Reply 40 of 86, by lazibayer
infiniteclouds wrote:
This is that chip from the bottom left --
Thanks. I can't find the datasheet for W48S87-27AH but I did find W48S87-27A and W127/W127-A. The former does have 60MHz and 90MHz settings but it lacks 95 and 124, so it's not the same as yours. The latter is an updated version of the former but it only has the 8 frequencies you listed above:
52.36 KiB
Not sure if the combinations can match the jumper settings on your boards manual. Interestingly it uses 2/3 and 1/3 divider for AGP and PCI at 83MHz.
All three chips have 48 pins, so I reckon it's unlikely for yours to have any hidden combinations.
Reply 41 of 86, by infiniteclouds
They do match -- page 30: http://www.philscomputerlab.com/uploads/3/7/2 … x59pro-ol-e.pdf
That's a shame -- I was hoping for 50FSB -- as even some Slot 1's can do this. Thanks for checking in any case!
Reply 42 of 86, by gdjacobs
The W127 PLL is used in other (presumably later) versions of the AX59 Pro. I suspect it's a complete drop-in replacement for the -27AH.
Reply 43 of 86, by lazibayer
No problem! Thanks for contributing to this thread 😁
Reply 46 of 86, by lazibayer
Stolen from
Kamerat wrote:
The Gigabyte GA-6EM have a clock generator capable of 33MHz FSB, the PLL52C66-05. You might have to modify the board to get access to the lowest clocks.
It goes from 33MHz all the way up to 100MHz.
Reply 53 of 86, by Kamerat
ExpertColor TX531
9148BF-04
I wonder if there's another revision of the board as the 55MHz FSB setting in the manual gives 83,3MHz with 33,3MHz PCI.
YouTube channel
Reply 55 of 86, by lazibayer
Got my hands on a FIC PA-2011 Rev. 2.5. Apparently the board's design included 6 models of clock generators and FIC decided to print all of their settings on the board. Mine has W48C67-01H on it, and besides the 4 printed ones, I tested the following settings:
CLK1 CLK2 CLK3 Freq
1-2 1-2 2-3 68
2-3 1-2 2-3 60
1-2 2-3 2-3 no boot
2-3 2-3 2-3 no boot
The other 5 models are:
IMI671
CY2277
W48C67-71
IMI652
ICS9147-01
    379.61 KiB
Reply 56 of 86, by Auzner
Found another IC I didn't see mentioned here:
MCNIX (Macronix International) MX8325-1
On a LS-486e rev D socket 3 labeled "MX8325MC"
http://pdf.dzsc.com/88889/9931.pdf
83.55 KiB
Reply 58 of 86, by lazibayer
TULIP 486 DC/DT (TC38)
Interesting board. No explicit jumper for bus speed and the clock generator, ICD2023SC-2, is theoretically capable of "jumper-free overclocking".
Re: Need help identifying cache on 486 Motherboard
Reply 59 of 86, by lazibayer
A 430VX board with Model Code No. 35832003
Link to the board's manual: http://support.pcpartner.com/support/man/intel/832003.pdf
Link to the original discussion: Subtle differences between Cyrix and IBM 6x86s
Clock generator: IMI SC653DYB
71.03 KiB
The board has documented two jumpers JP41 and JP42 that control the inputs on the S0 and S1 pins, and the reserved JP45 controls the input on the S2 pin.
