Reply 24160 of 27506, by Kahenraz
Iarsin wrote on 2023-04-09, 18:44:
I'm more interested in a CPU-z DOS version to identify for example the Mainboard of the Unisys pw² 500 16A. I need a manual for […]
I'm more interested in a CPU-z DOS version to identify for example the Mainboard of the Unisys pw² 500 16A. I need a manual for it's dip switches/jumper settings. The imprints are a bit unclear for me to make sense of.
But I actually doubt, that some sort of diagnostics tool can identify the Mainboard, and I think, it's really only build for this PC. A 386 doesn't come with dmi or the like.
There is a manual of the pw² 300 in the driver section, though.
Anyway, a DOS version would be cool, or at least for win 3.* ...
Would it take 4*16MB fpm SIMMs 30-pin? I got some handy.
HWiNFO for DOS provides a lot of hardware information.
Reply 24161 of 27506, by Veeb0rg
Ozzuneoj wrote on 2023-04-06, 18:37:
Law212 wrote on 2023-04-06, 18:33:
Finished setting up my pentium 2 Voodoo 2 sli setup. […]
Im using a monster 2 8 meg card and a voodoo 2 12 meg card which isnt ideal but its all i have for now.
That SLI bridge PCB is pretty neat. I can't help but feel that one of the real 3dfx logos should have been used on it though. Where did you get it?
Looks like they're here - https://www.serdashop.com/3DVideoBridge
Reply 24162 of 27506, by Veeb0rg
Iarsin wrote on 2023-04-07, 12:09:
I try to get some old MFM and rll hard drives running, but I never have done that before. So I'm not successful at all.
Don't be discouraged, those old drives literally die on their own from age. Adrian's digital basement did several videos on trying to revive some.
Reply 24163 of 27506, by Brawndo
Got the video and sound card drivers and applications installed in my 1998 Dell Win98 system, and installed all the updates from the Windows Security 2004 CD. All that's left is to update the Live! drivers to the LiveWare 3.0 version, install the latest officially supported DirectX for Win98, and then it's time to install some games!
Reply 24164 of 27506, by Demetrio
Me and a friend of mine wanted to play some Quake 2 coop so I used this moment to make some test:
  • Tested Internet multiplayer on my retro PII build
    I set up a coop server on an AWS VM (the free one 😁) and invited my friend to play. He used a Mac with Yamagi source port and had no problem, while I experienced severe lag with my Pentium II build; I believe the bottleneck is the ISA ethernet card, which cannot keep up with modern clients speed.
    Overall we had fun 🙂
  • Tested VGA capture
    Recorded my build VGA for the first time, through OBS: video was good while the audio was corrupted. Have to investigate the issue.
Uploaded a video of the test: https://youtu.be/OfdK-150bfs
I placed the Quake 2 OST over it for the audio recording problem.
Reply 24165 of 27506, by Kahenraz
Veeb0rg wrote on 2023-04-10, 04:26:
The motor shaft can also freeze if it's been stationary for too long. If it's accessible, you can try giving it some help.
Reply 24166 of 27506, by Iarsin
What kind of oil is suitable? Can I use oil for sewing machines? Or WD-40?
Tested once okay, but I think it's way to slow? It also did some noise that sounds exceptionally slow for stepper and maybe also heads?
The Unisys test Tool only counted read errors.
Submit is greyed out when attaching files, I already noticed Saturday.
Therefore I'm also not able to send a Soundfile.
Reply 24167 of 27506, by Iarsin
None of the diagnostic tools will tell about the Mainboard. Therefor I actually think CPU-z will also not achieve that anyway.
The BIOS strings will tell Unisys pw² 500 16A, I guess.
Reply 24168 of 27506, by dormcat
Iarsin wrote on 2023-04-10, 10:00:
I wonder how many 386-era motherboards had make and model info written in BIOS so a third-party software could read it out. 🙄
Reply 24169 of 27506, by stef80
Finally finished my "Year2k" build based on PIII Coppermine 1GHz, Voodoo 5 and Aureal Vortex 2:
1.92 MiB
1.84 MiB
Very silent it is 😉.
It's based on a PC I had in 2001, with some changes:
* GeForce2MX -> 3dfx V5 5500
* SB Live! -> Aureal SQ2500
Case is actually the same.
Reply 24170 of 27506, by Kahenraz
There is no need to compromise. A PCI Sound Blaster can happily live alongside an Aureal Vortex. You just need to feed the line-out of one into the line-in of the other.
Getting the drivers configured is a bit tricky, though. Make sure to disable legacy sound emulation for one of them in Device Manager, otherwise they will conflict. Also install the Aureal drivers last or backup and restore the a3d.dll that is installed. Creative's version has bugs, and you need the Aureal one to work with the other card anyways.
Reply 24172 of 27506, by stamasd
It lives. 😀
Had to glue the case back together in a number of places, add a composite out mod and a PAL/NTSC converter, and also build a US-compatible power supply.
The cassette player/recorder is still busted.
But the "computer" part works fine.
    661.28 KiB
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 24173 of 27506, by PTherapist
stamasd wrote on 2023-04-10, 19:58:
It lives. :) Had to glue the case back together in a number of places, add a composite out mod and a PAL/NTSC converter, and als […]
It lives. 😀
Good work!
The cassette deck will probably need a new belt, I had to do that on mine several years ago and was pretty much the only thing wrong with it. I hardly ever use cassettes though, a DivMMC expansion makes life much easier all around.
Reply 24174 of 27506, by stamasd
It's more than a belt; several of the buttons don't work properly, either can't be pressed down or when pressed don't click in place and stay down (the "play" button does that), so there's more to it.
It's not critical, I have a Interface 1bis to use with it https://sites.google.com/site/interface1bis/
and a TZXduino.
I/O, I/O,
I/O, I/O
Reply 24176 of 27506, by BitWrangler
BTW I've used several "broke" cassette boomboxes as amps with merely a cassette/aux adapter, they don't need to turn, stop, eject well or anything else, all you need is some play mechanism function to get the head in place, even if you have to wedge the button down. So, it's possible you might get it "working" with one of those, with the 3.5mm plugged into another tape deck, MP3 player, winCE handheld (They play wav well) or laptop or desktop.
Reply 24177 of 27506, by Kahenraz
I've had a lot of trouble using much newer cassette decks with my ZX81. Recording is particularly difficult. It's much better to use a mono cable or adapter as well.
This was the advantage of the all-in-one units. No need to fiddle with an external tape deck.
Reply 24178 of 27506, by stamasd
Kahenraz wrote on 2023-04-11, 13:06:
Depending on the mechanism, of it's some kind of carbon-backed switch or dome, you can repair these with a bit of special paint. 8-bit Guy did an episode on this for a different keyboard.
It's not the computer keyboard. That works fine. It's the controls of the mechanism of the tape deck, you see those at the bottom right of the picture separate from the keyboard.
There's something that mechanically stops them from operating correctly. Probably some part broken inside.
I think this machine had some sort of mechanical shock applied to it at one point. All of the standoffs that hold the 2 halves of the case together were broken and the bottom part of the case was cracked. That may have damaged the mechanism of the tape deck as well.
At least the PCB was intact and it works correctly. And the keyboard, which would be a pain to replace.
(BTW the PCB is actually +2B rev.1 not +2A; it's part number Z70833 - in theory I could remove the tape mechanism altogether and replace it with an original disk unit, and it would work seamlessly)
I/O, I/O,
I/O, I/O
