Reply 9260 of 27674, by yawetaG
wrote:You know that nightmare where you are running down a hallway and the hallway keeps getting longer and longer? Yeah, I'm still ru […]
wrote:I’m quite interested in this because I have a couple of case covers that need a paint job. i havn’t experimented yet but getting the right paint gloss level and colour is probably key.
You know that nightmare where you are running down a hallway and the hallway keeps getting longer and longer? Yeah, I'm still running.
Cases are spray-painted. This can be seen from the haze of paint on the inside of parts, where the paint cover is not complete.
The slightly rough structure you see on some cases is an effect called "orange peel", so-called because the paint resembles the skin of an orange, and caused by using the wrong distance to the object needing painting. Some paints also have structure integrated in their formula.
Now take this from someone who has been building scale model kits for 25 years: You won't ever be able to get anything resembling the original level of gloss by applying paint with paint brushes or rollers instead of some sort of spray painting, unless you're very, very skilled at hand painting (and even then it's usually possible to see streaks).
Apply a primer suitable for metal, and sand that super smooth by using wet sanding and the proper kind of sand paper (600 grit wet-sanding and higher! what you have is waaaaay too low grit).
Apply more primer if needed, if so, repeat sanding. Paint with the right kind of paint (not wall paint), and if necessary finish off with the right kind of top coat you need for your objective (flat, semi-gloss, or gloss - for more gloss, apply more coats). Use spray cans, a wide area spray gun, or an air brush (further to the right is better). If you really want something very glossy, use Future floor wax dispensed with an air brush for the top coats (Google for exact instructions).
Try out your painting skills on pieces of scrap first. Especially getting the distance to the subject right is quite hard - for spray cans it's 25-30 cm. Another aspect of importance is temperature. If it's too cold, you'll have paint flow and adherence issues, if it's too hot the paint will dry too fast unless properly prepared (again, Google for tips).
Paint remover tip: Brake fluid will also work. Key is to keep an eye on the time it soaks.
