Post your 'current' PC
Reply 520 of 642, by Shagittarius
My New PC:
i9 9900k @ 5Ghz w/ Corsair H150i pro 360mm AIO (Top Mounted)
2X 8GB RGB Hyper-Z DDR4-4133Mhz (Though only gotten it stable at 4000 so far)
Asus Maximus Hero XI
Nvidia RTX 2080 TI
SoundBlaster Zx
Samsung 970 Pro 512GB M.2
Samsung 840 Pro 256MB
Samsung 840 Evo 256MB
Toshiba 4TB HDD
Corsair 850Watt Gold Cert. PSU
Corsair D800 Case modified to remove hotplug backplane
Reply 522 of 642, by Shagittarius
oeuvre wrote:
How are your 9900K's power usage temps under full load?
I think it was maxing out at 72C running Prime @ 5Ghz, If I run 3 Cores at 5.0, 3 @ 4.8, and 2 at 4.7 its stays below 62C. Since all this gear is so new I'm not convinced that I've got all the power requirements dialed in as best as they could be yet, but in my opinion it runs pretty cool and I'm not sweating it. I've never even seen it run at stock, looking forward to messing with this more.
Reply 523 of 642, by buckeye
Just curious what monitor you're using with this? Nice hardware!
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 524 of 642, by Shagittarius
I'm waiting for the 144Hz Gsync HDR 32" 4K Monitors to come out then down to under 1k so currently I'm still running at 1080p @60Hz on a 40" Sony XBR-9.
Reply 525 of 642, by oeuvre
Hm, not sure what's going on with my temps... under full load (re - Prime95, max heat) I'm getting around 80-82C on my 9700K and idle in the high 20s/early 30s. Upgraded cooler to a beefy be quiet! shadow rock II rated at 180W TDP and still the same...
Reply 528 of 642, by Shagittarius
Well rest easy knowing that Prime95 is a torture test and you are unlikely to see loads approaching that ever in real world use.
My 2080TI on any modern game will run right up to 85C and then stay from around 80-82C. I think its just set up to not care until it hits that thermal level, then it throttles down which honestly when I'm currently running at 60 FPS 1080p is really not necessary. Frame limiting FTW.
Seems everything now is desgined to run right up to it's envelopes, which I guess is a good thing, no one is squirelling away performance. Maybe when we start to see 7nm they may start not pushing hardware so hard again for gains? That would be artificial though anyways, why not run full-out?
Reply 532 of 642, by GordonFreeman
Here are the specs of my current system:
i7-3770K 3.5GHz
Gigabyte GA-Z77-D3H (ver. 1.1)
16GB 1600MHz DDR3
GTX 980 Ti
128GB SSD
240GB SSD
1TB HDD
I built the first version of this system in 2010. Rather than buying or building a new PC, I've just continually upgraded this one - to the point that, now, the system is totally different except for the case and DVD drive. Some parts have been replaced multiple times; for example, it's had 4 different GPUs. Some of the parts in this system are getting old, but it's still pretty good for gaming and most other things. My current idea is that this will be the final version of this system. Once this system is no longer usable for me, I'll probably sell the entire system and then build an entirely new one.
Here's a picture of the system:
Here's the inside:
Here's my entire PC setup:
The monitor is an ASUS 27" 1440p LCD. The speakers are Bose Companion 5 computer speakers. Also on the desk is my MacBook, which is a Late-2013 Retina MacBook Pro. I also have a wireless 360 controller for this system.
Reply 534 of 642, by detritus olentus
This is my current workhorse which I have managed, with a few modifications, to get into a gateway G6-400 case in keeping with my love of the beige-box look. The Motherboard, GPU, some extra ram, and Gateway box were all "liberated" from recycle piles. PSU was a gift from a neighbor, and the hard drive was shucked from a new in box external from a thrift shop. Ended up being a pretty cheapo build and it works wonderfully for daily use.
Specs:
  • MSI X58 Pro-E
    i7 950
    8GB ram
    500GB seagate HDD
    Nvidia GeForce GTS 250
950.41 KiB
715.31 KiB
954.69 KiB
235.87 KiB
https://archive.org/details/@detritus_olentus
Philly Burbs.
Reply 535 of 642, by GordonFreeman
oeuvre wrote:
Logitech MX400? I loved those mice.
It's a Logitech M500 actually, but they look very similar. It's definitely a nice mouse. I had another one just like it that started having issues, but I liked that mouse so much that I just got another of the same model. This one has a new logo on it, though.
Reply 536 of 642, by oeuvre
AHh man that GTS250 brings me back. Really cool sleeper build right there... I love stuff like that.
Reply 537 of 642, by probnot
detritus olentus wrote:
Specs: MSI X58 Pro-E i7 950 8GB ram 500GB seagate HDD Nvidia GeForce GTS 250 […]
Specs:
MSI X58 Pro-E
i7 950
8GB ram
500GB seagate HDD
EVGA? I'm pretty sure I have that exact card in another PC. Fan had to be replaced a few years ago though.
Reply 539 of 642, by JustDavid
My current system has:
Case: Fractal Design Define R5
Cpu: 4790k@4.5ghz
CPU-Cooler: Noctua NH-D15 in dual-fan mode
RAM: 16gb DDR3 (2x8gb@2400mhz)
GPU: Gtx 1070@1964mhz
HDD: 500gb SSD and around 4TB spread out over multiple mechanical hard drives
Screen: 31.5" 1440p Gsync Screen 32GK850G-B
