Reply 260 of 381, by root42
The PCBs from Aisler arrived. I already have the components from Mouser. So pending some spare time I can start assembling three little converters!
Apart from the stupid CF connector, this will be my first SMD soldering.
219.72 KiB
YouTube and Bonus
Reply 261 of 381, by matze79
Nice PCB, goldenig 😁
Its not hard to solder, the parts are BIG. 😁
Reply 262 of 381, by POTA
I've been trying to contact the 'matze79' fellow on youtube, he said to contact him via email but didn't provide an address. There doesn't seem to be a way of contacting him directly on this board either.
Reply 263 of 381, by feipoa
You need a certain minimum number of posts before you can PM on Vogons. I'm sure matze79 will show up.
Reply 265 of 381, by root42
What question do you have to him? If you need an adapter: I still haven't started soldering mine. I will have three in the end, but only need one. So I would part with one or two.
YouTube and Bonus
Reply 266 of 381, by POTA
Thanks root42, I have just sent you an email.
Reply 269 of 381, by matze79
Stupid.. 😳 now you can contact me:
My Email Adress:
01101101 01100001 01110100 01111010 01100101 00110101 00110010 00110101 01000000 01101100 01101001 01110110 01100101 00101110 01100100 01100101
Reply 270 of 381, by root42
I finally got around to soldering my first adapter. I have not yet powered it up, nor have I programmed the ATTINY.
I have some questions, matze:
* You mentioned something about power being swapped. Can I simply use a center positive 5V supply on this thing or will I fry it?
* Which pin header is for programming? And what is the other pin header for? (JP1 and X1)
Edit: Ok, I see from the traces that JP1 is an alternative serial pin header. I just need to figure out the pinout to connect it to my ASYN2 port of my Multi IO card... And hence X1 is the programming header for the ATTINY. Also still need to figure out the pinout for that.
Edit2: Does the device need to be powered on for programming, or rather not?
* What does SW1 do?
Eagerly awaiting an answer, so i can see if it works. 😀
Also I need to manufacture some serial cable...
461.99 KiB
YouTube and Bonus
Reply 271 of 381, by root42
Another question that came to my mind:
Since there is a linear voltage regulator on this thing -- can I use the 12V input as well? There are cheap Molex to barrel plug converters out there, so I don't need to build my own...
YouTube and Bonus
Reply 272 of 381, by gerwin
Some of your questions are answered on page 8 of this topic.
Did you not get a pre-programmed chip with the kit? I never programmed anything for my own assembly.
Reply 273 of 381, by root42
Thanks, I‘ll have a look at page 8. it’s all too long ago already. 😉
I made my kit from scratch via matze‘s github repo.
YouTube and Bonus
Reply 274 of 381, by root42
Ok, successfully programmed the ATTINY. Also figured out the polarity of the PSU jack. Now left is the serial pin header. But for a start I can just plug it into my multi card...
YouTube and Bonus
Reply 275 of 381, by matze79
The Switches where placed onboard for turning on Mouse Wheel Support etc.
But we had no success getting your hands on a RS232 Scroll mouse yet. (Experimental Stuff...)
The 6 Pin header is for programming. its standard ISP Pinout.
You don't need a header there 😀
There is 5V on the ISP Header.
Only the DC-Jack is swapped. GND = center Pin
Why not simply plug in a COM Cable to Pinheader of I/O Card ?
AVRDUDE:
avrdude -c usbasp -p t2313 -U lfuse:w:0xfd:m -U hfuse:w:0xdf:m -U efuse:w:0xfe:m
avrdude -c usbasp -p t2313 -U flash:w:ps2adapter.hex
hex:**
ps2adapter-noboot-tiny2313.rar
1.7 KiB
82 downloads
Reply 276 of 381, by root42
matze79 wrote:
The Switches where placed onboard for turning on Mouse Wheel Support etc. But we had no success getting your hands on a RS232 Sc […]
AVRDUDE:
Yeah, I used the 6 pin isp with my cheapo usbasp clone with avrdude. Seemed to have worked. Now I need to test the whole thing, connect the device to the IO card and feedbin some power.
YouTube and Bonus
Reply 277 of 381, by matze79
Its enough to connect 5v and mouse to see if its alive, the led should show feedback when you move the mouse 😀
Reply 278 of 381, by root42
Don't laugh, but I accidentally ordered a male rs232 socket - the picture showed a female socket... so I can't plug it to my IO card without a gender changer. I am waiting on new female sockets to arrive from China...
Hence I wonder: what is the pinout of the header next to the rs232? I can probably figure it out using my meter, but maybe it's faster to just ask. 😀 Also: do all 9(?) pin ASYN headers of IO cards have the same pinout?
YouTube and Bonus
Reply 279 of 381, by matze79
Just look in the Schematic 😀 there is how the header is connected.
