Reply 29960 of 31464, by Nexxen
Studied some DIP components. Hex inverters, bidirectional stuff...
Just to understand how signals travel through a 286 board.
I started wondering how a BIOS works. What happens, step by step, when power on occurs.
I'd really love to learn more about this.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 29961 of 31464, by zuldan
Upgraded my Windows 98 overkill machine (850XT PE) from a AMD 64 X2 6000+ (3GHz) to a AMD Phenom II X4 955 (3.2GHz). Quake 3 went from 401fps to 520fps. 3DMark99 went from 7500 to 7900. I’m sure I’ve seen benchmarks with like 20,000+ so maybe I need some sort of 3DMark99 patch?
Reply 29962 of 31464, by Joseph_Joestar
zuldan wrote on 2025-08-07, 09:57:
Yeah, that 3DMark 99 score seems way too low.
I got 41615 points on my C2D E8600 + X800 GTO rig. Full benchmarks are in this post.
My retro builds
Reply 29963 of 31464, by zuldan
Joseph_Joestar wrote on 2025-08-07, 10:23:
Very nice scores! i’m also using ATi Catalyst 6.2 reference drivers. I changed the motherboard and still getting the same score so it must be the 3DMark99 build I’m using. Do you have a link to the exact build you’re using?
Reply 29964 of 31464, by myne
It's probably because of the deprecation of 3dnow and/or a slower internal method emulating "obsolete" instructions like MMX/SSE.
Eg Iirc mmx and sse allowed 4 numbers to be operated on in parallel with olny one command to do so.
Eg "add 1 & 2, 3&4, 5&6, 7&8" would result in 3,7,11,15
If that instruction lost its optimised path, it could still exist as a valid instruction but take 4x longer (in clock cycles). Which hardly anyone would notice given the last software written for it was running on hardware at least 1/4 of the speed.
"3DMark 99 MAX is the first benchmark ever that has been optimized to fully support both Intel Pentium III SIMD and AMD 3DNow! instructions at the engine level."
I built:
Reply 29965 of 31464, by zuldan
myne wrote on 2025-08-07, 10:45:
It's probably because of the deprecation of 3dnow and/or a slower internal method emulating "obsolete" instructions like MMX/SSE […]
That makes sense. I think I’ll try 3DMark 2001 tomorrow and see if there is a major boost.
Reply 29966 of 31464, by Joseph_Joestar
zuldan wrote on 2025-08-07, 10:42:
I think I got the whole 3DMark pack from here on Vogonsdrivers, but it's been so long I can't be sure.
They are also available on the Futuremark website of course.
My retro builds
Reply 29967 of 31464, by DudeFace
the quake 3 scores look good, the 3dmark99 scores are low you probably need the patch for 3dmark99 to unlock the framerate otherwise the benchmark will be locked at 75fps, without the patch my fx5200 was scoring around 6-7000 with the patch its around 12000, the 850xt should do at least double that depending on cpu.
Reply 29968 of 31464, by zuldan
Joseph_Joestar wrote on 2025-08-07, 10:56:
Thanks for the info. I’m using the build from the 3DMark website.
Reply 29969 of 31464, by zuldan
DudeFace wrote on 2025-08-07, 11:22:
Yes my frames are limited to 75fps for each test. Wish I could find this magical 3DMark99 patch. I’ll try the Vogons 3DMark99 files Joseph linked.
Reply 29970 of 31464, by Joseph_Joestar
zuldan wrote on 2025-08-07, 11:28:
One more tip. Be sure to fully disable V-Sync in the Catalyst Control Center before performing any benchmarks. Both for Direct3D and OpenGL. Don't leave it at "Default" or "Auto" etc. Make sure it's actually turned off.
From what I recall, some earlier versions of 3DMark are affected by this. And certain OpenGL games might also report inaccurate benchmark results unless V-Sync is off in the driver panel.
My retro builds
Reply 29971 of 31464, by DarthSun
zuldan wrote on 2025-08-07, 11:30:
https://drive.google.com/file/d/1RBV2-D3E5vUk … ?usp=drive_link
The link contains all the patches for retro 3DMarks.
All of them can be configured on a modern machine. For example, 3DM99 on RyZen + QFX3500
The attachment 225621_wteondgkiajr0ecf_73144_99_cs.jpg is no longer available
Phenom-II-X2 + HD6870
The attachment 225621_zyp9vs2wgkbqr2pb_phiiwxp_3dm99_hd6870_1.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 29972 of 31464, by PTherapist
DudeFace wrote on 2025-08-05, 18:28:
nice ive been wanting a mega cd for my mega drive 1 since i was like 7yo, now 32yrs on i still dont own one. lol would also like […]
PTherapist wrote on 2025-07-28, 14:57:
Spent hours over the past couple of days trying to fix a Sega Mega CD Model 1. […]
It needed a replacement laser but no matter how much I calibrated the new laser, it wouldn't reliably read CD-R backup discs. Original discs were no problem, but CD-R was so hit and miss. Games would either not boot, or boot fine and develop glitches later. I got it to a point where it would read some backups temperamentally, then I decided to just give up and reassemble the console.
After putting everything back together I thought I'd just test it one more time - only to discover that it's now working perfectly fine and reading all discs. WTF!!!!
The only thing I can think of here is that the issue may have been RF interference between the Mega CD & the Mega Drive, which impacts the much noisier CD-R media more heavily. Though I've never seen anybody reference this as an issue before and the consensus always seemed to be that the shielding was irrelevant.
Either way, once the console is reassembled, the internal metal shielding and external shielding between the Mega CD & Mega Drive is now present. Prior to this, I was testing it out without both sets of shielding, with just the Mega Drive sitting awkwardly on top, directly above the disc drive.
Either that, or the console is just cursed. 🤣
nice ive been wanting a mega cd for my mega drive 1 since i was like 7yo, now 32yrs on i still dont own one. 🤣 would also like a multimega and a mega pc, thought looking at current prices prob should have bought them years ago, anyway the problems you've been having with the cdrs is probably down to the speed you're burning at, i had the exact same issues with my sega saturn and dreamcast cdrs, with the saturn the games would be jumpy and just not load right, i sold my saturn (this was before ode's) then found i had the same issues with dreamcast, i eventually realised it was down to burn speed,
it was 50/50 whether the console would recognise the disc or not and 50/50 if it would detect it as a game or audio cd, when the games did load they were jumpy as shit and just not working right, at first i was burning at 12x since it was the lowest my drive would do, i then found a drive that did 10x, it was better but still unplayable, i then found a drive that will do 8x and since then every disc loads no problem and plays perfectly, im also using cheap as shit discs like £3 for a 10 pack.
i know ps2 dvdrs need to be burned at 4x, xbox360 at 2.4x, or you'll end up with the same problems you mentioned, so for cdr games 8x is probably the maximum you want to go, since mega cd is older you may need to burn lower, also good luck finding a dvd drive that burns that low, you'll probably haver more luck with a cd writer.
also i heard the metal plate is to shield the megadrive from the mega cd's radiation, or shield the mega cd from the megadrives radiation i forget.
In this particular case, it's definitely the console being the issue here, rather than burn speed.
I burn discs at 4x, which is the lowest the burner I use will go. I've got several other burners that won't go lower than 10x-16x, so I'm quite lucky with this old circa-2012 Pioneer CD/DVD Writer/Blu-Ray ROM drive.
A good bit of advice if you ever decide to get a Mega CD, probably go with the Model 2 if you want minimal maintenance. If you fancy a more thorough full restoration project, get the Model 1 like I did and enjoy the pain of a lot of recapping and drive repair (even worse if you get a Model 1 with the Sony disc drive/laser, they're even worse). 🤣
Reply 29973 of 31464, by gmaverick2k
Uploaded a couple of backup/restore cd images in mdf/mds format for time computers onto the vogons library
https://www.vogonsdrivers.com/getfile.php?fil … 2&menustate=0,0
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 29974 of 31464, by pete8475
Make sure vsync is off! If the framerate counter is maxed at like 60 fps while it's running then vsync is still on.
aka pete4237.5
Reply 29975 of 31464, by DudeFace
PTherapist wrote on 2025-08-07, 15:38:
In this particular case, it's definitely the console being the issue here, rather than burn speed. […]
if you're burning at x4 then yeah its gotta be the console, you're lucky to find a drive that burns that low, a mega cd2 is probably the best for reliability, im going for nostalgia and looks over reliability so it will be a model 1 i go for also to match my megadrive 1, also hoping to find a boxed one for that new feeling, looking at prices on CeX its £375, unboxed is about £200 which is more reasonable, a boxed multimega is £850 and unboxed is still over £500, i remember they retailed for either £299 or £399, as for replacing caps thats no problem if the laser is dead ive heard about an ode option.
Reply 29976 of 31464, by zuldan
Joseph_Joestar wrote on 2025-08-07, 11:31:
Thanks Joseph and pete8475 and everyone else that responded. Silly me had v-sync on. I assumed it was off by default.
Not bad for a Windows 98 machine. Not as insane as DarthSun 98 machine, although I should be able to play a lot more older 98 games 😉
Reply 29977 of 31464, by Archer57
Saved another unremarkable AGP card from recycling:
The attachment 20250813_003557_cutD.jpg is no longer available
The attachment 4800_7300DDR2_2001se.jpg is no longer available
This one is zotac passive 7300GT. The card was a nice demonstration why passive cooling without some airflow is a bad idea - every single capacitor popped. This is the first time i had to do what people call a recap out of necessity...
Also a few missing SMD components, as usual after spending some time in scrapper's bin. And i was not sure if the GPU is alive after all the cooking, but turns out it is completely fine.
I am sure most would consider this to be a waste of time, but i just find repairing this cards fun... so why not?
Despite being DDR2 this one is quite decent, having 50Mhz higher GPU clock and 75Mhz higher memory clock than stock 7300GT should. I also like passive coolers like this, because it is possible to add a slow fan to them and the temperatures will be fantastic. This one stayed at 45C with ~1500RPM 80mm fan...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 29978 of 31464, by PcBytes
Geforce 6 and 7 have no business being passive period. Those are bumpgate era.
Reply 29979 of 31464, by DarthSun
PcBytes wrote on 2025-08-12, 22:17:
You're wrong. It's just that GeF6-7xxx is the best for retro.
