Reply 23300 of 27499, by Shponglefan
Replaced the CD-ROM drive on my Pentium 133 build. The previous Toshiba 6x was making weird ticking noises, so I swapped in an 8x Mitsumi.
After hooking up the CD audio cable, tested it with the most period appropriate soundtrack I could find. 😁
    494.16 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 23301 of 27499, by Demetrio
Did some test of this tool: https://github.com/TheSandBoxMKG/ipxgw, that allows IPX multiplayer games between real MS-DOS/Win9x and DOSBox.
Used DOOM as test case, it worked!
Gonna use it to play online, through a virtual LAN, with some friend 😁
Reply 23303 of 27499, by Gmlb256
Demetrio wrote on 2022-12-01, 17:05:
Nice! 👍
I did something like that to play Hexen in co-op but with a USB to serial port years ago.
Reply 23304 of 27499, by Demetrio
Kahenraz wrote on 2022-12-01, 20:01:
Those floppy drives and CD drive match that case perfectly! It looks great.
Thanks a lot 🙂
Practically, I didn't need the 2nd floppy drive, but I added it anyway cause it looks good 😄
Reply 23306 of 27499, by amadeus777999
Very Nice!
Reply 23307 of 27499, by PD2JK
Investigating this Satellite 2800-200, won't turn on. Well, if the power button isn't connected, it sure won't... 😀
    1.06 MiB
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 23308 of 27499, by RandomStranger
Yesterday I installed the MSI TV-tuner card into my Shuttle XPC and replaced the CMOS battery in my XP build. The Shuttle is even more cramped than it first looked. I don't know if a longer sound card, like an Audigy 2 ZS would fit.
Today I went to this year's last vintage market. Month after month it kept getting worse for vintage computer parts. I hoped I could pick up some Geforce MX on the cheap, but today I haven't found ANY expansion cards. Not even the odd modem and networking cards you always find.
So I just picked up another pair of aluminum water bottles, 16 neodymium magnets, a boxed copy of Fallout 3 GOTY and FlatOut, and these:
1.19 MiB
Another addition to my pin-up art collection and a 1GB old-stock Intenso flashdrive that is an actual PEN-drive.
Reply 23309 of 27499, by henk717
Recorded a video for my MS-Dos 7.1 floppy : https://www.youtube.com/watch?v=M7Mp0szm-fA
Spent a lot of effort over the years on making this the most feature packed boot floppy I could make, its a single floppy that allows you to install MS-Dos 7.1 with a good set of memory managers, slowdown utilities, cd-drivers, tools and more.
Reply 23310 of 27499, by stef80
Today was a "Zalman" day:
1.4 MiB
1.63 MiB
9800XT now runs in low to mid 40s under load 😀.
Both cards have quite hot memory chips (Samsung 2.8ns on FireGL/9700Pro and Hynix 2.5ns on 9800XT), so porcupines will help.
Reply 23311 of 27499, by PD2JK
Nice cards. That orange got me thinking it was a X800 card. Take good care of them, R3xx based cards always tend to die on me.
Reply 23312 of 27499, by Virtua
i noticed today three caps on my windows 98 board hidden by the cpu heatsink were... rather embiggened. spent a little bit dismantling rather than playing unreal, so yeah...
win 10 : x570-a pro • ryzen 5900x • geforce rtx 3070 • sound blaster x ae-5 plus
win 98 : k8-vm800 • athlon 3000+ • radeon 9600 • sound blaster live! 5.1
Reply 23313 of 27499, by stef80
PD2JK wrote on 2022-12-05, 13:26:
It's stock cooling solution that kills them in most cases. Also, I'm out of Zalmans 🙁.
Reply 23314 of 27499, by HanSolo
henk717 wrote on 2022-12-05, 01:25:
Awesome! That's a great project.
And it comes just at the right time as I'm about to install my DOS/Win98-Laptop and I'm still using my tools from 'back then'.
Reply 23315 of 27499, by henk717
HanSolo wrote on 2022-12-05, 18:08:
Thanks! It feels a lot like digital origamy trying to find ways to squeeze out enough kilobytes to make more programs fit, most of it has been compressed with UPX on the strongest settings (After decompressing the original compression of the file).
Let me know how it works for you 😁
Reply 23316 of 27499, by HanSolo
henk717 wrote on 2022-12-05, 18:24:
As an Exe-packer I would recommend aPACK. That gave me better results than UPX on a 4K-Intro 20 years ago. (But things might look different with larger Exe-files)
Have you considered using the higher density format of Fdformat that you also mention in the video? I used that back then for some of my disks.
Reply 23317 of 27499, by henk717
HanSolo wrote on 2022-12-05, 18:46:
Ill keep aPack in mind since for some programs the UPX result was broken while the original one was with aPack.
I have considered the 1.72M format, but wanted to maintain maximum floppy drive compatibility since not all drives can handle that well.
Reply 23318 of 27499, by PD2JK
henk717 wrote on 2022-12-05, 19:28:
Is that some kind of overburn feature for floppies? Or more bits per track?
Reply 23319 of 27499, by HanSolo
PD2JK wrote on 2022-12-05, 20:58:
More sectors (up to 21) per track and more tracks (up to 82).
