARE FUNCTION CurrentTime# (Advance, NewHour, NewMinute, NewSecond)
DECLARE FUNCTION GetSeconds (Seconds#)
DECLARE SUB DrawClock (DisplayedTime#)
DECLARE SUB Main ()
CONST FALSE = 0
CONST NONE = -1
CONST TRUE = -1
CONST BACKGROUND = 0
CONST CLOCKSIZE = 190
CONST HANDNUTSIZE = 3
CONST HOURSTODEGREES = 30
CONST LARGEMARKINTERVAL = 3
CONST MINUTESTODEGREES = 6
CONST MINUTESTOFRACTION# = 1 / 60
CONST PI# = 3.14159265358979#
CONST SECONDSTODEGREES = 6
CONST TWELVEHOURANGLE = -90
CONST CLOCKX = CLOCKSIZE * 1.5
CONST CLOCKY = CLOCKSIZE * 1.1
CONST HOURHANDLENGTH = CLOCKSIZE / 1.6
CONST LARGEMARKLENGTH = HOURHANDLENGTH / 2.5
CONST MINUTEHANDLENGTH = HOURHANDLENGTH * 1.5
CONST SECONDHANDLENGTH = HOURHANDLENGTH * 1.5
CONST SMALLMARKLENGTH = LARGEMARKLENGTH / 2
CONST TORADIANS# = 180 / PI#
ON TIMER(1) GOSUB ClockTick
CALL Main
END
ClockTick:
DrawClock CurrentTime(TRUE, NONE, NONE, NONE)
RETURN
STATIC Seconds#
IF Advance THEN
IF GetSeconds(Seconds#) = 59 THEN
Seconds# = (GetHours(Seconds#) * CLNG(SECONDSPERHOUR)) + (GetMinutes(Seconds#) * SECONDSPERMINUTE)
IF GetMinutes(Seconds#) = 59 THEN
Seconds# = GetHours(Seconds#) * SECONDSPERHOUR
IF GetHours(Seconds#) = 11 THEN
Seconds# = 0
ELSE
Seconds# = Seconds# + SECONDSPERHOUR
END IF
ELSE
Seconds# = Seconds# + SECONDSPERMINUTE
END IF
ELSE
Show last 105 lines
      Seconds# = Seconds# + 1
END IF
ELSE
IF NOT NewHour = NONE THEN Seconds# = GetSeconds(Seconds#) + (GetMinutes(Seconds#) * SECONDSPERMINUTE) + (NewHour * CLNG(SECONDSPERHOUR))
IF NOT NewMinute = NONE THEN Seconds# = GetSeconds(Seconds#) + (NewMinute * SECONDSPERMINUTE) + (GetHours(Seconds#) * CLNG(SECONDSPERHOUR))
IF NOT NewSecond = NONE THEN Seconds# = NewSecond + (GetMinutes(Seconds#) * SECONDSPERMINUTE) + (GetHours(Seconds#) * CLNG(SECONDSPERHOUR))
END IF
CurrentTime = Seconds#
END FUNCTION
DIM HourAsRadians#
DIM HourOnFace
DIM MarkLength
DIM MinuteAsRadians#
DIM SecondAsRadians#
STATIC HourHandX
STATIC HourHandY
STATIC MinuteHandX
STATIC MinuteHandY
STATIC SecondHandX
STATIC SecondHandY
LINE (CLOCKX, CLOCKY)-(HourHandX, HourHandY), BACKGROUND
LINE (CLOCKX, CLOCKY)-(MinuteHandX, MinuteHandY), BACKGROUND
LINE (CLOCKX, CLOCKY)-(SecondHandX, SecondHandY), BACKGROUND
FOR HourOnFace = 0 TO 11
HourAsRadians# = ((HourOnFace * HOURSTODEGREES) + TWELVEHOURANGLE) / TORADIANS#
IF HourOnFace MOD LARGEMARKINTERVAL = 0 THEN MarkLength = LARGEMARKLENGTH ELSE MarkLength = SMALLMARKLENGTH
LINE ((COS(HourAsRadians#) * CLOCKSIZE) + CLOCKX, (SIN(HourAsRadians#) * CLOCKSIZE) + CLOCKY)-((COS(HourAsRadians#) * (CLOCKSIZE - MarkLength)) + CLOCKX, (SIN(HourAsRadians#) * (CLOCKSIZE - MarkLength)) + CLOCKY), 14
NEXT HourOnFace
CIRCLE (CLOCKX, CLOCKY), CLOCKSIZE, 1
HourAsRadians# = (((GetHours(DisplayedTime#) + GetMinutes(DisplayedTime#) * MINUTESTOFRACTION#) * HOURSTODEGREES) + TWELVEHOURANGLE) / TORADIANS#
SecondAsRadians# = ((GetSeconds(DisplayedTime#) * SECONDSTODEGREES) + TWELVEHOURANGLE) / TORADIANS#
MinuteAsRadians# = ((GetMinutes(DisplayedTime#) * MINUTESTODEGREES) + TWELVEHOURANGLE) / TORADIANS#
HourHandX = (COS(HourAsRadians#) * HOURHANDLENGTH) + CLOCKX
HourHandY = (SIN(HourAsRadians#) * HOURHANDLENGTH) + CLOCKY
MinuteHandX = (COS(MinuteAsRadians#) * MINUTEHANDLENGTH) + CLOCKX
MinuteHandY = (SIN(MinuteAsRadians#) * MINUTEHANDLENGTH) + CLOCKY
SecondHandX = (COS(SecondAsRadians#) * SECONDHANDLENGTH) + CLOCKX
SecondHandY = (SIN(SecondAsRadians#) * SECONDHANDLENGTH) + CLOCKY
LINE (CLOCKX, CLOCKY)-(HourHandX, HourHandY), 2
LINE (CLOCKX, CLOCKY)-(MinuteHandX, MinuteHandY), 2
LINE (CLOCKX, CLOCKY)-(SecondHandX, SecondHandY), 4
CIRCLE (CLOCKX, CLOCKY), HANDNUTSIZE, 15
END SUB
END FUNCTION
END FUNCTION
GetSeconds = INT(Seconds# - (GetHours(Seconds#) * CDBL(SECONDSPERHOUR)) - (GetMinutes(Seconds#) * CDBL(SECONDSPERMINUTE)))
END FUNCTION
SUB Main
DIM KeyCode$
DIM Seconds#
SCREEN 12: CLS : COLOR 3
Seconds# = CurrentTime(FALSE, GetHours(TIMER), GetMinutes(TIMER), GetSeconds(TIMER))
DrawClock CurrentTime(FALSE, NONE, NONE, NONE)
LOCATE (CLOCKSIZE / 8) + 3, 1
PRINT " QBClock v1.00 - by: Peter Swinkels, ***2019***"
PRINT " Press the a or A keys to quickly advance the time. Escape = quit"
TIMER ON
DO
DO
KeyCode$ = INKEY$
LOOP WHILE KeyCode$ = ""
IF KeyCode$ = "a" OR KeyCode$ = "A" THEN
Seconds# = CurrentTime(FALSE, NONE, NONE, NONE)
IF KeyCode$ = "A" THEN
IF GetHours(Seconds#) = 11 THEN Seconds# = 0 ELSE Seconds# = Seconds# + SECONDSPERHOUR
ELSE
Seconds# = GetHours(Seconds#) * CLNG(SECONDSPERHOUR)
ELSE
END IF
END IF
DrawClock CurrentTime#(FALSE, GetHours(Seconds#), GetMinutes(Seconds#), NONE)
ELSEIF KeyCode$ = CHR$(27) THEN
EXIT DO
END IF
LOOP
TIMER OFF
END SUB
Reply 13471 of 19657, by ragefury32
It's usually a G3, but I got the Wegener G4 upgrade card, so the machine ran like a Mercury (Titanium PowerBook Rev. A) but minus that liability-of-a-chassis (the TiBooks are notorious for being fragile as they age). I kinda wished that I kept the PowerPC 750e/400MHz Processor card so I can do a comparison between the G3 and the G4, and an out-of-box, as-is comparison between the Pismo and the ThinkPad.
Oh yeah, I had an X41 Tablet - I hear ya. The twist-and-flop form factor is more comfortable to work with. That being said, that hinge is expensive to manufacture and the machine doesn't fold as thinly as the 2-in-one.
Reply 13472 of 19657, by Bruninho
derSammler wrote:
Started backing up the hard disks of my Apple Powerbooks in case they fail or get damaged by a software crash. Did the 190cs yesterday, now the 540c is running its backup.
I'd love to get these wallpapers. I have been using some retro mac wallpapers with my macbooks recently.
JOBS, Steve.
Reply 13473 of 19657, by Bondi
I ran Zandronum (Doom mod) on P233MMX, W98 with Yamaha pcc10xg (PCMCIA) as MIDI device. The card sounds awesome. It also makes a huge difference in terms of performance. If I switch to software Roland MIDI synth the game runs signufucantly slower, becomes unplayable. And with the Yamaha it runs smoothly, yet only in 320x200 mode.
PCMCIA Sound Cards chart
Reply 13474 of 19657, by imi
So, delivery driver offloaded a whole pallet at my house today, the box was big enough to fit me... and inside of it were even more boxes, and inside the larger boxes were even more smaller boxes 🤣
anyways, started to get my stuff a bit organized before I drown in random hardware ^^
247.69 KiB
Reply 13475 of 19657, by pan069
Yeah, I caught that after posting the code here. But cool that someone actually took the time to run the code. 😊
I was going to have stab at adding a digital clock this weekend (if I could find the time), switching between analogue and digital with F1 or something. Your clock looks great! I wasn't yet sure on how I was going to formulate the digital number segments. Maybe your code might give me an idea or two... 😀
Reply 13476 of 19657, by Peter Swinkels
Glad you like my work. Love to see your digital clock.
Reply 13477 of 19657, by Bruninho
Last night I had a go at getting GP4 to run on Windows 2000 SP4. No luck... black screen with music. Got a headache from that so I am resting for some time now.
JOBS, Steve.
Reply 13478 of 19657, by derSammler
The Pismo is even worse. I've got three and gave up trying to fix them. They have flimsy parts everywhere. The "thickness" of the plastic holding the hinges must be a bad joke by whoever designed that thing... Also what breaks easily is the part below the mouse button - and actually that whole case part, the bezel of the display, and so on.
Reply 13479 of 19657, by Xicor
During resurrecting a k6II-450 I suspected immediately that the PSU has not to be trusted. The voltage was ok @ empty or in mild loads, there was indeed a fault lurking. Used my "Chinezium" electronic load to test the 5V rail, and for my amusement @10A I was getting a severe undervoltage.
629.26 KiB
The psu was supposed to supply at least 20A. The undervoltage may not be a cause of catastrophic failure but in time it will degrade the dc-dc converters. So, as precaution we should always suspect this generic Chinese psu bricks, that is if we value the parts that they supply.
