Reply 24440 of 27649, by RandomStranger
appiah4 wrote on 2023-06-05, 11:35:
RandomStranger wrote on 2023-06-05, 11:15:
appiah4 wrote on 2023-06-05, 10:14:
I have no idea how that may have burnt. I misaligned and inversely plugged in wavetable headers before and never managed to burn anything before. Please check C25 for a short.. But I have a feeling they plugged in something other than a wavetable onto that header - the header itself looks a bit melted in fact..
Nah, the wavetable header is alright. It was still a little wet after the wash. C56, the one between the wavetable pin in question and the ground also seems to be fine (at least not shorted). Will check C25 and C26 when I get home. This is sadly bad news. If something inappropriate was connected to the card, it increases the risk of serious damage.
That is probably a power rail from the ISA bus leading to the wavetable header through some filtering caps, so if that rail got shorted elsewhere and there was a current surge all of a sudden.. well you know..
I wouldn't try that card out on an important motherboard for sure.
It should to be B7, -12V. There are 2 other traces this burnt one roasted a bit. They still make contact where they should and not shorted to this -12V trace. One below the LM1877N chip, the other belongs to pin-2 on the wavetable header. And I don't know what's under C26.
Edit: All the caps around the disaster area seems to be fine for now (not shorted).
Reply 24441 of 27649, by BetaC
Sombrero wrote on 2023-06-05, 06:56:
BetaC wrote on 2023-06-05, 06:17:
After feeling the need to play through TIE Fighter again, I finally moved my UMAX mac clone out of the way, and set up my DOS machine again. This, in turn, led me to figuring out why windows 3.11 wasn't happy with my sound setup, and figuring out that I had accidentally set both sound cards to using the same DMAs and IRQs. Now that those issues are cleared, and my system has been downgraded to a 100MHz Pentium 75, I can play TIE fighter without the speed issues that even 233MHz can introduce.
I've noticed CPU speed affects even mouse sensitivity in TIE Fighter, the faster CPU the more sluggish the mouse gets. No idea does it affect joysticks but if you are using one and it feels like you aren't turning as fast as you should, then 100MHz is still too fast.
Seems like I'm currently going through a period of planned obsolescence, all my stuff is breaking. First 6800 GT croaked, then Voodoo3 2000 and now Sound Blaster Z I had in my "modern" PC (that just had its 9th birthday) continued the streak. What's next in line, my apartment burns down and I get leprosy?
I usually use TIE Bomber historical Mission 2 as a way to test if my machine is good. at 100MHz, the station immediately starts to fire at me as I get close enough.
Reply 24442 of 27649, by OSkar000
I went thru a bag of random 72pin memory modules to find something for one of my next projects.
203.87 KiB
And found 2x8mb FPM... not much but enough to boot a system that doesn't run with EDO.
186.69 KiB
Last week I took a peek inside the PSU and it looks ok from what I could see.
255.49 KiB
And to make everything as eay as possible... a huge motherboard with lots of fun stuff on it 😀
Reply 24443 of 27649, by TheAbandonwareGuy
I somehow created a card that blew out the AGP port on my test rig by attempting to reflow the VGA port on a GF2Mx that had a dead blue channel.
There are no solder bridges I can find... I'm honestly more dumbfounded than angry. Like how does reflowing the VGA port cause the card to blow up the AGP port? As soon as I turned the PC on I got the magic smoke from near the front of the AGP port. Now it doesn't even recognize when a AGP card is installed, still boots off the integrated graphics.
Kind of sucks, the nForce2 with Integrated GF440Mx graphics motherboard in that thing is kind of rare, but I have another one held as spare so no big loss to me personally and that IS sort of the job of the test rig, to fall upon its sword in place of a more unique machine if something goes horribly wrong.
Reply 24444 of 27649, by BitWrangler
Bummer.... any of those small SMD electrolytics near it that could have cooked to a short?
I had a try at burning something on the graphics side myself today. Acer SFF box, again forgot the rule of "If you didn't build it yourself go through it with a fine tooth comb before you power it up." ... because it had no video .. well not out of either onboard nor Gt710 15pin VGA, after turning it on and off enough times to mangle the windows install (maybe... it might have been improperly set up or halfassed) I realised the GT710 didn't have it's VGA header plugged properly, it was on a single row of pins, gah... so risked blowing something there maybe with less forgiving monitor.... anyhoo, sorted that, booted... munched windoze.
Reply 24446 of 27649, by TheAbandonwareGuy
BitWrangler wrote on 2023-06-06, 01:58:
Not that I could see with the motherboard in the case.
Going to pull the board at some point. I think it actually burnt out the traces for the +12v on the AGP port though, so likely not fixable.
Reply 24447 of 27649, by rasz_pl
OSkar000 wrote on 2023-06-05, 19:22:
You can mod any EDO module to FPM
https://www.youtube.com/watch?v=nk8uEFpYbBw Re: What retro activity did you get up to today?
TheAbandonwareGuy wrote on 2023-06-05, 19:55:
There are no solder bridges I can find... soon as I turned the PC on I got the magic smoke from near the front of the AGP port. Now it doesn't even recognize when a AGP card is installed, still boots off the integrated graphics.
doesnt have to be visible, might have happened in the connector or inner PCB, most likely shorted power and blew up regulator powering AGP slot on the board
Reply 24448 of 27649, by appiah4
You probably did not reflow it smoothly enough. With an uneven solder surface on any voltage rail of the edge connector it would have created a loose connection between the card and the slot, which would in turn create a point of near infinite resistance between the card and the voltage source. V = i x R so the card will try to draw that current through the infinite resistance and cause both overloading of the PSU and overheading of the port destroying the card, the port, and the PSU or some combination of them.
Reply 24449 of 27649, by RandomStranger
So far I patched the burnt trace,replaced a funny looking cap, with a needle went through between the legs of the ES1868F chip and checked if there is any shorts between them, then made some turn-on tests with an expendable PC, but without monitor. Based on the boot sounds and beeps the card doesn't make a difference in an obviously bad way, nothing blew up.
993.17 KiB
777.82 KiB
1.2 MiB
Not my best soldering job, but seems to be alright for now.
Reply 24450 of 27649, by OSkar000
rasz_pl wrote on 2023-06-06, 07:55:
Thanks! I will give that a try! I have some 16mb EDO modules that I could use for experiments 😀
Reply 24451 of 27649, by rasz_pl
appiah4 wrote on 2023-06-06, 08:31:
? infinite resistance means open circuit means no power draw at all
voltage never goes up, bigger R means smaller i
Reply 24452 of 27649, by appiah4
rasz_pl wrote on 2023-06-06, 11:03:
? infinite resistance means open circuit means no power draw at all […]
It's OBVIOUSLY not effectively infinite, and I never said it was INFINITE, I said it was NEAR INFINITE, which means it would be a (possibly intermittent) VERY, VERY, VERY high resistance area in the voltage circuit.
I also never said Voltage would go up, I said the card would try to draw the current through that resistance regardless. It would result in a huge thermal issue at the contact area, and as the heat builds it would eventually overload the PSU and destroy the slot/card.
I really think you either have a reading comprehension problem or are just an overall asshole.
Reply 24453 of 27649, by BitWrangler
appiah4 wrote on 2023-06-06, 12:02:
It's OBVIOUSLY not effectively infinite, and I never said it was INFINITE, I said it was NEAR INFINITE, which means it would be […]
Near infinite or 100,000 ohms across a power rail, or in series circuit to load is gonna do practically nothing. I = V/R
Reply 24454 of 27649, by appiah4
BitWrangler wrote on 2023-06-06, 13:23:
Depends on the power rail, the ISA slot has 2 5V rails for example, and if both are being used and one is intermittently going up to 100KR and then dropping to 0R, well.
Reply 24455 of 27649, by rasz_pl
Your tongue has "NEAR INFINITE" resistance (~1Mohm), if you lick 5V power rail you will feel whole 5 uAmps flowing thru you (micro, 5 zeroes after the dot).
ok, so voltage stays the same, resistance is "NEAR INFINITE" meaning amps are "INFINITESIMAL". Where does the energy come from to cause "huge thermal issue"?
overall asshole.
some people interpreted being factually correct in weird emotional ways 😐
Reply 24456 of 27649, by rkurbatov
Finished soldering of this beauty from Labs. If somebody is interested - more details in his topic (BlasterBoard 2.0). Very nice card, perfect match for 80386.
    362.57 KiB
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 24457 of 27649, by Thermalwrong
OSkar000 wrote on 2023-06-06, 10:48:
Good luck with it, the two sticks I modified are still working happily and pass memtest on that 486 board 😀
Apparently it can work for the larger 16-bit 42-pin SoJ modules too, you just have to link the nearest !CAS line to the !OE pin.
1.13 MiB
I have had such an ordeal! I've been trying to get a working screen for my Toshiba Satellite 400CDT since the lower 1/4 row of pixels didn't work - I bought a 'new' replacement LCD from focus_memory on thebay and that replacement LCD had the same fault and had some really weird flickering problem. They sent me a new one which worked for almost a whole game of solitaire then it blanked out never to work again.
I just can't deal with getting either of these sent back or replaced again and I bet the seller would hate me for it too. The return was about to close anyway so I dove into both displays.
Display 1: Taking the metal front off, there was some weird black tape over one of the row-segment drivers - this LCD isn't new or old-stock at all and has been repaired! unlike my first display where the row-segment was corroded off from a drink spill, this one's row segment driver was a clean break on the actual pins that are soldered to the controller rather than the part that's glued onto the LCD panel. So I put the fine tip on my iron and used a PCB scrap to push down the flex PCB of the row-segment driver onto the control PCB and soldered it down. Now LCD #1 is working! if I'd opened it up before I could've saved weeks and the LCD is really nice now that it works.
The flickering problem? This LCD panel has 3x control boards, one with the main processory chip and the row-segment drivers, one with the column-segment drivers and a PCB that looks like it generates some voltages and other signals. The broken LCD panel that was in this laptop to start with I kept the parts of it for future use, good thing I did because they fixed two LCD panels... The voltages board has 6x small variable resistor trim-pots and adjusting them while the laptop is on can do some odd things, reduce/increase flickering, brighten/darken the panel, introduce ghosting. The parts-panel I had, I swapped the voltages-board from that and the display looked great.
But I don't want to waste this part on this LCD, so I initially measured the trimpot values and tried to match on this LCD's original voltages-board. That worked, but what worked better was just visually matching the positions. I guess there are enough capacitors and other things in the circuits that measuring values in circuit won't work. But these are 1x turn tiny trimpots so just matching them up visually meant the original voltages-board from this LCD can be used.
At least with the refurbishing they fit a new front polariser so polariser-breakdown is a long way away for this panel and it looks fantastic.
Display 2: Looking at the back of this LCD that turned white mid-use, it appears to have been in the ocean for a while. All of the chips on the 3x control boards and their board-to-board connectors have corrosion. And the plastic part of the LCD was all smashed up. Really glad I kept panel 0 for parts.
At this point I'm very familiar with the LTM10C021 panel from Toshiba. It's way less integrated than later panels and uses 2x board-to-board connectors, lots of failure points where corrosion gets. So again I used the parts from the broken display panel to make this one work, taking the voltages-board and replacing a board-to-board connector which ugh, actually required using the microscope. It worked after I cleared all the shorts.
Of course my work on it was a bit heavy-handed and the chip-on-film connector for one of the column-segment drivers got separated from the glass a little, so there's a bunch of funny coloured strips on the right-most columns of the panel, but it works again!!
So to fix that, I used some of the rubber strip that from the parts-panel that's used to stop dust-ingress. Cut that up to fit the last column-segment driver and layered a few of these little rubber strips, now with the metal front in place, that presses down the mylar flex-pcb onto the LCD glass's contacts and the rightmost part of the display looks good again.
An ordeal, but at the end of the day I bought one panel and now I have 2x working panels, so okay. Focus_memory handled my complaint pretty well but the selection of available parts for old computers is getting rather limited.
Reply 24458 of 27649, by TheAbandonwareGuy
PSUs fine
AGP interface is clearly OK as the Integrated 440MX still works
Board otherwise works.
So just the physical port itself. I suspect the card too but its a card with a value of $10, so needless to say I'm not offering up another board to the GPU gods to find out.
Reply 24459 of 27649, by ediflorianUS
TheAbandonwareGuy wrote on 2023-06-04, 18:22:
Say does anyone remember what this game is? I asked on Reddit a few years ago but nobody ever could tell me what it was. This is a either DOS or early Windows game I played when I was really young
The main things I remember are that it had a ludicris number of discs, and that the discs came in a binder sort of like the binder like Phantasmagoria or the software bundles new PCs used to come with.
The very first thing that I remember happening in the game was some sort of escape or maybe chase sequence that if you failed you blew up. I want to say you were re-entering a planets atmosphere in an escape pod. Right after that your in some sort of industrial base/military looking area with a lot of lava.
Is it Dragon's Lair 3D: Return to the Lair from Disney? Remember ing it large , 1CD back when evrything was floppy....
or Dragon Lore II: The Heart of the Dragon Man ? (3xCD's in 1996)
or how about Dragon's Lair from 1993 (1 full CD)
My 80486-S i66 Project
