Show us your retro computer cases
Reply 80 of 213, by creepingnet
That very last Fliptop looks like a flip-top version of the Kingspao Model 35. I've had 3 PC's with those thus far (the non-Fliptop version)...
1992 Flight 386 SX (which I put a ZEOS 486 Motherboard into, the original "Creeping Net 1" or first PC I did a lot of hardware building/tinkering on in 2001-2011)
1994 CAT Computers 486 (Was my main 486 system 2007-2012)
The third was a Pentium 233 MMX system I built out for my mom in 2004. She used that thing for 10-12 years before replacing it with an HP. It may even still be at her house - I dunno. Had a 80GB HDD and 128MB of RAM, Running Windows 98 SE on a ATI Rage II Graphics card and a 17" KDS CRT.
~The Creeping Network~
Reply 81 of 213, by zazuradia
So i've read you like old computers, and since i've used the help on this forum to put my babies together, i might as well treat your eyes with these pics. I humbly present you my gaming room:
(This is the "retro" side of the room, so to speak. There's still a lot of work to do, but almost the 80%, at least, is done.)
This should be the main view. Some cheap Trust speakers, a cheap 10 button joystick, a regular 3 button Logitech mouse, a regular AT keyboard, a 4 button gamepad (despite of it's looks), and the crown jewels: What i consider one of the best CRT monitors ever made; a 17 inch AOC 7VLr. And one of the most robust mechanical (arguable) keyboards still working to this day; from 1991, an IBM Model M (Spanish ISO) bolt-modded (it's on the tray below the table, i promise. 🤣).
1.73 MiB
The laptop is a Dell Latitude L400, model PP01S. A Pentium 3 700MHz, 256MB of RAM.
1.09 MiB
Rescued from the trash on a rainy night (no dramatization, it actually happened), a Pentium 100, 16MB, and a Sound Blaster 16. It has Windows 98 SE in a 2GB Compact Flash but i'm planning on going full Ms-DOS on this system, but i had problems in the past, so i'll need some time. (I had to replace the disk reader because it wasn't working. I want to repair it because it has the super cool Creative logo in the tray plate.)
1.4 MiB
On the other side of the table, this cool looking beefy punk housing a Pentium 4, 512MB of RAM and an ATI 9600 video card to run some of the most demanding games from the Windows 98 era. As you'll se later i don't need console emulators, but that joystick comes in a hell of a handy with the MAME32. (I was building it with a P3 motherboard but the AGP port was incompatible with the ATI 9600. I searched for a compatible board but they are quite expensive. I might replace the noisy CPU fan and stick with this one. I don't know.)
1.45 MiB
And finally, and although i feel i'm flexing a little bit here, The Pentium 4 system is connected via S-Video to this massive 30 inch CRT tv (alongside these other systems i will not bother commenting on, since they're not computers, and to minimize the flex.)
1.52 MiB
I hope you enjoyed the pics as i enjoyed others' works. Feel free to ask or DM anything, you're very welcome. As i said, i'm planning on changing some stuff, but i'm enjoying this room and every system on it, as it is something that i always wanted to build.
Reply 83 of 213, by Tetrium
emosun wrote:
my collection of japanese cases from the 90s
Are those really from Japan? I think they look neat 😁
My retro rigs (old topic)
Report spammers here!
Reply 84 of 213, by Windows9566
A beige ATX case that i found in the dumpster at work, i cleaned it up and put my Pentium 1 hardware in it and turned it into a retro DOS/Win95 machine
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 85 of 213, by Brickpad
Windows9566 wrote:
https://i.imgur.com/2pycqnh.jpg […]
I have the same exact case with a dual Pentium II 400MHz setup. Doesn't have the front USB ports as yours does. It's made by Enlight, model 72500. The only pain is having to pull the front bezel off to remove the side panel. 😕
You can still find it on NewEgg, but it's been long out-of-stock
https://www.newegg.com/Product/Product.aspx?I … N82E16811116009
Reply 87 of 213, by wiretap
^--is there a blackout curtain that normally goes over your window? If not, it would be good to add one, to slow further yellowing of the plastic on the cases.
My Github
Circuit Board Repair Manuals
Reply 88 of 213, by Murugan
I put a cover in front of the window now.
I'm moving out in June and then I have a decent place to store them 😀
Reply 89 of 213, by appiah4
These are mine.. I also have a few more Compaq/Dell OEMs at home, but these were conveniently sitting together in a storage cupboard, so I thought why not snap a photo for this thread?
    462.51 KiB
Reply 91 of 213, by jm8881
This is my retro gaming station. I tried to emulate how we had our first computer setup. It's a HP Vectra VE 4/66. The only changes to it from how HP shipped it is I've replaced the HDD with a cf card and I had to replace the noisy fan inside the power supply.
    103.79 KiB
Reply 94 of 213, by badmojo
I added this nice little AT tower to my collection recently - needed some restoration but came up pretty well. The power button jams if you don't hit it dead center but that just seems to be a design flaw, it's not worn at all.
Reply 95 of 213, by appiah4
oeuvre wrote:
dat deskpro doe
As Master Yoda would say, there is another..
Reply 98 of 213, by gdjacobs
I wonder if you could soap it for smoother toggling. Also, functional turbo?
Reply 99 of 213, by badmojo
Yep possibly but I worry about any sort of lube collecting dust over time - the reset and turbo buttons work real nice but they don't have as far to travel. No biggie, I just have to man up and live with it.
Non functional turbo I'm afraid - the motherboard in that machine has a header, but it's slated for "future use" in the manual and does nothing. So the button and MHz display are totally gimmick here (as apposed to mostly gimmick in machines that it actually does something).
