Reply 6340 of 27581, by TheAbandonwareGuy
- Oldbie
wrote:Found the most likely cause of my 440BX mini fire. Looks like condensation buildup in the Slot 1 socket due to using canned air in a very humid environment. I usually use an air compressor for this reason, but none were available at the time. Really irks me I could be so absent minded about this and it's not exactly easy to get this exact mobo. So what I am probably going to do is just purchase an Intel Socket 370 board and just skip the whole Slotket and Slot 1 scenario now that the original mobo is a goner. Unfortunately, Gateway's motherboard port case cutouts are part of the case and not a removable panel so I will have to stick close to the Intel P-III mobo designs.
Dremel and a steel cutting bit? IO plate metal is usually pretty thin.
