Mouse copy/paste support
Reply 40 of 151, by truth_deleted
Since the clipboard patch requires a 3rd party library, it may be worthwhile to detect that library by the method in a previous post in this thread (edit to the configure.ac file). However, I didn't test it outside mingw. Also, before running configure it would be necessary to run "autogen.sh" (or the analog in VS).
In addition, the above could be accompanied by preprocessor directives so that the patch code is only compiled when the proper library is present:
#if C_CLIPBOARD
// Clipboard code
#endif
Reply 41 of 151, by Wengier
truth5678 wrote:
Since the clipboard patch requires a 3rd party library, it may be worthwhile to detect that library by the method in a previous […]
#if C_CLIPBOARD
// Clipboard code
#endif
I have added preprocessor directives to the source files related to the clipboard. Source files related to this feature have been zipped and attached. I have also attached in diff format.
    srcchgs.zip
    44.83 KiB
    59 downloads
    patch.diff
    59.69 KiB
    63 downloads
Reply 43 of 151, by emendelson
On OS X, using a build script supplied by Dominus some years ago, I can build DOSBox with Wengier's new copy/paste code, but I can't figure out how to get the curses library integrated, so the copy/paste function doesn't work.
This is probably the result of my ignorance, so I'll be grateful for any help. I tried compiling PDCurses, but it needs X on the system, and X isn't installed on recent OS X systems. I wasn't able to compile Ncurses, which may be the way to go. Has anyone got any further with this?
Reply 44 of 151, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
In the makefile you need to add pdcurses libs a file, but that doesn't matter if it doesn't compile.
Download and install xquartz maybe it will compile with that.
BUT if x is needed for the copy/paste you are not much better off than with gtk ;(
AND you will find yourself in OS X' dll hell if you want to maje your build available ;(
I haven't had time to test this myself yet...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 45 of 151, by emendelson
That's what I was afraid of...! I'm trying to avoid installing xquartz in my main system, in order to stop myself from distributing anything that needs it on the user's system. I'll try to experiment on a VMware setup later on, but will glad to know what you find out when you get a chance to try it.
Reply 46 of 151, by Wengier
I have re-checked the officially supported platforms of PDCurses, which are DOS, OS/2, Win32, X11 and SDL. Probably you should use PDCurses-SDL instead of PDCurses-X11 on Mac OS X. I don't have OS X to test it personally though.
Reply 48 of 151, by emendelson
I've tried to compile the sdl version of pdcurses under OS X, but get an error message about not finding sdl.h. I've installed sdl-config via Macports, but it didn't help. I hope someone who knows what he or she is doing (as I don't) might be able to help, but I'll keep trying in the meantime.
Reply 49 of 151, by Wengier
Maybe try some links relating to the sdl.h not found error below?
http://stackoverflow.com/questions/20277477/h … k-folder-in-mac
http://stackoverflow.com/questions/9350375/er … le-or-directory
http://www.linuxquestions.org/questions/progr … s-there-133384/
Reply 50 of 151, by Wengier
For people who prefer a different color style for the mouse selection, I have attached the Windows binary (along with all required DLLs, zipped), and the updated mouse.cpp file.
    dosbox.zip
    1.76 MiB
    68 downloads
    mouse.cpp
    32.78 KiB
    63 downloads
Reply 51 of 151, by emendelson
Wengier wrote:
Maybe try some links relating to the sdl.h not found error below? […]
Thank you, Wengier! I should have figured that out for myself, but I didn't. In my case, because I installed SDL via MacPorts, the command line I needed to use was this:
make -I/opt/local/include/SDL/ -lSDL
Now I have to figure out how to get libpdcurses.a built into DOSBox under OS X...
EDIT: I've attached a copy of libpdcurses.a compiled under Mavericks.
    libpdcurses.a.zip
    62.5 KiB
    59 downloads
Reply 52 of 151, by Wengier
emendelson wrote:
Thank you, Wengier! I should have figured that out for myself, but I didn't. In my case, because I installed SDL via MacPorts, t […]
For getting libpdcurses built into DOSBox, have you tried the method in truth5678's earlier post that makes change to the configure file and my earlier post that adds the preprocessor directive?
Reply 53 of 151, by emendelson
Hello Wengier,
I've tried both techniques, but I don't seem to have the syntax correct for modifying the makefile to add libpdcurses.a.
The real expert in this is Dominus, and I'll hope that he'll have time to think about this before long. I'm simply stumbling around, and everything I know about building DOSBox on the Mac is what Dominus told me earlier...
Meanwhile, Wengier, thank you again for your generosity with help and with these terrific patches.
Reply 55 of 151, by emendelson
I tried both methods, but without success. The OS X build seems to require a set of interlocking kludges that Dominus worked out, and since he understands these things (I don't), I'll hope he gives it a try someday.
Reply 57 of 151, by emendelson
OK, please keep in mind that I don't know what I'm doing, and that so far, I have done only what Dominus told me to do, using a build script based on his suggestions. In trying to apply the CopyPaste patch, I did the following:
1. Starting with current SVN, I substituted all of Wengier's "srschanges" files for the SVN files.
2. I built libpcurses.a following suggestions in Wengier's earlier message.
3. I modified the build script that Dominus helped me put together by making these two changes: I added --enable-clipboard to the configure line and added the references to libpdcurses.a to the sed lines that modify the makefiles.
The build script I use is completely non-portable, because it refers to directories on my system. But, thanks to Dominus, it works when building SVN. I've attached it here.
By the way, the reason my script has all these complicated additions is that I want to build an executable that can be used on other people's systems, not only my own, so various libraries have to be built in.
Reply 59 of 151, by truth_deleted
I don't see where you submitted the library name to the linker: -lpdcurses. Also, did you ensure that curses.h was copied to /opt/local/include?
Did you inspect the config.log file to see if curses.h and pdcurses were detected? This assumes that the configure script was formatted properly for pdcurses detection in osx.
Edit: I inadvertently posted this after Wengier's post. His request for an error message would answer the 2nd question above.
