Voodoo 5 6000 Clone PCB
Reply 20 of 135, by mwdmeyer
I'm waiting for my clone V4 from this guy. If it arrives and he sells a V5 6000 clone for not stupid money I will purchase!
Reply 21 of 135, by havli
This clone V5 seems to support only 5V PCI. Which will limit the performance quite a bit as you won't be able to run it in 3.3V PCI-X boards as 66 MHz PCI device.
Reply 23 of 135, by aaronkatrini
I'm no expert by any means and I don't want to put bad name to the project, but I have my doubts about this...
1. Why PCI? it would be way limited in comparison to AGP 2x.
2. Why the card has a secondary male VGA connector? Reminds me of Vooodoo 1 or the Voodoo 2, where those were only 3D accelerators, but VSA100 chips can handle 2D just fine.
3. Why no evidence of the card in use?
It kinda reminds me of the Bitchin' Fast Voodoo 5 9000 Project, that one was an excellent prank from a fellow Vogons member, hope this one isn't just a way to scam people of their money.
Again, I want to clear that I don't want to start any drama or start a conspiracy theory, just want to make sure the project is legit before people start sending money. 😀
Reply 24 of 135, by anthony
It is pci because it too slow for d3d and later opengl and intended to be used in conjunction with another powerful accelerator. Thats why it has Vga in. What evidence you’re expecting, that card 2 days old and it not available for orders now.
Reply 25 of 135, by The Serpent Rider
So, price will be $1500 or around that.
Oh well, at least it's just one RTX3090 =)
BTW do you have plans to increase VRAM capacity per chip to 64 Mb?
Reply 26 of 135, by havli
anthony wrote on 2021-02-18, 15:55:
I understand the PCI interface (after all, the original V5 6k was also just PCI66 ~ AGP 1x). But why not make it 3.3V / 66 MHz compatible? Does the pci-pci bridge support it?
Reply 27 of 135, by anthony
64 mb per chip config is buggy. If i’ll find convenient way to switch memory configurations maybe i’ll implement such feature In future.
No problem in 66mhz pci support if bc-66 bridge chip is used. This card already able to operate at such clock by isolating certain contacts.
Reply 29 of 135, by red-ray
anthony wrote on 2021-02-18, 13:48:
Hello, guys, appreciate your interest to my recent project. If you have any questions don’t hesitate to ask.
I noticed the four fans report their speed and wonder if it's possible to read this with software? If so I will update my SIV utility to do this if you can tell me where to read the speeds from.
Last time a checked SIV did OK on a 6000 and I would be interested to know if it reports your card OK.
    97.06 KiB
Reply 32 of 135, by erek
this went viral,
https://hothardware.com/news/3dfx-voodoo-5-60 … husiast-vsa-100
https://www.tomshardware.com/news/3dfx-voodoo … etter-than-ever
https://www.guru3d.com/news-story/3dfx-voodoo … enthusiast.html
https://hexus.net/tech/news/graphics/147447-3 … se-engineering/
https://www.tweaktown.com/news/67383/legendar … oard/index.html
Reply 33 of 135, by Ozzuneoj
Crazy. I can't imagine how much work that must have been. Looks very cool though.
Now reverse engineer (and finish) the Rampage! 🤪
Reply 34 of 135, by imi
erek wrote on 2021-02-20, 00:52:
"You can see a move from AGP to PCIe Express, the added benefit from using PCI Express is that it can feed 75 Watts, no longer an external power supply was needed. below I added a photo of an original Voodoo 5 6000, that's the one with the brick 😀"
🤣, some of their writing staff seems to be quite young x3
Reply 36 of 135, by anthony
red-ray wrote on 2021-02-19, 14:03:
All v4 and v5 cards have gpio2 routed to fan speed sensor, take a look at vidserialparallel register in vsa100 manual. Problem is, you can read only first chip, i may be wrong thou. But on that particular card i had intention to use this gpio for an other purpose (vsa100 has only one input gpio)
Not tested your util so far, but highly likely that it’ll report my card absolutely the same way as v56.
Reply 37 of 135, by anthony
386SX wrote on 2021-02-19, 16:48:
Interesting and impressive project. Some questions for curiousity, is the PLX chip acting like the Hint chip did or they are completely different logics? How many watts the card requires from the PSU?
Plx is rebranded hint, same manufacturer. It sucks about 5 amps at max from the 12v line
Reply 38 of 135, by Ozzuneoj
imi wrote on 2021-02-20, 01:43:
Yeah I saw this too. Every time I see a post about something "retro" on one of the big tech sites, I feel older and older. The people writing the articles may not have even been ALIVE when this stuff happened. This is like if I were writing a professional article about the release of the IBM PC... but trying to apply my "modern" knowledge to it, authoritatively, without bothering to fact check.... and getting paid to do it. 🤣
