Reply 7460 of 27443, by bjwil1991
- l33t
wrote:Noticed what could be causing my V3 3000 to artifact […]
Gave it a vinegar treatment and then a gentle scrub with soda. Still artifacting. I believe the corrosion might have eaten away at the solder enough to not make good contact.
So afterwards I proceeded to give the contacts some taps with my soldering iron, however the solder refuses to soften up (I tried it on a different chip and it melted really quick). The contacts still have that white-grey rough surface from the vinegar treatment, despite the scrubbing.
Is there a good way to clean it so my soldering iron can do the job? Should I continue scrubbing?
Use Deoxit on it. That'll get rid of the crap that's on there.
