EZ-Drive Dynamic Drive Overlay
Getting old software/games running on older hardware.
Re: EZ-Drive Dynamic Drive Overlay
Postby manuelink64 » 2016-5-29 @ 01:15
Hi guys!
in my entire life (33yo), I never did try to put a bigger disk in a old system, recently, a great
friend of mine gave me a Unisys PW2 (486), with the 504mb hdd limit.
I followed this guide succesfully, I put a 8.4GB Seagate HDD on a 486!! :-D ,
but....
for some weird reason, the system clone the 4 partitions/units C:,D:,E:,F: endlessly to Z:
I tried to limit this, writing LASTDRIVE=F on CONFIG.SYS with no success :depressed:
Please, any help for this poor guy.
Regards!
[Unisys CWP] [CPU] AMD-X5-133ADZ [RAM] 64 MB (4x36) FPM [HDD] Seagate 8.4GB [Audio] SB16 SCSI 2 (CT1770) [Video] ATI Mach64VT2 [OS] Windows 95 OSR2.5
User avatar
manuelink64
Postby xboingx » 2016-8-11 @ 08:00
Hi guys, I have a question regarding EZ-Drive. I have it installed on my Quantum bigfoot as I was using the HDD in older system. Now I have it installed in a system that can cope and I decided to make the MS DOS a slave to dual boot with Windows 95. The Idea is to put Windows HDD in a removable case set as primary master and plug it in only when I want to boot Windows. The dos disk is supposed to be moved to primary slave. However after I change the disk to primary slave the ez-drive does not detect the system (no system dis or disk error). I tried to disable ex-bios but than the system hangs right after writing Starting MS-DOS.
So I would like to ask if uninstalling EZ-drive will erase all my data or will the system be intact and in bootable state just without the ez-bios? I cannot find any information about this. Can MS DOS 6.22 even start from primary slave if it is the only HDD in the system?
xboingx
Postby xboingx » 2016-8-12 @ 11:47
To answery my own question, yes uninstalling EZ-BIOS does not remove data.
xboingx
Postby loktar » 2016-11-28 @ 06:46
manuelink64 wrote:Hi guys!
but....
Regards!
You ever figure this out.. I actually am running into the same issue. Pretty sure it's due to a limit on the size of the media, trying to use a 16gb minisd... getting smaller than that at the store is actually quite hard lol. I wouldn't care however the issue is I can't install a CD drive since there aren't enough drive letters available :/
**edit** Yeah just threw a CF card adapter and a 1gb card and it worked fine wonder what the limit of the software is. I'll probably purchase a 4 and 8gb mini sd off of amazon to test.
User avatar
loktar
Postby maverick85 » 2016-12-22 @ 11:16
PhilsComputerLab wrote:
philscomputerlab wrote:I couldn't find anything newer from Western Digital however. Specifically with FAT32 support, so if someone knows about a newer version than 9.03W please let me know.
Found one :)
It's Western Digital's Data Lifeguard Tools 11.2.
Also based on the same 2004 Ontrack as Seagate's DiscWizard.
Uses just one floppy, but also has a few less options.
But the main features are identical:
- FAT16 and FAT32 supprt
- Boot from CD-ROM on machines that don't support it
- Uses 10 KB more memory compared to EZ-Drive
- Very nice graphical user interface
- Needs 16 MB RAM to load
Just like Seagate's DiscWizard it happily works with CF cards but not with drives from other manufacturers.
i'm at wits end trying to install windows 95 on my 60gb hard drive for my toshiba 400CDT with 75MHz pentium cpu and 16MB ram.....
done all the tricks, ez/-drive, odd etc, trying to boot from cd rom drive and install win95 to no avail. dont want to install win98. i use win98 startup disk to get cd rom support, formateed drives dissapear then 504MB limit appears again
windows 95 is not bootable which is a pain in the a**
TOSHIBA 400CDT
Win95/DOS laptop
User avatar
maverick85
Postby maverick85 » 2016-12-22 @ 14:02
finally got it working. now have 8 drives 2gb each (could've partitioned more) and have windows 95 installed and running ;)
TOSHIBA 400CDT
Win95/DOS laptop
User avatar
maverick85
Postby adultlunchables » 2017-1-08 @ 04:40
I'm have the same problem a couple other people are having, the software duplicates drive letters and I can't install the CD-ROM drive because all the drive letters are taken. With that being said though, if I go through the process of formatting 4 partitions and then UNINSTALL ezdrive, I'm left with 1 good 2gb partition and no duplicate drive letters... which is very nice because 1) EZ drive is not installed at all and 2) it's 4x bigger than the 500mb I used to have.
adultlunchables
Postby UltimaPlayer12 » 2017-1-21 @ 16:10
I don't know what version of EZ-Drive you guys have in comparison to this, but I found a floppy while digging through my dad's old files that shipped with his WD drive. This one claims to support FAT32, so maybe it could be of use to you all. I made the dump with WinImage, so if you want to write it to a floppy you should be able to with that or any other floppy writer supporting the .ima format.
https://drive.google.com/open?id=0B45uj ... TBjNFUyU1k
The Beast 2.0:
CPU: AMD K6-III 450MHz GPU: Nvidia FX 5600 128MB HDD: 20GB (Seagate?) Mobo: ASUS P5A-B RAM: 512MB Sound Card: SB 16 PnP ISA OS: Windows 98 SE
UltimaPlayer12
Postby manuelink64 » 2017-1-21 @ 23:38
UltimaPlayer12 wrote:I don't know what version of EZ-Drive you guys have in comparison to this, but I found a floppy while digging through my dad's old files that shipped with his WD drive. This one claims to support FAT32, so maybe it could be of use to you all. I made the dump with WinImage, so if you want to write it to a floppy you should be able to with that or any other floppy writer supporting the .ima format.
Phil's version are 9.03W (in the youtube video)
but in his website, is the same version as you, 9.06W
thanks anyways :lol:
User avatar
manuelink64
Postby UltimaPlayer12 » 2017-1-21 @ 23:47
Ah okay, well I'll leave that up as an alternate mirror until it gets taken down automatically or the bandwidth limit is exceeded :lol: sorry to waste your time guys
The Beast 2.0:
UltimaPlayer12
Postby bluejeans » 2017-6-09 @ 12:25
Has anyone had this running with drives over 160gb? And how about when using a sata-ide adapter? Only ide drives I have are 320gb and 500, but plenty of satas that are 80.
bluejeans
Postby NJRoadfan » 2017-6-11 @ 17:40
Its doubtful a 48-bit LBA compatible version of EZ-Drive was released. Whatever is out there likely works on drives up to 137GB. Ontrack's Disk Manager might have gotten a 48-bit LBA revision though.
NJRoadfan
Postby weldum » 2017-6-16 @ 18:18
Hi, I have an old 386SX laptop, that currently has an 80MB hdd. I want to change it for a 4GB Compact Flash, have the adaptor but can't install EZ-Drive due to not having floppy disks.
Is there any way to install it without floppy?
Ohh, the humanity :depressed:
386SX 25-C3 800-P3 900-Atom 1.6-C-D 2.13-P4 2.26-P4HT 3.0-P-DC 1.6-AFX 2.6-FX 3.3
User avatar
weldum
Postby Azarien » 2017-6-17 @ 07:00
You could try doing it under vmware/virtualbox machine that would have access to physical CF card (and virtual floppy).
Azarien
Postby weldum » 2017-6-19 @ 04:49
i've tried with virtualpc, virtualbox and vmware, can't mount the physical drive.
nevermind, i've bought some new floppy disks and see what happens
User avatar
weldum
Postby Caluser2000 » 2018-4-30 @ 03:29
I found this link with older DDO software on it http://vintage-pc.tripod.com/hdd_utils.html Might be useful the someone.
User avatar
Caluser2000
Postby ozzmosis » 2018-12-06 @ 09:10
Responding to an old message here, but:
NJRoadfan wrote:-They change the partition type of the drive to prevent any other machines from accessing the contents of the drive. This used to not be a problem in the Windows 9x days as you could kick start a machine with an EZDrive or Ontrack equipped floppy, but its not possible with Windows NT based OSes. This eliminates the convenience of popping a CF card into a reader on a modern machine. Also in many cases, one might inadvertently format a drive with data on it thinking its blank.
I'll probably start a separate thread on this, but if my experience with Ontrack Disk Manager is any guide, it's not difficult to mount a CF card that has a drive overlay installed using any Linux PC and a CF card reader. (The same applies if using a modern large IDE drive and a USB adapter.)
The "mount" command for VFAT in Linux supports an offset, which in my case was 0xFC00 (64512), where the MS-DOS 5.0 boot sector is located.
So in Ubuntu, the full command to mount the CF card of my Compaq Portable II is:
sudo mount -t vfat -o offset=64512,noexec,rw,umask=0000 /dev/sdx /mnt
Where /dev/sdx is my card reader (/dev/sdd in my case).
ozzmosis
Previous
Return to Software
Who is online
Users browsing this forum: No registered users and 2 guests
