Reply 22780 of 27454, by chrismeyer6
BitWrangler wrote on 2022-09-29, 03:24:Hah, note to self... don't turn on machines you haven't built yourself... Story starts years back... emachine with socket 754 board in, XP2600 or something the sempron of semprons socket 754 chip, 32bit only. Dirt cheap impulse pickup, thought actually from the badging it had a decent barton inside it, nope. Anyhoo, think I tried booting it a couple of times and it was flaky. Goes into a storage pile, pulled it out about 5 years back and get nothing out of it... can't be bothered with it. So today, I decide I want it's mATX case.. move it around and 2 screws appear in the bottom of the case... take the motherboard out and there's 3 more loose screws under there, wow! It's a wonder I didn't smoke the place out. IDK if I'll check that board out sometime sans shorts, it's 3rd choice 754 board at the moment and I only want one 754 system going.
I need to build myself a decent vacuum cleaner, household ones are too big and clunky, "computer" vacuums are so pathetic they don't do anything. I hate using air duster much because it just fills up the air I'm tryna breathe with crap, plus you can go through $20 of air dusters in an afternoon if you're going through much. Anyway gotta look into something with like a 1/2" nozzle, handheld and enough suction to lift stuff up and bag it. I have the parts of one of those rechargeable vacuums with dead batts, so might use some of that. Just make it less klutzy for getting in the corners of cases.
I'm kinda doing a sleeper build M4A785-M into the eMach mATX, it's probably gonna be more modern. Though I just got bummed out because at first glance I took the IDC pin header sitting next to the PATA pin header to be a floppy header... but nah.. it's the parallel port header, derp, that's why it looks too short, why da crap is it over there. So since this case got a custom faceplate floppy, I'm wondering if I wanna have it sitting there useless mocking me, or whether I wanna try another mATX for the AM2/3 board and stick a duron mATX in this one. It's not a real nice case though, front panel got "Kyled" there's crack in it. Will see what else is around.
Get yourself a cheap electric leaf blower. Once a quarter I take all of our systems outside and give them a good blow out with the leaf blower and in about 10 minute all of our systems are cleaned. And doing it outside keeps all that dust and dirt from ending up all of your house and ultimately back inside your computers.
