Reply 26420 of 27685, by dominusprog
Bruno128 wrote on 2024-01-13, 00:42:
dominusprog wrote on 2024-01-12, 18:24:
Replaced the amplifier caps on this Creative Vibra card.
Noticeable change?
Well, the left channel was very quiet and noisy.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 26421 of 27685, by GigAHerZ
On my P2/P3 testbench, I ordered a ATX extension cable and spliced in molex/sata/fdd power connector right to the ATX extension. Now i have a single-cable solution on my default testbench.
I still have separate cables coming from PSU that is under the table. This extension with all the power for devices stays with that particular testbench. Whenever i need to power another machine, not the testbench, i can just disconnect this single ATX extension cable from PSU ATX connector and move that testbench away.
(Unfortunately i missed one when counting wires, so one wire got an extra sleeve without any additional cables coming out of it. It's the green one.)
Reply 26422 of 27685, by Nexxen
Kahenraz wrote on 2024-01-13, 06:16:
Nexxen wrote on 2024-01-13, 00:54:
Reorganized my mobo storage order.
I have to stop buying them. They have puppy eyes though...
I have this same problem. I just went through my motherboard collection a few weeks ago and made a pile of "what was I thinking" boards.
I can relate 😀
And I don't have multiple of the same board model (like a Super S7, or older). But nice boards surface from time to time and it's a pity to see them go to recycling.
My issue #1 is that I don't have enough room anymore. Even the basement space is full of other stuff.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 26423 of 27685, by PcBytes
Opening my closet can result in an avalanche event 🤣
Reply 26424 of 27685, by DerBaum
I did a small Ooopsie...
I needed some old serial Eeproms... Around 4 or 5.
Then i found an ebay seller offering an auction for just 1 euro per chip, wich is a good price.
So i bought all the remaining stock of 9. (If i need 5 i want at least 2 spare chips...) for 9 euros plus 4 shipping.
Today the chips arrived and i found out that the offer was not for 1 chip per auction... It was for 10.
Now i have 90 tiny (4kbit / 512byte) and pretty special serial eeproms basically nobody uses today 😁
Thats ok for me...
1.45 MiB
EDIT:
The best part is... I even ordered the wrong parts. I needed 2 wire serial eeproms and ordered 3 wire serial eeproms. 😐
Maybe i can use them for another project instead...
Great success... like always...
FCKGW-RHQQ2
Reply 26425 of 27685, by Susanin79
Played a bit with my 486 EISA, swapping CPU to the DX4ODPR100 and did some tests. Unfortunately the slow cache modules didn't allow to run it with the WS0. The performance of the Olivetti EVC-1 video card was not impressive 😀, however, I didn't expect much from it.
Here is the results in compare with the Ultimate 486 Benchmark Comparison tread:
Benchmark results:
MB details
CPU Vog Intel DX4100 Intel DX4100
Model SK096 (P24D) DX4ODPR100
L1 Cache 16KB WB 16KB WT
L2 Cache 256KB WB 256KB WB
RAM 128M FPM 32MB FPM
Symantec Sysinfo v8.0 (arb. units) 216 120,9
PC-Config v9.33 (% of Pentium 100) 66 50
CpuIndex v2.3 (arb. units) 9 9
PiDOS [25k digits] (sec.) 22 25
Landmark v2.0
Integer ALU (Mhz) 363 338
Floating-point FPU (Mhz) 819 815
Video (char/sec) 13845 1746
Checkit 4
Dhrystones 39211
Whetstones 13579,5
BIOS Video Speed 23674
Direct Video Speed 453735
Chaikin Benchmark DOS v1.0
Memory - ALU (arb. units) 7,2 6,9
Floating Point (arb. units) 8,3 7,9
Bytemark v2, 32-bit Windows
(ALU) Numeric Sort (iterations/sec) 25,9 22,69
(ALU) String Sort (iterations/sec) 1,41 0,66
Bitfield (mil of iterations/sec) 3,81 3,75
ALU) FP Emulation (iterations/sec) 1,57 1,41
(FPU) Fourier (iterations/sec) 376 348,9
(ALU) Assignment (iterations/sec) 0,192 0,18
(ALU) IDEA (iterations/sec) 50,3 47,83
(ALU) Huffman (iterations/sec) 32,6 31,65
(FPU) Neural Net (iterations/sec) 0,191 0,171
(FPU) LU Decomposition (iter/sec) 7,23 6,24
Integer Index (% of Pentium 90) 72,4 61,33
Floating-point Index (% of P90) 39 34,77
Roy Longbottom Dhrystone v1.1
[Integer, Optimised]
DHRY1OD (VAX MIPS Rating) 93 62,8
Roy Longbottom Linpack
[Rolled Double Precision, Optimised]
LINPCOD (MFLOPS) 4,6 3,91
Roy Longbottom Whetstone
[Single Precision, Optimised]
WHETCOD, MWIPS (MFLOPS) 26,2 25,24
N1, Floating Point (MFLOPS) 7,9 7,19
N2, Floating Point (MFLOPS) 6 5,54
N3, If Then Else (MOPS) 9,5 9,2
N4, Fixed Point (MOPS) 15,4 14,13
N5, Sine, Cosine (MOPS) 0,81 0,95
N6, Floating Point (MFLOPS) 4,1 3,89
N7, Assignments (MOPS) 8,6 5,08
N8, Exp, Sqrt, etc (MOPS) 0,53 0,52
Speedsys v4.78
Score (arb. units) 42,4 37,38
Video Memory Bandwidth (MB/s) 34,4
System Memory Bandwidth (MB/s) 100 58,13
Ave. L1 Cache (MB/s) 94 53,92
Ave. L2 Cache (MB/s) 50 32,65
Ave. RAM Throughput (MB/s) 37 20,38
Show last 18 lines
Cachechk v4.0
L1 Cache (MB/s) 104 102,2
L2 Cache (MB/s) 56 51,5
Memory (MB/s) 37 24,4
RAM Access Time (Read) (ns) 114 171
RAM Access Time (Write) (ns) 61 132
3Dbench v1.0 (arb. units) 71,4 24,3
Doom v1.9s timedemo3 (fps)
FPS 40,8 10,99
Quake v1.06 timedemo1
FPS [320x200, fs, console off] 12,1 7,7
Test completion time 125,3
VIDSPEED (write)
320x200x256 1847
640x400x256 2232
640x480x256 1818
800x600x256 2232
    1.87 MiB
    Digis-486E EISA overal view
Reply 26426 of 27685, by PcBytes
Moar LX fun.
QDI Legend V, Deschutes 300 SL2W8 (which apparently might be one of the unlocked Deschutes?), 2x128MB PC100 and a nice selection of my personal cards - MX440, 8139C NIC, NEC UsB2 card, ES1373 PCI, and a 20GB Maxtor.
file.php?mode=view&id=182874
file.php?mode=view&id=182875
Still got a long road to go with it - the 98SE install on the Maxtor was an absolutely untouched 98SE install done on a CT-5AGM2 I sold.
Also, a group shot of the slots 😁
file.php?mode=view&id=182876
From left to right - Luckytech P6BX2 w/ Katmai 500 (yes, it is a Katmai, reshelled into what was a boring locked Deschutes 266 I think), Soyo 6BA+IV w/ Coppermine 650, Zida 6DLX w/ Celeron 433, and my most favourite Slot1 combo - BE6-II w/ P3 1000B SL5DV. Been hoping I'd swap it for a 1000EB, and I think I know just the right classified and fellow retro enthusiast to order some chips from 😀
Reply 26427 of 27685, by kingcake
Does anyone know the name of these loops motherboards use for chipset heatsinks? They just look like standard 2.54mm headers but with a loop. I've tried searching mouser and aliexpress but can't find them. Searched through all the test points and headers.
84.28 KiB
Reply 26428 of 27685, by DerBaum
kingcake wrote on 2024-01-13, 23:33:
http://www.yinghuachina.com/Products/594.html
these?
i searched for "pin header hook"
FCKGW-RHQQ2
Reply 26430 of 27685, by kingcake
DerBaum wrote on 2024-01-13, 23:35:
http://www.yinghuachina.com/Products/594.html […]
these?
Thank you! They weren't showing up because I put 2.54mm in all my searches. Looks like they list them under 5.08mm pitch since they skip a position.
Reply 26431 of 27685, by creepingnet
Got back into retrocomputing for awhile, started moving storage into my new abode (Garage). Now I have a computing spot in the garage with the Compaq and Tandy - so now all three PC's are running all year around (my 486 is in my office space now since it sees frequent use and a lot of experimentation).
Broke out the NanTan 9200 and FMA3500C. PLayed some games on the 9200...seems my trackball fix worked nicely once I let the ball settle in.
The FMA3500 is getting an 80GB HDD Finally, the CMOS Battery repair wore out....but I have some ideas (Varta was replaced with CR-series). Going to start focusing on tuning/tweaking/modding/fixing-up that one. Really liked the dry-run of the 80GB HDD.
~The Creeping Network~
Reply 26432 of 27685, by Minutemanqvs
My mission today is to update the firmwares of all Matrox cards I have, from the Mystique/Millennium to the Parhelias. It looked quite simple in theory. But for older cards the update utility absolutely insists on having a real DOS environment and formatting a diskette...and I have Windows 2000 almost everywhere. So time to get out the 486 for these.
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 26433 of 27685, by dominusprog
You can make one using a normal pin header, remove the plastic part and bend it.
Reply 26434 of 27685, by PcBytes
Currently hunting a SCSI-Ultra160 PCI controller and asking myself why did I buy two SCSI based Quantum Atlas drives 🤣
Reply 26435 of 27685, by MJay99
You can also find them as solder anchors on Digikey:
https://www.digikey.de/de/products/detail/aav … ion/D057/524369
Reply 26436 of 27685, by PcBytes
Cleaned up my recent ECS K7S5A purchase as well as the 9600 Pro it came with.
file.php?mode=view&id=182921
file.php?mode=view&id=182922
Now, anyone remember HoneyX and Cheapmod BIOSes? 😁
Reply 26437 of 27685, by Minutemanqvs
Minutemanqvs wrote on 2024-01-14, 09:29:
All the G4XX and Parhelia cards upgraded without any issue with the Windows utility. For the old Mystique / Millennium II it's fun to see that the update utility shows the last flash date, and flashes the firmware twice. Versions were all over the place!
Reply 26438 of 27685, by DerBaum
I am investigating why some Aztech soundcards dont have a eeprom but most of them have one.
1.7 MiB
I have 3 Cards without eeprom (IC U9(11)/UX2)in my collection. So i decided to try what happens if i add an eeprom.
All Aztech cards from Generation 1 to Generation 4 use eeproms.
On generation 1-3 it holds general configuration Data to initialise itself.
For Generation 4 it holds the PNP data to be autoconfigured by the BIOS.
My EEpromless cards are generation 3 cards.
I ordered eeproms (because i got a good price i ordered a lot more then i needed)
1.45 MiB
and after that i found out that gen. 1-3 is using different eeproms as gen. 4.
Of course i ordered the wrong eeproms.
Generation 1-3 uses 24C00 16byte 2wire serial eeproms.
Generation 4 uses 93C66 512byte 3 wire eeproms.
Conclusion:
1. Sometimes i am an idiot.
2. I ordered new eeproms 😏
FCKGW-RHQQ2
Reply 26439 of 27685, by vutt
I played around with my recent purchase Logitech Soundman 16
Since I'm using ATX power only SS7 board I had to deal with -5V.
So I made for myself this contraption from UA7905C voltage regulator and surplus PicoGUS PCB I have been using for ISA bus poking.
272.47 KiB
I didn't have back in days PAS so it was my first rodeo
I have to admit PAS16 behaved very smoothly. No speed issues whatsoever on AMD K6-2@280Mhz on SIS530 chipset MB.
Games Terminal Velocity, The Secret of Monkey Island, Doom engine games, Descent, Tyrian... ...all worked fine both in PAS and Thunderboard (SB2.0) mode. Used latest PAS16 dos drivers.
Fantastic software with for installation and mixer as well.
Tested with DOS music players - Impulse tracker, Cubic player, Inertia Player all worked perfectly.
I wonder if there are dos demos supporting PAS/PAS16? Any dos demos using Midas Sound System API perhaps... ...need to do more searching because pouet.net does not seems to have PAS filter for easy searching.
