Reply 19380 of 27650, by Caluser2000
My AMD K6-2 project is coming along quite nicely. The first modo never displayed anything and no beep errors. I replaced that with a slightly older one and it is rocking along with the ndd pulled from tje HP P200mmx system. There is a significant increase in speed. Booting to the desktop in a minute and half....😉
    669.57 KiB
Reply 19381 of 27650, by xcomcmdr
Caluser2000 wrote on 2021-07-06, 19:48:
The HP P200mmx packed a sad last night and doesn't. Done the normal trouble shooting stuff.
You monster ! Linux killed it !
Reply 19382 of 27650, by Caluser2000
xcomcmdr wrote on 2021-07-07, 07:06:
No I threatened that I was going to install MickySoft Windows 95 OSR 2.5 on it......😉
Reply 19383 of 27650, by brostenen
Recieved the cartridge shell for my naked PCB C64 DeadTest cartridge, and installed it into the shell.
Proceded to add a homemade label on the cartridge, that seemed fitting.
Not the most beautifull, but it is just a test cartridge after all.
227.96 KiB
Reply 19384 of 27650, by SteveC
The hard drive on my PS/2 model 70 pretty much never spins up now so resurrected another ESDI drive I had spare which has a 'snow' of bad sectors. The drive failed to low level format from the reference disk, just telling to replace the drive - always failed on track 666! The majority of the bad sectors (about 46KB worth) are in the last third of the drive so have partitioned 80MB C: from the 120MB total and formatted it in DOS a few times and the number of bad sectors has stayed steady at 12KB so I'm hoping it'll not get any worse!
Now slowly restoring the drive backup from a Zip disk.
Reply 19385 of 27650, by PC@LIVE
Restarted two PCs: An Olidata with P166MMX Overdrive, currently it is on the bench and I have been working on it for a while, I added a USB PCI card (NEC chip) with 5 ports, the motherboard is LPX from the intel mod. Advanced M / A Monaco (if I remember correctly), i430FX-66 chipset, having only single voltage, the only way to use a P.MMX was the Overdrive which has the regulator for the built-in Vcore, the total of the installed memory is 64MB (4X 16MB EDO?).
Being an LPX it has a Riser card, on the one hand there are two PCI slots and one ISA, on the other hand there is only one ISA slot, in addition there is both audio and video integrated, the video is ATI MACH64 from 1MB expandable to 2MB (there are 2 empty sockets to add chips).
As hd I have a 4GB maxtor with W98SE, a 1.44MB floppy and a 4X cd player.
The USB card is useful for me to connect anything to the PC, but usually the use is for Pendrive.
The other is an AMD 5x86-133MHz P75, mounted in a BEK V429S VER2.0 VLB (Baby-AT), with 16MB of RAM 256KB cache, three VLB slots and five 16bit ISA, Opti chipset.
2MB CL-GD5429 VLB video card (expanded long ago by adding one MB), ISA Opti931 sound card, ISA Realtek LAN card.
1GB HD with W95 installed, 1.44MB floppy, 4X Philips CD player (or maybe 6x?).
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 19386 of 27650, by PcBytes
Just came home and got some time to test a few parts I have not been able to test further on my trip.
One of them is a ASUS GTX670 2GB GDDR5 DirectCu II - this one works fine, and it was a steal for how much I paid for it ($12). Does need a new HSF though, although it passed Furmark at quite crispy temps (65*C max) but that's because I took the liberty to replace the hardened thermal paste it had with some brand new Arctic MX5.
The other is a MSI K7N2 Delta-ILSR - basically the full version to the previous K7N2 Delta-L I had - this one features a 3rd IDE port + 2x SATA150 thanks to the Promise PDC20378 controller onboard, 1394 managed by some Agere chip I think (not sure if it's the nVidia chipset that is controlling it or it's the separate Agere chip.), and active cooling for the northbridge (which I might have to replace - IIRC I had an ABIT HSF somewhere around that might fit and is active cooled as well.)
Initial testing mislead me to think the CPUs I had were all bad, but it quickly got dismissed once I took out an Jetway N2PAP-Lite and tested each CPUs in it, with each POST-ing successfully (except an mobile Athlon XP 2600+ in S462 package which I honestly don't even know why am I keeping and what benefits would it bring.).
An additional test confirmed my hunch - the original BIOS chip on the K7N2 was either corrupted or the contents were from a failed flash - this was further confirmed once I swapped the socketed PLCC32 between boards (as in using the N2PAP BIOS on the K7N2, which I knew it would work as it worked just fine on the Delta-L variant I previously had) and got the BIOS screen from the Jetway BIOS on my K7N2.
This meant, of course, I had to hotflash the old chip (not sure if this can be really called hotflashing considering I am actually using the board from which I have to hotflash the BIOS), run Flashrom and get the chip programmed. This was done pretty quickly, thanks to a spare 8GB WD Protege and a H-L GSA-H12N DVDRW. Since the drive already had a 98SE install done eons ago (it's at least three or four years old at this point), I just booted off a DVD called F4UBCD (FalconFour's Ultimate Boot CD, a quite handy disc which has MiniXP and Hiren's Boot CD in one ISO) into a live XP session, whipped up Explorer, copied the W6570NMS.780 BIOS onto the 98SE drive where I had a BIOS folder full of BINs for various mobos (ABIT, Soyo, DFI, LuckyTech, EPoX, ZIDA, Chaintech and the list could very well go on for long) along with two flashers (Uniflash 1.40 and 2.00RC, and Flashrom).
Then finally, I hotswapped once I booted into command prompt only, cd'd into the BIOS directory, then ran the command "flashrom -p internal -w W6570NMS.780". Flashrom detected my chip (some SST I don't exactly remember right now), wrote the BIN to it, verified the chip, then end. I shut the mobo off to clear the CMOS from RAM (since I didn't drop in any CR2032 battery yet), then powered everything back up, and got my board to work correctly.
In the end, here's a photo of the final result. Don't mind the CPUs down there, they were subsequently tested once I got the first working POST using MSI's original BIOS.
file.php?mode=view&id=114144
Reply 19387 of 27650, by BitWrangler
Nforce and mobile don't play nice together, CPU may work in a Via, SiS, or AMD board.
Reply 19388 of 27650, by PcBytes
I did try that Mobile 2600 on a ECS KT600 and a ASUS A7V600-X and neither POST'd. The only one it liked was a PCChips M848 mobo I had crossflashed with a DFI BIOS (748AL to be specific) but the reported procesor was wrong. (something like Athlon 1100MHz)
Reply 19389 of 27650, by Caluser2000
Just cruising the internet using a modern Linux distribution on my K6-2 400...😉
    94 KiB
Reply 19390 of 27650, by appiah4
Undid the overclock on my IBM 5x86-100 from 120MHz to 100MHz, it turns out the system was actually suffering from some instability after all. I did benchmarks with 7 DOS programs and on average I seem to have lost 16.7% performance.
I also upgraded its video card from an MX86200 PCI to a Riva128 PCI and that made VESA mode games a million times better. Now it's a fantastic DOS PC.
Reply 19391 of 27650, by lolo799
Removed the dead battery, the mobo reminds me a bit of the Acorn A7000 one by its size.
392.75 KiB
Transferred some files via floppy disks to try Linux/m68k
24.77 KiB
79.91 KiB
It lives!
24.53 KiB
Waiting for some extra RAM to arrive.
Lovely booting and shutting down hdd noises...
Performa450.m4a
675.86 KiB
47 downloads
Reply 19392 of 27650, by BetaC
lolo799 wrote on 2021-07-09, 14:52:
Removed the dead battery, the mobo reminds me a bit of the Acorn A7000 one by its size.20210709_123109.jpgTransferred some files via floppy disks to try Linux/m68k20210706_200050_1_1.jpg
20210709_123553_1.jpgIt lives!20210706_195337_1_1.jpgWaiting for some extra RAM to arrive.
Lovely booting and shutting down hdd noises...Performa450.m4a
I’m legitimately surprised at how comparatively quiet my 80 MB SCSI drive is by comparison.
Reply 19393 of 27650, by BitWrangler
It's not a "real" hard drive unless it makes you fear for the structural integrity of the desk while it's coming up to speed 🤣 (Full height ST506)
Reply 19394 of 27650, by Caluser2000
BitWrangler wrote on 2021-07-09, 20:03:
He! he! he! Absolutely love it 🤣!
The 20meg scsi hdd on my Mac SE is quite loud but still seems to chug along quite nicely after all these years...😉
Reply 19395 of 27650, by Caluser2000
Nice work man...😉
Reply 19396 of 27650, by babtras
Got a 386 desktop going, with a genuine AdLib card in it. Installed the AdLib Jukebox and enjoyed grooving to the tunes. Now I can start working on how to play music from a Turbo C++ program.
Reply 19397 of 27650, by SteveC
Just playing with the OPL2LPT on my PS/2 Model 70 and forgot what a lovely sound it has. I know there are YouTube videos of an hour compliation of DOS game music but it'd be great to have something running on real hardware that did the same!
Reply 19398 of 27650, by Caluser2000
Just found the Debian 4 and Net BSD 5 cds the chat gave me when I got my first A700 Acorn RiscPC
No MickySoft Windows NT though. But is that really a bad thing.
Remember folks ARM originally stood for ACORN RISC MACHINE And 30years plus later Apple has finally got a clue...😉
    679.52 KiB
Reply 19399 of 27650, by lolo799
BetaC wrote on 2021-07-09, 19:49:
How does it sound at shutdown?
Make some recording, there is a lack of hdd noises collection thread on the forums!
I agree, and so does my Syquest Sparq!
Caluser2000 wrote on 2021-07-09, 20:11:
Same, make some recording^
The only difficult part was finding a soft to make splitted zip archives and unzip them, from my powerbook to the 450.
Caluser2000 wrote on 2021-07-09, 20:40:
Of course it runs NetBSD!
