Reply 240 of 381, by root42
What's the status on this project? I have PS/2 mice, but only serial on my 80286 boards. Are PCB schematics and BOM available, or how is this distributed?
YouTube and Bonus
Reply 241 of 381, by matze79
Also on hackaday: https://hackaday.com/2017/10/09/a-converter-y … o-serial-mouse/
i wanted to put everything on http://retroianer.de also including schematic and pcb files. hopefully i will find the time.
Working on internal mount, now with 3d printers, everything changes.. 😁
91.58 KiB
101.63 KiB
This is the converter mounted inside my 8088 Computer.
internal connected to Multi I/O Controller.
135.06 KiB
Reply 242 of 381, by matze79
Here are the Files for 3d printed bracklet mount:
https://www.thingiverse.com/thing:2916860
Reply 243 of 381, by bjwil1991
That looks amazing, man.
Reply 244 of 381, by matze79
Full GPL Firmware is now on Github, including Sourcecode, feel free to improve, report back bugs etc.
Firmware:
https://github.com/matze79/PS2-Adapter
PCB files will follow.
Case:
https://www.thingiverse.com/thing:2435339
Bracklet mount
Reply 245 of 381, by matze79
Fixed Github Link:
Now it should work.
Reply 246 of 381, by matze79
Eagle PCB files added.
Now you can make your own, or maybe improve it.
Reply 248 of 381, by root42
Awesome!
YouTube and Bonus
Reply 249 of 381, by root42
One note: I tried uploading to aisler and OSH park, but both complain. Aisler because of the dimensions layer not having any PCB boundaries (I think they are in the Dimension layer in your file), and OSH park has multiple complaints.
YouTube and Bonus
Reply 250 of 381, by matze79
feipoa wrote:
Did you make any progress concerning pointer lag when using certain KVM's?
Not really, i just use a KVM that works.
But the Firmware is opensource, maybe one with more knowledge can help ? 😳
>One note: I tried uploading to aisler and OSH park, but both complain. Aisler because of the dimensions layer not having any PCB boundaries (I think they are in the Dimension layer in your file), >and OSH park has multiple complaints.
i don't have any idea, i just used dirtypcbs and it worked fine for me.
Its also cheaper then oshpark.
Because you get 10 pcbs 5x5cm for 16,95$.
Reply 251 of 381, by root42
>One note: I tried uploading to aisler and OSH park, but both complain. Aisler because of the dimensions layer not having any PC […]
Ok, thanks for the info. I might order there as well, but I haven't yet given up on using one of the other providers. I have a minimal fix on the PCB (distance from one trace towards a solder pad) and I might generate some gerber files for other PCB providers.
I will make a pull request once I have this all working... 😉
YouTube and Bonus
Reply 252 of 381, by matze79
you may want to fix the powerconnector too, + and - are swapped. 😀
Reply 254 of 381, by matze79
Do what ever you want, everything is GPL 😀
i also would like a ultimate XT Converter 😁
Reply 255 of 381, by root42
I have now a version of the Eagle PCB file that works at Aisler. 😉 However two things come to my mind:
1) I have never used an ATtiny before. I guess I need some kind of programmer device for this?
2) Since I only need one adapter: Does anyone still have kits, before I start ordering my own at Aisler and Mouser?
YouTube and Bonus
Reply 256 of 381, by matze79
hopefully dreamblaster will make a series and sell them at serdaco shop 😀 so there is a place in future where you can get this converter device easily.
i'm pretty sure someone will take the leftovers.
Reply 257 of 381, by matze79
You can simply wire the ATTiny2313 to the LPT Port and program it with avrdude 😀
few resistors are recommend but not needed.
Reply 258 of 381, by root42
I have created a Mouser project for the BOM:
https://www.mouser.com/ProjectManager/Project … ssID=86005d505b
I haven't ordered nor built anything yet, so please double check if I selected all the correct components! Feedback welcome, I will change the project accordingly.
YouTube and Bonus
Reply 259 of 381, by root42
Furthermore, there is now a project for the PCB over at Aisler:
https://aisler.net/p/LZMRKTBP
My PCBs are scheduled for manufacturing, but I haven't gotten them either, so you might want to wait until I receive them and can test them, if they are actually fine. 😉
YouTube and Bonus
