Reply 4940 of 27502, by clueless1
You're welcome to contribute to my 7-Zip benchmark databases if you wish. There's some cool stuff in there. The Windows benchmark is multi-threaded, DOS version single-threaded. Integer and memory subsystems tested separately.
Reply 4941 of 27502, by kva
I think I will need some days to dig through this site. It is amazing 😀 Then I will try to contribute when I can, don't worry 😉
Celeron Tualatin vs Celeron Conroe at equal clocks
Pentium Pro 256k vs Pentium Pro 1M vs Pentium II Overdrive!
VIA C3 vs VIA C7
My website all about old hardware
Reply 4942 of 27502, by Standard Def Steve
I hooked up my 486 to some modern audio equipment and listened to some old synth tunes. I can't believe how awesome it sounded. My DSLR's mic isn't the best, but even the recorded video doesn't sound too bad.
https://www.youtube.com/watch?v=jdFtF5XFIRs
Reply 4943 of 27502, by Tetrium
kva wrote:
I was searching for information about my dual core VIA CPU and I found this site. Now I am amazed because I finally have my plac […]
I was searching for information about my dual core VIA CPU and I found this site. Now I am amazed because I finally have my place on earth 😁
So hello to all of you my fellow retro maniacs 😁
In my collection I have about 200 CPUs (from 386 to skylake) and 50 motherboards, everything in working conditon. My favs are Cyrix/VIA and Pentium Pro. I will present them all some day 😀
Merry Christmas!
Welcome aboard! 😁
200 CPUs, nice! Now I wonder how you're storing all your stuff 😜
Seems like Vogons might be one heck of a Christmas present for you 🤣, enjoy the readings and enjoy your stay! 😁
My retro rigs (old topic)
Report spammers here!
Reply 4944 of 27502, by PhilsComputerLab
I can relax a bit now 😊
FreeDOS timed their 1.2 release for today, so I was a bit stressed preparing a video review. I "only" had release candidate 2 to test, so when 1.2 went live, I quickly tested things to see if anything had changed, it hadn't, so I could put the video review live.
Time to get some sleep 😵
YouTube, Facebook, Website
Reply 4945 of 27502, by stamasd
Merry Christmas!
I know how you feel. I had thought I was the only crazy guy on this planet to collect vintage computer stuff. I kept getting hits on web searches to this site, and found useful information on it for several years, until I realized about 2 years ago that it's actually a very active site, with really nice and knowledgeable users. That's when I decided to register, and stopped feeling like the odd duck.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 4946 of 27502, by kva
More or less like this skarby.jpg 😜
My better half is not happy about that so I have to find a better way 😉
VIA C3 vs VIA C7
Reply 4947 of 27502, by stamasd
I have more CPUs than you. But then, I also collect from earlier periods (for instance I have about 250+ 286 chips 😁)
I/O, I/O,
I/O, I/O
Reply 4948 of 27502, by Tetrium
kva wrote:
More or less like this http://kva.pl/skarby.jpg :P […]
I found that the best way is to use original CPU trays. With these you could literally stack hundreds of CPUs into a single box and it's all stable 😀
Other ways always seemed kinda lacking somehow when compared to using real CPU trays, but the trays weren't always easy to find.
s7 trays fit anything from s5 all the way to Athlon XP though, making these very versatile.
Shoe boxes are kinda nice for Slot CPUs, provided they are the right size.
It's all about making best use of the space that's provided to you 😀
Reply 4949 of 27502, by kva
I know, I have some of my CPUs in original trays. But like you said - they are not easy to find 🙁
VIA C3 vs VIA C7
Reply 4950 of 27502, by FFXIhealer
Today I benchmarked my Windows 98 machine, then swapped out the CPU and did all the same benchmarks. I've posted the results here on this forum.
CPU upgrade w/Benchmarks
Reply 4951 of 27502, by Ace
Rebuilt my Super Socket 7 hybrid PC in a new case and just finished installing Windows 98 SE on a currently "dummy" build (dummy because I'm using a 733MHz Slot 1 Pentium III when I intend to use something else) in which I plan to install a 1.4GHz Tualatin Pentium III via slotket paired with a GeForce 4 Ti4200 and 512MB of RAM on a Soyo SY-6BA+ motherboard. I actually have no idea if this motherboard will support Tualatin chips (I did update the BIOS as the AGP slot refused to work when I first got the board, which the BIOS update corrected), but if it does, there will definitely be a 1.4GHz Tualatin Pentium III in that thing. If that fails, I have some spare 1GHz Coppermine Pentium IIIs I can fall back on (these things fly on an overclocked 440BX board with a 133Mhz FSB).
Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
Reply 4952 of 27502, by stamasd
Occasionally people have CPU trays for sale on the forums at http://www.cpu-world.com Which is a site with which, if you're not familiar with already, you should be.
I/O, I/O,
I/O, I/O
Reply 4953 of 27502, by Tetrium
Been busy messing around with RTW so I can choose between 21 different temples instead of the usual 3, amongst other bits 😀
Absolutely! cpu-world is a great resource, not only for its information and great knowledge.
I got many of my harder to find CPUs from there.
Reply 4954 of 27502, by luckybob
Thanks to a few gifts from family, I'm now the proud owner of a 1080p digital camcorder. My family found out about my desire to educate you people about dual-cpu systems and were appalled when they found out I got the old VHS out of storage.
Still got to get some accessories, like a proper tripod. But hopefully soon I might have a few videos up. I fully intend to swear like a sailor on shore leave, violate your safe-space, and bask in everything violent and devious, all while dicking around with old systems. At least that is the plan.
Reply 4955 of 27502, by krivulak
About a week ago a package arrived to my home. I completely forgot about it, but the moment I opened it I knew what it was.
It was this itty bitty teeny tiny monitor - IBM 4707!
And Oh boy, I can tell you this is the nicest monitor I have ever seen! It has 9 inch picture tube and it has so sharp picture!
Every CRT display I dealt with was blurry, crappy, just not worth it so I generally got the idea that CRT displays are crap. So I moved entirely to LCDs. But now I take it back.
At first look I thought that it is yellowed a lot, but under closer inspection it was soo dirty I couldn't believe it. First power up was not great, the picture was blurry in one corner, controls were dirty and jumping around and I couldn't get the picture stable. So I cracked it open, removed all plastics and threw them all in shower and got my old toothbrush and detergent. Came out quite nicely.
While it was drying, I took apart the potentiometers. The graphite inside was quite dirty, so I cleaned brushes with a little bit of alcohol and assembled it back. The stand was squeaky and weird, so after cleaning I lubricated the base with some silicon lube and assembled everything up. Came out quite nicely, moves now great, plastics are nice and white, some dings and scratches, but I can't do anything about that. Power up?
Controls are stable, picture is clear and sharp now, it is super duper nice tiny monitor!
And what to do first with new equipment?
Of course, play my most favourite game - Commander Keen! 😀
Reply 4956 of 27502, by yawetaG
Finally managed to fix the Japanese Windows 98 install on my Epson Pentium 200, it was merely a question of running Scandisk from DOS.
Looks like the build in VGA has a bug that makes the screen move 2 cm to the left when using a resolution of 1024x768...unfortunately that is out of spec for my monitor.
Reply 4957 of 27502, by cj_reha
Oh, come on, VHS would look so much better. Dicking around on old systems WITH authentic looking footage? 200% better!
Reply 4958 of 27502, by cj_reha
Made some spreadsheets and have started logging inventory of all of my excess parts. Got most of the video cards done today, with a basic test to see if they POST. So far no dead ones 😁
Reply 4959 of 27502, by ODwilly
Debating on attempting to hack a 6pin AUX connector onto a normal power supply.
