Reply 1320 of 3172, by hard1k
shock__ wrote:
MIDITXD and MIDIRXD via headers, while the joystick stuff can be left as is? Sure, why not.
Great, thanks!
Yes, only these 2 traces, reserved for possible future use - soldered in by default (so that the MIDITXD and MIDIRXD go to the InterWave), but with the possibility to solder a header, break into them and alter the routing.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 1321 of 3172, by hard1k
shock__ wrote:
EDIT: From the InterWave or DSUB?
In between 😀
4 holes (2 per each trace). The suggested aim is that a daughterboard could connect to the pair that goes to DSUB, breaking into the traces (thus leaving the corresponding signals from the InterWave as dead ends).
EDIT: in the picture DB means DSUB.
    3.29 KiB
AWE64 Legacy
Reply 1322 of 3172, by hard1k
And another minor thing to correct 😀 Please forgive my being so perfectionist 😁
In the text regarding prototyping stuff the preposition "on" should be replaced with "at":
https://ell.stackexchange.com/questions/13918 … n-your-own-risk
AWE64 Legacy
Reply 1323 of 3172, by shock__
fixed
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 1324 of 3172, by shock__
hard1k wrote:
In between :) 4 holes (2 per each trace). The suggested aim is that a daughterboard could connect to the pair that goes to DSUB, […]
In between 😀
https://i.imgur.com/OdGzpKK.jpg Hope that is alright, because I'm certainly not going there again!
[Z?]
Reply 1326 of 3172, by shock__
640K!enough wrote:
Would it be a relatively simple matter to bring RAHLD# down to an unused pin of X3?
Probably not relatively simple, but certainly possible.
[Z?]
Reply 1327 of 3172, by hard1k
Absolutely!
Another thing - is it possible to drill some hole(s) - at least one - for the plastic standoff(s) for DB mounting?
AWE64 Legacy
Reply 1328 of 3172, by hard1k
Question (a bit early one I guess, but just before I forgot) - what would be the convention for serial number distribution? RND? Alphabetical order of contributors? If it's the latter, I'm 7th (with shock__ as the # 0, I guess), so S/N 007, totally fine with that 😁
AWE64 Legacy
Reply 1329 of 3172, by wbc
hm, what about placing pins from Interwave and connector sides near each own and using jumpers instead of 0-ohm resistors to route MIDI to DB15 if daugtherboard card is not installed?
--wbcbz7
Reply 1330 of 3172, by shock__
!RAHLD added to X3
Serial numbers will be drawn randomly, also I'll likely choose a system where people can't fight over who has the lowest.
Standoffs ... not really. Are there any standard ones that are easily obtainable? Also the huge X1/X2 connectors should provide enough structural integrity, along with the fact that the electrolytic capacitors will likely act as standoffs anyway (at least in the analog part of the card) ... depending on the design of the daughterboard.
WBC: those aren't 0-Ohm resistors. Also as of now all pinheaders (except for P54/MPC) are fully optional, meaning that all actual configuration is done by solder jumpers (which is something I'd like to keep that way). If people want to build their cards in a fashion that they're only fully operational combined with a daughterboard, I'm beyond the point where I care anymore. I could of course add even more headers or actual plug-jumpers, but would prefer to keep the card from becoming a jumper graveyard. Keep in mind, this card is supposed to be 100% compatible with the original GUS PnP - including all shortcomings like the lack of good Soundblaster support or a useful MIDI interface.
The only exception in that regard is the awesome and largely appreciated effort by 640K!enough regarding the development of an extended ROM module - primary due to the copyright situation and secondary due to the effort he already has delivered at this point.
This will also be the last time I'll respond to _any_ requests regarding additional headers/breakouts for this prototype, unless related to the ROM circuit.
[Z?]
Reply 1331 of 3172, by hard1k
Just googled - those standoffs/spacers were much easier to find 2-3 years ago than nowadays. OK, nevermind then 😀
And many thanks for implementing all other last minutes changes you received from us! The MIDITXD/RXD header is just fine as it is, no need in changing it. Anyone who designs a possible daughterboard will be able to adapt it to the current design, so no problem here.
AWE64 Legacy
Reply 1332 of 3172, by 640K!enough
You will get no more change requests from me before the prototype run. Of course, I already have every memory-related signal available, short of KITCHEN_SINK#, so you would hope I have what I need.
Reply 1333 of 3172, by shock__
Currently there'd be 3 people interested in a prototype (that is including me) ... is interest seriously that low?
[Z?]
Reply 1334 of 3172, by MrTentacleGuy
I'm sure there are just people who don't feel like they could contribute to testing. I'm still interested in the card, but I'm not sure what I could add to the process.
Reply 1335 of 3172, by cyclone3d
I guess I'd be up for a prototype. Not exactly sure what I could contribute other than testing different things to makes sure it works as expected though.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1336 of 3172, by keropi
I am also interested in a prototype - I just didn't think it was time yet to send a PM ... so make the cards 4 😀
It will also allow me to gauge the time that is needed to build one - main IC will come pre-soldered nothing changed there correct?
Reply 1337 of 3172, by shock__
Yup, InterWave will come presoldered, unless you absolutely insist on soldering it yourself.
[Z?]
Reply 1338 of 3172, by the Goat
I am greatly interested in the project overall. But I'm not confident I would be able to assist in a meaningful way in the time provided. I'm certainly in for the eventual production version.
Reply 1339 of 3172, by kanecvr
Also interested in the card, and I have the soldering skills and equipment to put one together.
