Reply 1640 of 3172, by 640K!enough
wrote:There is a wealth of information inside, thanks for the link! I will see if I can easily add support to DOSMid. Don't have any GUS hardware to test, but I noticed DOSBox got some GUS emulation, so that should be enough I guess. Will post here when/if I get this done, so perhaps one of the GUS-clone owners could see if it works on this modern clone.
It may be worth mentioning that there are two generations of Gravis cards; those based on the GF1, like the original UltraSound, ACE and Max, and those based on the InterWave, like the PnP and PnP Pro. Software designed for GF1-based boards will largely run on InterWave boards (if there is some RAM present), but software designed for native InterWave mode will not run on GF1 boards. GF1 boards are probably more common, so you may want to give some thought to which generation of cards you support. There is a full SDK available for the GF1 cards as well.
