Reply 16860 of 27589, by quovadis11
pan069 wrote on 2020-10-06, 01:13:quovadis11 wrote on 2020-10-06, 00:42:learning MASM, code with VS2019 and build/debug in DOSBOX 😀
I'm considering trying to use Open Watcom.
VC 1.52 works, but the syntax is difficult compared to Borland compilers and the build result is not very good.I use Open Watcom on my Linux desktop. I use wmake to build (although gnu make is nicer/better/easier/current etc). I build binaries into a shared DOSBox drive so it makes development cycle super easy. I.e. I can just use VSCode or Sublime to edit, a normal native terminal to compile and then run from DOSBox. Open Watcom WASM supports MASM syntax (I think).
Oh, Thanks! 😀 I'll considering VSCode/Sublime for editor.
