Reply 400 of 781, by Tiger433
And that`s photo of my ATI Rage 128 card:
1004.65 KiB
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 402 of 781, by Tiger433
And the drivers for win95 are far worse than for 98-ME, because with win95 drivers I haved blurred screen, with newer drivers screen look better. That card isn`t good beacuse of that for Win95, but is good for 98-ME and even 2000/XP. Can you test and compare first GeForce and Radeon videocards like GeForce 2MX400 or GeForce 256, Radeon 7500?
My Youtube channel
Reply 405 of 781, by PhilsComputerLab
Nopileus wrote:
I think "meh" is the expression you're looking for, great video as usual!
Ha, good idea, I might use that at some point 😀
YouTube, Facebook, Website
Reply 406 of 781, by vetz
I agree, the video is great, two thumbs up!
Though I feel the conclusion could've been better in terms of comparison with other alternatives. Yes, I know I'm nitpicking here 😊 You base the conclusion on the card itself, but you don't mention the alternatives beside on performance. If you compare it to a TNT2, the TNT2 has:
- Better drivers
- Better Direct3D support
- Better output quality in higher resolutions (for most of the cards, will vary on model and maker)
- Better performance
- Equal DOS compatibility
You do mention "look elsewhere for Windows gaming", and recommend it for DOS, which I fully agree with. But I think it could've been mentioned that you can have your cake and eat it too 😀
Reply 407 of 781, by PhilsComputerLab
Yes I try to keep it to the card at hand, but I hear you and always take things on board 😀
Reply 408 of 781, by Tiger433
Can you test that Savage4 in Gothic, even with demo of that game and compare it to Riva TNT2? I tried that game with Savage4 on PCI and ran better than on Riva TNT2 PRO on my K6-2 years ago and uses with Savage less RAM, and I haved very much problems to find driver which work with that Savage4 PCI videocard, every found driver i got BSOD`s, I remember only one driver ran normally from a few I tried.
My Youtube channel
Reply 409 of 781, by SquallStrife
Is the reverb/echo intentional?
Edit: I like that you have your formula down-pat. I haven't found my groove yet. 😒
Keep up the great work dude! 😀
Reply 410 of 781, by PhilsComputerLab
Just the way that room is, not much I can do...
I'm not going to stick to a weekly schedule anymore, sometimes a project takes me just a bit longer and I don't want to have that time pressure. Other times it just takes me a day or two 😀
So basically, I'll publish stuff when it's done 😀
Reply 411 of 781, by clueless1
When I heard the echo, my first thought was you just moved in and don't have the place fully furnished yet. Empty rooms tend to have more echo. 😀
Reply 412 of 781, by oerk
Rooms with tiles and lots of glass or generally hard surfaces too.
Phil, you could treat the room acoustically, if it bothers you...
Anyway, awesome work, as always! 😀
Reply 413 of 781, by PhilsComputerLab
Unreal S3 Savage4 MeTaL S3TC Gameplay
Looks impressive for 1998 technology.
The game skips every now and then / rubber-banding, but otherwise holds a stable frame rate of 30+ FPS.
The S3TC textures look nice, though not every texture got a facelift.
Reply 414 of 781, by PhilsComputerLab
Intel vs AMD S1E5 The Pentium 4 Extreme Edition 3.2 GHz
Extreme price, extreme performance 😀
Reply 416 of 781, by gdjacobs
Is your A64 3200+ the one with 512k L2 or 1024k L2? Furthermore, have you got something like a Clawhammer A64 3500+ which you can use to compare single and dual channel RAM with at a similar clock rate?
Reply 417 of 781, by PhilsComputerLab
The 3200+ is a ClawHammer.
Reply 418 of 781, by gdjacobs
The 3500+ is dual channel on S939. The 3200+ (or anything on S754) is not. That's why I think it'd be a cool comparison.
