Reply 25120 of 27589, by Shponglefan
- l33t
Tried to repair this Asus A7N8X-X motherboard.
Initially the board wouldn't stay powered on. It would power off automatically after a few seconds. Some of the 3300uF caps were bulging, so I removed and tested them. They were all bad.
Replacing them with new caps has now led to the board staying on, but still won't POST. Further testing revealed there is a short. I keep getting a 30 ohm resistance on all the caps I replaced, along with another of other components in and around that area (MOSFETs, inductors, SMD caps, etc.). So I proceeded to undo my recapping to see I'd maybe caused the short.
But even after removing all the replaced caps, the short remains.
Further testing and tracing led me to the underside of the nForce2 400 chip. One 'edge' of those caps shows the 30 ohm short, some of them 15 ohms, and some not shorted.
Now I'm wondering if the issue is the main nForce chip itself, unless I can find something else in the mean time.
