Reply 2080 of 3172, by root42
Sure, sourcing parts is no problem! PCB plus Interwave is fine.
YouTube and Bonus
Reply 2081 of 3172, by shock__
Bad news everyone! Slight delay with the production, as the first audit "failed" due to the producer being unable to exchange one of the gerber files.
On the positive side ... there won't be any annoying visible "pool marker" on the board.
EDIT: Never mind ... seems like they went full speed on the audit this time and sent the board off to production already after re-ordering.
EDIT2: PCBs are being shipped 😀
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 2082 of 3172, by Katara
shock__ wrote:
Bad news everyone! Slight delay with the production, as the first audit "failed" due to the producer being unable to exchange on […]
Great news, I hope there will be enough cards for everyone, I joined this forum just to follow up with the development of the gravis clone, I never thought you will go this far!
Reply 2084 of 3172, by shock__
Good news everyone!
https://i.imgur.com/PkcxC8w.jpg
Bad news everyone!
JLC PCB fucked up the instructions, meaning the cards ended up with the pool marker being visible when the card is fully populated 🙁
Even worse news everyone!
Shipping will be a bit delayed ... probably after easter. I'll PM you once your board has been shipped.
[Z?]
Reply 2085 of 3172, by root42
I think the PCBs look lovely.
YouTube and Bonus
Reply 2086 of 3172, by Whiskey
I don't really understand what you mean about the pool marker being visible, but they do look really nice regardless. I guess this means we need to order some components so we can build and test these cards, is there a spreadsheet or parts list thats up to date?
I stream retro games every wednesday here & I dump the recordings here
Reply 2087 of 3172, by root42
JLC puts a tiny text (like a serial number) on the PCBs, to track quality complaints and such. I never minded them before, but if you don't want them they need to silkscreen them where e.g. an IC will be placed.
71.12 KiB
YouTube and Bonus
Reply 2088 of 3172, by shock__
Yup, that's what I originally set the "JLCJLCJLCJLC" marker under the main IC for ... sadly looks like they missed or ignored it.
On another project I've gone as far as scrubbing it off with a fiberglass pen and re-sealing the PCB with some UV-cureable solder resist with mixed results (south of the large FPGA): https://i.imgur.com/BSRqvHy.jpg
Also thanks for reminding me to upgrade the parts list ... it should be the same as for prototype #2 except for 2 more 10k or 0 ohm resistors and the additional 2x5 header for ESP/SPDIF.
[Z?]
Reply 2089 of 3172, by keropi
I don't worry about the JLC marker , in fact I can say I don't care about it being there
looking good shock___ !
Reply 2090 of 3172, by hard1k
Absolutely awesome! 😀
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 2091 of 3172, by Tiido
You can tell them to put the marker to a specific area. An aquaintance suggested putting the message into the gerbers themselves.
Reply 2092 of 3172, by shock__
Which is exactly what I did ... after they cancelled my original order, so I could add it again. If they said "better luck next time" I'd have been ok with that. Now I have 2 markers and ended up with a 3 day delay. Meh.
[Z?]
Reply 2093 of 3172, by cyclone3d
Wow!
But these are still just beta boards so no big deal. Things happen. Not like it is going to affect the functionality in any way.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2094 of 3172, by 640K!enough
On a few boards, I actually scraped very carefully with a sharp, stiff blade. When the deed was done, you could hardly tell that anything had been there, and there was very little observable effect on the solder mask.
When dealing with smaller boards, you can save a few dollars by creating your own panels. I did that with one adaptor board I used for my early ROM module experimentation. I got 20 of them for the same price as five, and the marker was placed on the break-off tab above the usable boards. Now that I've done that successfully, it may be a way to cut costs on future ROM module production.
Reply 2096 of 3172, by matze79
cyclone3d wrote:
Wow!
I`m pretty sure they will work perfectly as the last prototype did 😀
Reply 2097 of 3172, by shock__
matze79 wrote:
cyclone3d wrote:
Wow!
You are correct ... just assembled one board: https://i.imgur.com/a2okbvq.jpg
Only did major testing so far (output via demo/xtc-play, RAM test, ROM dump + checksum), but looks like no new issues were introduced. Meaning the design is final unless something severe pops up.
EDIT: Updated partslist will follow tomorrow.
[Z?]
Reply 2098 of 3172, by Tiido
This looks really lovely, I hope nothing bad is found during testing ~
Reply 2099 of 3172, by 640K!enough
We'll have to pay special attention to the 4-MiB ROM bank again. I suspect that the resistor changes will fix the problems with the previous prototype, but I'll only be fully convinced when I hear it.
