Reply 19040 of 19588, by BitWrangler
Cool, really tempted to put one of my A500s in one. Though it might make more sense to put the A1200 in one as the CDROM and PSU lashup is a bit primitive. I have a hard time spending money though, dirt poor too long. Maybe I should round up some crap and try for a trade on Amibay 🤣
2017: Basement full of ancient PC stuff, starting to go through it. 2021: Still starting, heh, many setbacks. So what's this BitWrangler guy's deal ??? >>> Taming the pile, specs to target?
Reply 19041 of 19588, by adalbert
Replaced thermal paste in some video cards, I really don't like plastic clip mounting mechanism, so I bought bunch of small springs, M2.5 screws, metal washers, nylon washers and locking nuts. First I tried that with an old Geforce MX, and this is how the - i suppose - original thermal paste looked like... not even touching the heatsink (which is far from being flat). Anyway, putting screws with springs in place of original clips seems to work fine. Nylon washer insulates the PCB.
Repair videos: https://youtu.be/T6mXM1tA7pA
Reply 19042 of 19588, by Merovign
wiretap wrote on 2021-05-23, 11:29:
With the cheapest option being the Raspberry Pi, it works out pretty awesome when you use Pimiga or Amikit. You'll get an excellent Amiga OS experience.
I will have to check that out, thanks!
*Too* *many* *things*!
Reply 19043 of 19588, by bjwil1991
Got the Kawasho Color TV/Radio/Clock/Alarm/Auto-outlet set working (mostly) by spraying DeoxIt D5 in the RF port (3.5mm jack) and the F5 FaderLube in the potentiometers and the slider controls since they were a bit crusty and made the picture jumpy when adjusting the brightness.
1.98 MiB
Next on the list is removing the scratches from the plastic. Paid $8 for it back in 2018 and it's a perfect set to test some A/V equipment: VCRs, DTA boxes, consoles that are RF only, and so on.
Reply 19044 of 19588, by appiah4
Finally managed to capture some S-Video MS-DOS footage from my Cx5x86 PC, and to be honest it turned out to be a lot worse than I thought it would be. I'm not sure what I was expecting..
https://youtu.be/G2BfyX8ujvE
Reply 19045 of 19588, by brian105
adalbert wrote on 2021-05-23, 19:06:
Can you describe how you got those plastic clips out? I wanted to do the same on an MX 440SE but couldn't figure out how to remove those dumb clips.
I cut my finger on a modem
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3 chipset, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD, 20X DVD-ROM
Presario 2100: MediaGX 133, 24MB EDO, Quantum Bigfoot 2GB
Reply 19046 of 19588, by BitWrangler
appiah4 wrote on 2021-05-24, 11:13:
That's not that bad for TV capture, some will look muddier, blurrier and like they were upscaled from QVGA
Reply 19047 of 19588, by pentiumspeed
Probed the Compaq Deskpro 386e's Kingston KTC-x000 32 bit expansion memory board to get map of wirings so I know what are they set up, to wire up to a spare 4MB 72 pin SIMM instead of defective 1MB section, which is made up of 8 x 256k x 4 bit and 4 x 256k x 1.
Cheers,
Great Northern aka Canada.
Reply 19048 of 19588, by creepingnet
I've been posting a some DOS/Vintage Windows stuff on my YouTube Channel - https://www.Youtube.com/creepingnet - as of late. Gearing up to do some other DOS games. Mostly using the NEC's but I'm thinking in the summer I'll break out the Tandy 1000 again and keep the Versas in portable mode and do some videos on the Tandy since I cleaned up my games and sorted them out on that. My videos are a bit slow to come out, I usually record them, forget I have them, then release them months later. Also doing some NES let's plays, and planning to do some really-old-school style Atari 2600 Let's Plays using my phone and a vintage Minolta camera stand. I'm still working out some problems though.....
- Audio - Sound like I'm yelling through a megaphone and a Delay Pedal during the Postal Raw & Uncut and Theme Hospital videos. I think this is likely because of hardware monitoring being on without headphones so I'm changing my configuration for that.
- Video - Going to dig up an S-Video cable at some point and hope that improves the VGA output a little bit. Right now I'm using VGA to Composite into a NV06 VHS capture device so things like Postal and Theme Hospital are a little fuzzy. It's AMAZING for 256 color VGA 320x200, EGA, CGA, and NES stuff though.
All the DOS/Windows stuff I'm doing is recorded using a 2014 Dell Inspiron 15 with 8GB of RAM, 128GB SSD, and OBS Studio.
I broke out the P/75 with the intent to record some Monkey Island Let's Plays at some point since I can still beat both of those 100% from Memory somehow after 30 years, including speed through the insult swordfighting part. However, my Versa P/75 is being a bit of a cantankerous mess.....sometimes SoundBlaster outputs through the internal speaker, sometimes it does'nt. Might need to find the ESS688 drivers for DOS so I can turn the Mic off because when it works I get nasty high pitched microphonic feedback from the internal mic. Also I don't think that Dell battery is up to the task of keeping the CMOS refreshed so I'll probably be returning to a CR2430 holder.
Not in much of a rush on the computer stuff though, probably going to make some more guitar videos first since that's what my primary audience likes.
~The Creeping Network~
My Website - https://sites.google.com/site/thecreepingnetwork/home - ending 9/2021
NEW WEBSITE - 9/2021 https://creepingnet.neocities.org/
Reply 19049 of 19588, by bjwil1991
Got some of the hard drive situation under control on my Wyse WY-2108 system, however, it doesn't like any DOS version past 6.22 on a hard drive, let alone a Windows 95 boot diskette.
The BIOS ROM on the Promise EIDEPro doesn't like the system for some reason due to being the version 1.03, which worked on my 386 before I upgraded the board and I/O cards to VLB, including the video card.
On the plus side, the XT-IDE Universal BIOS works with the Promise care after I disabled the on-board BIOS and put the XT-IDE BIOS on my 3C509 NIC.
Reply 19050 of 19588, by Shagittarius
bjwil1991 wrote on 2021-05-24, 23:14:
A 286 wont work with DOS beyond 6.22 as far as I know.
Reply 19051 of 19588, by Caluser2000
A 286 will run IBM PC Dos 7.0 just fine and dandy....
Reply 19052 of 19588, by appiah4
Got @HanJammer 's 3.5" CF-IDE drive bay printed for my Cx5x86 PC last week, got it installed yesterday. Unfortunately, it didn't go flush as I had hoped. I could shave a bit off the sides and push it in a bit further, unfortunately if I do that then the screw hole won't align. I can drill a new one with the Dremel, of course, but I'm a bit tpp lazy to do that today. Maybe on the weekend.
Reply 19054 of 19588, by bjwil1991
Caluser2000 wrote on 2021-05-25, 00:09:
I'll give the IBM DOS 7.0 a whirl. Just need to order 1.44MB diskettes so I'll write the XDF images to the diskettes and switched the drives over and go from there.
I wonder, would the PC-DOS 2000 work on a 286 as well or not really?
Reply 19055 of 19588, by Caluser2000
bjwil1991 wrote on 2021-05-25, 18:12:
Theres only one way to fing out I guess. Some years ago I posted a comparisom a member vcged , wvwestlife iirc ,made of the comparison the various Dos version free conventional memory left without any other software being loaded. IBM PC Dos 7.x had almost as much free conventional memory as MS Dos 3.3.
Reply 19056 of 19588, by hyoenmadan
Just for the record.
IBM DOS 7 isn't the same thing as MS DOS 7. IBM DOS 7 is more akin to MSDOS 6 than to MSDOS 7.
Reply 19057 of 19588, by Caluser2000
hyoenmadan wrote on 2021-05-25, 19:07:
There is no official MS Dos 7 stand alone version. MS Dos 7 doesn't support FAT 32 either. MS DOs 7.1 does as does the last version of IBM DOs 7.x.
Reply 19059 of 19588, by BitWrangler
Dragged out the Sharp PC-4641 the HDD version of the PC-4600 series, where the PC-4602 is the dual floppy version. 10Mhz V20, 40MB HDD, 4 greyscale mono CGA LCD, nice keyboard, 720MB floppy, par, ser, extfloppy ports... Now I never had the original PSU for it, says it takes 2.4A, 9 volts, center NEGATIVE (Emphasis because center positive seems to be batting for defacto standard nowadays.) ... so last time, all I could find was megawart lump that only put out 1.5A... and I thought that was worth trying for life signs, due to a) not having to charge the battery and b) none of the options like modem, external display, EMS or ROM pack are installed, so peak draw shouldn't be so peaky. I ran it a number of times on that, 7 years ago maybe... Now I thought the HDD would not boot, had bad boot sector beyond what fdisk /mbr would sort out, but was accessible if you booted from floppy... so I plug this adapter in this time, hit power and get one green wink and nothing... damn... IDK if the PSU or the internal PC supplies are weak... hmmm... OH, yeah I had rigged a 9V PSU with more than 2A for testing a radio out with, center neg, w00t... let's just try that before I crack her open... BEEP.. crunch.. grind... the normal ones... it only freaking boots... off the hard drive now.. . damn, guess it was pulling that other wart kinda low. Yayyy... then it was supper time.. more later maybe.
