Reply 7400 of 27453, by SW-SSG
wrote:Use a hairdryer to warm it?
This^ is what I ended up doing, being careful to warm the heatsink more than the CPU itself. After a while it popped off without much resistance.
It turned out to be an Athlon 64 4000+ E6, with a manufacture date of 47th week 2006... so it must have been a budget build. Single-core socket 939 in the shadow of Core 2.
wrote:Perhaps. Although in many cases the mounting mechanism limits or prevents torsional movement of the heatsink, making it impossible to twist before pulling.
wrote:That's why it's always a good idea to twist before pulling.
Indeed, this HSF is slightly wider than usual and was flush against the sides of the retention bracket. The only way out was up.
