Reply 200 of 381, by keropi
^ or leave the socket installed and don't bother with it: solder 2 pins and feed it 5v 😁
Reply 201 of 381, by matze79
if you install the diode voltage will drop 0.7V.
Simple drop in a Wire, for the diode and from 1 to Pin 3 of 7805.
Feed 5V, but watch Polarity or it will die 😁
Reply 202 of 381, by konc
Thank you all for the information, I hope I wasn't the only one not knowing how to power the adapter and that more will find all these useful so that I don't feel bad flooding the thread with my questions 😁 I'll play it safe, I'll just solder the 7805 as well and feed it 12V since everything else is already in place.
Reply 203 of 381, by Jepael
Just a reminder, since the barrel of the connector is +12V, you have to be extra careful when it's dangling around in the PC where all exposed metal you see is ground. So it might have been a bit safer if you left out the DC jack and just feed it +12V from molex connector and solder wires to PCB.
Reply 204 of 381, by James-F
Got my kit, thanks matze79!
One small problem, the power adapter input has thick center pin so no standard power adapter (wall-wart) actually fits.
I'll have to buy another more standard one from ebay.
Please check this matze79.
If you ask me, I'd skip the 7805 altogether, there are plenty 5V adapters.
Reply 205 of 381, by rick12373
Got mine yesterday! So on the subject of the power adapter, has anyone found a suitable well priced one online they can link me to (I'm in the USA)?
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 206 of 381, by James-F
After much soldering I removed the 7805 and the non-standard power supply input, along the way I destroyed some soldering pads because of heavy components with dual sided pads.
After I soldered an new more standard power supply input I noticed it is a negative center while practically all standard power supplies are positive center. 😠 😠
To other users, please check carefully how are you going to supply power to the unit, because it is an absolute nightmare to desolder from a dual sided PCB.
@matze79, I hope you take notes for your later PCBs.
* PSU input should be a a standard (thin center pin) and positive center.
Reply 207 of 381, by James-F
bestemor wrote:
Only thing that happens is that the mouse optics lights up red (as they should), and some times the GREEN light on the adapter actually turns ON, and starts to continually blink on-off(500ms intervals) - indefinitely, while the RED light is not lit at all. Other times when I attach the mouse, there are no lights at all(nor green nor red), not even after waiting, and having the computer on or off when doing it does not affect that either.
Same here.
The mouse is Logitech M-SBF90.
I tried everything, it just doesn't work.
Reply 208 of 381, by matze79
Did you solder the Diode ?
What Voltage to you supply to the adapter ?
The light should turn on even without a Computer and just a Mouse attached.
Did you also try another Mouse ?
maybe the mcu programing is defective ? do you own a isp programmer ? or esd damage ?
3$:
http://www.ebay.com/itm/USBTiny-USBtinyISP-AV … UgAAOSwTA9X4Oxq
Can you please provide Pictures of your Build ?
Whats really sucks is the part vendor supplied me with 2 different dcjacks so there two versions out now.
i would recommend to simply remove the damn connector of the powersupply and solder your own for few cents.
This is simple design error, the drawing was wrong connected and i havent noticed it.
But all Roland Equipment also use this Polarity.. and many audio components also.
Sorry i'm busy these days.. too much work, no time left 😒
Reply 209 of 381, by matze79
Heilbar from dos-reloaded.de shows howto mount the Device internal:
http://dos-reloaded.de/forum/index.php/Thread … 17165#post17165
Sorry German language but Pictures are enough, so you can see.
Reply 210 of 381, by feipoa
The slot cover mounting is really slick.
Reply 211 of 381, by konc
A different approach: Secure it wherever inside the case (I placed it at the bottom, insulated of course). Then get a normal ps/2 port on a bracket and replace the header that goes to the motherboard with a male ps/2 plug. This way nothing's hanging/showing/sticking out and the adapter can't get damaged in case of a clumsy move when plugging/unplugging the mouse.
Reply 212 of 381, by matze79
Searching for this Mouse:
219.66 KiB
Felmar Loyd needs this Mouse for enhancement of the firmware to Support Wheelmouse.
Anyone has one laying around ? we need them to see how it works.
Reply 213 of 381, by rosaage
Is there something special about this wheelmouse not found in others?
Reply 214 of 381, by matze79
Yes, its serial wheelmouse.
Reply 215 of 381, by keropi
I wish I had one to donate to the cause, tbh I did not knew this mouse also came in serial ..!
Reply 217 of 381, by feipoa
I have bought a few of those in the past - that is, in the ps/2 format. For some reason, on all the units I bought, even NOS, the scroll wheel is incredibly difficult to move. It seems as if the rubber on the scroll wheel has expanded over time and rubs on the housing.
Reply 218 of 381, by tabm0de
Finnish completing my first board 😀
Everything works as described and im happy with the result even if i did do it that well haha
But sadly im not that good with electronics so it would be nice if there is like a "stupid" instructions where stuff goes ( the right way also ), or it could be something i have missed in this forum.
Also there wasn't much room for the capacitors to sand next to each other, otherwise im happy with the board!
naa, nothing yet...
Reply 219 of 381, by gerwin
I made an illustration that may help, it is halfway page 8 of this topic. Here it is.
