Reply 20 of 26, by chrisNova777
hahaha
check out this funky flash intro from back in the day
http://web.archive.org/web/20000622003848/htt … undblaster.com/
http://web.archive.org/web/20000815210240/htt … sbliveplatinum/
ok this kind of solidifies it
http://web.archive.org/web/20000826211348/htt … um/software.asp
it says right there highlighted in red
CuBasis VST
By integrating audio and MIDI recordings, CuBasis VST effortlessly turns your PC into a complete recording studio. Its simple MIDI interface allows you to connect any combination of MIDI keyboards and MIDI sound modules. CuBasis VST also prints your MIDI parts as notes, with text and titles.
Note:This software is only included in products sold in Europe.
so my suspicion was correct.. at least by the time they replaced Cubasis AV with Cubasis VST...
i guess i can assume that they probably did it that way from the start... ?
heres the original page from web archive of the steinberg us site, archived in 1998:
http://web.archive.org/web/19980213230539/htt … asis/index.html
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
Reply 21 of 26, by chrisNova777
http://www.activemusician.com/Steinberg-to-Bu … rope--t101i4274
not surprising that it was also bundled with the emu APS which uses the same Emu10k chip as the sblive!
Reply 22 of 26, by chrisNova777
http://www.mediafire.com/download/g2b5bu1c3gv … ubasis_AV.toast
if anyone wants a copy of this old disc i finally tracked it down
Reply 23 of 26, by chrisNova777
confirmed working on XP 32bit with "Win98 compatibility" enabled
    68.22 KiB
    19.99 KiB
    5.05 KiB
    75.54 KiB
    30.53 KiB
Reply 24 of 26, by chrisNova777
🤣.. zero interest... 😀
Reply 25 of 26, by calvin
Amusingly, it's 16-bit, well into 1998.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
Reply 26 of 26, by autoexecdotbat
hay,
Can I at least have the soft karaoke folder in the appliactions cd? I've been triing to find that for years!
to win the game you must defeat coppa!
http://chng.it/DNc2L8LvLJ
