Best way to create ISO+OGG images?
Reply 20 of 32, by Stiletto
Neville wrote:
Sorry about that. I thought that being a freeware program all would be OK. Is it OK if I provide a link to another website carrying the program instead?
If it really/truly doesn't have any viruses, and was freeware, it's fine to link.
do the Fandango!" - Queen
Stiletto
Reply 23 of 32, by pantercat
I've written a small bash script that extracts the data track to iso, the audio tracks to wav, converts the wav files to ogg files and generates the cue file. It should work on any linux distro with bchunk and vorbis-tools packages installed.
#!/bin/bash
# isoogg.sh v0.3
# Usage: ./isoogg.sh file.bin file.cue
die() {
echo -e "$@"
exit 1
which /usr/bin/bchunk &>/dev/null || die "\nbchunk not found. Try: (as root) apt-get install bchunk\n"
which /usr/bin/oggenc &>/dev/null || die "\noggenc not found. Try: (as root) apt-get install vorbis-tools\n"
SELF=$(basename $0)
[ "$#" -ne 2 ] && die "\nUsage: $SELF [BIN_file] [CUE_file]\n"
BIN_FILE="$1"
CUE_FILE="$2"
NO_EXT="$(echo "$1" |sed 's/\.[^\.]*$//')"
[ ! -f "$BIN_FILE" ] && die "\n$BIN_FILE not found."
[ ! -f "$CUE_FILE" ] && die "\n$CUE_FILE not found."
grep "2 AUDIO" "$CUE_FILE" &>/dev/null || die "\n$BIN_FILE do not have audio tracks."
egrep -ie "FILE .* MP3|OGG|OPUS|FLAC" "$CUE_FILE" &>/dev/null && die "\n$CUE_FILE already have compressed audio tracks."
[ -f "$NO_EXT".iso ] && die "\n$NO_EXT.iso already exists"
/usr/bin/bchunk -w "$BIN_FILE" "$CUE_FILE" "$NO_EXT"
[ -f "$NO_EXT"01.iso ] && mv "$NO_EXT"01.iso "$NO_EXT".iso
[ -f "$NO_EXT"01.ugh ] && echo -e "\nWarning: File $BIN_FILE is really an ISO-9660." && mv "$NO_EXT"01.ugh "$NO_EXT".iso
[ ! -f "$CUE_FILE".bak ] && mv "$CUE_FILE" "$CUE_FILE".bak
echo "FILE \""$NO_EXT".iso\" BINARY" >"$CUE_FILE"
echo " TRACK 01 MODE1/2048" >>"$CUE_FILE"
echo " INDEX 01 00:00:00" >>"$CUE_FILE"
for FN in *.wav; do
/usr/bin/oggenc "$FN" -q 6 -o "${FN%.wav}.ogg"
rm "$FN"
done
i=2
for FN in *.ogg; do
echo "FILE \"$FN\" MP3" >>"$CUE_FILE"
(("$i" < 10)) && echo " TRACK 0$i AUDIO" >>"$CUE_FILE" || echo " TRACK $i AUDIO" >>"$CUE_FILE"
echo "$FN" |grep "02.ogg$" &>/dev/null && echo " PREGAP 00:02:00" >>"$CUE_FILE"
((i++))
done
echo "The $BIN_FILE and $CUE_FILE.bak files are no longer needed. You can delete them."
echo "Copy the files $NO_EXT.iso $CUE_FILE and *.ogg to the game directory and mount $CUE_FILE"
#rm "$BIN_FILE"
#rm "$CUE_FILE".bak
Reply 25 of 32, by pantercat
Yes. Well, this is not optimal, it would be advisable to do something similar in powershell (or a GUI) but it can be done and it works. I have made some small changes to the script to work in windows with win-bash.
Download and extract.
Copy the BIN and CUE files to the same folder where isoogg_win.7z has been extracted
Double click on start_shell.bat
Should open a window with a bash shell
Now type:
or
./isoogg.sh "file with spaces.bin" "with spaces.cue"
Wait ~ 1 minute and if the bin file has audio tracks we will have in the same folder file.iso, file.cue and *.ogg
I've tested it on Windows 7 Pro SP1 x64
Alternatively you can copy only isoogg.sh from download above and get the rest of the files from the original sources. You'll need these files:
https://ftp.osuosl.org/pub/xiph/releases/vorb … ls-win32-bin.7z
*.dll
oggenc.exe
https://github.com/extramaster/bchunk/release … 2.1_repub.1.zip
bchunk.exe
https://sourceforge.net/projects/win-bash/fil … latest/download
*.dll
bash.exe
echo.exe
grep.exe
ls.exe
mv.exe
rm.exe
sed.exe
start_shell.bat
Reply 26 of 32, by collector
A few years back I started writing a tool that was a frontend for CDRTools that could could rip/compress CDA tracks and make ISOs of CDs, and generate/edit CUE sheets for DOSBox. It was also a simple frontend for DOSBox. I gave it up since there was not much interest in it.
102.87 KiB
40.76 KiB
36.52 KiB
Reply 27 of 32, by olddos25
Well, you should continue it in some form or another. It has the potential to be pretty useful!
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Reply 28 of 32, by MKSheppard
pantercat wrote on 2018-09-07, 11:18:
Yes. Well, this is not optimal, it would be advisable to do something similar in powershell (or a GUI) but it can be done and it […]
Now type:
or
I've tested it on Windows 10 x64, with whatever was the current version in August 2020 and it works.
I'll rehost your file on my website later, if that's OK with you, so people don't have to go to ad-infested download sites.
Reply 30 of 32, by Akuma
pantercat wrote on 2020-10-17, 16:48:
Sure, do whatever you want with the code.
I'm glad it's useful to you. 😀
Do you want to check out mine 😉 ?
BIN/CUE to ISO/CUE converter v1.09, supports : FLAC,MP3,OGG,OPUS (script)
Reply 32 of 32, by Akuma
pantercat wrote on 2020-10-23, 18:40:
Well done! :D […]
Well done! 😁
Since you have asked, I would say
Consider implementing things when you actually need them.
Keep it simple. 😉
Unfortunately I keep running into them, and that complicates things.
Thanks for the support 😁
