Dual Pentium Pro Build Thread
Reply 140 of 185, by Mentat-vvo
wiretap wrote on 2020-08-09, 19:22:
But then he'll realize only a few dozen people will buy them if the price is fair. 🤣 .. it's better just to make gerbers for retro computer stuff public, as there's really not a whole lot of revenue in niche products. Someone will just buy one to clone/fork anyway.
A couple of Dozens of years have passed - no one made a clone )) And the only person who decided to get into making PPros work in slot1 mobos was max1024. But, he shared the detailed instruction how to prepare the BIOS in his article on overclockers.ru and other resources, in Russian. If you think he would kindly share the BIOSEs - nope. So, I was pushed to do all the stuff myself.
I am not ready to make the project open. Just not yet. The rare dual-socketed motherboards, the time spent , the parts, the production, the assembly - all the stuff costs money. Also, $$$ is a good motivator 🥴
Ps. A Dual Tyan 694X needs a special BIOS tweaking approach , since it somehow protects the main module. I have correct detection of single PPro, but it locks on a second CPU detection, even if it’s not there. A rom.by BIOS patcher, however, do not throw error 41. I need to patch the patcher now))
Got this broken OR840. Gonna try to fix it and run dual PPros.
1.42 MiB
PPro250/Freeway694x/512M/Gf3Ti500/AdvGUS
2x P3Xeon900-2M/1Gb/QuadroDCC/AWE32
K6III+400@624/P5A/256Mb/GF3ti200@500
Iskra 1031 Issue 2 - i8086 PC/XT Clone from USSR
Reply 142 of 185, by luckybob
that OR840 is probably okay. I've seen quite a few not post if they dont have their cmos battery installed.
Re: Outrigger: an ongoing adventure with the OR840
It is a 2450 cell.
Reply 143 of 185, by Mentat-vvo
luckybob wrote on 2020-08-12, 09:19:
It is a 2450 cell.
Thanks for a hint, I’ll try.
Reply 144 of 185, by Mentat-vvo
Sad news, guys. The 3.3v support in OR840 has beed wiped out. I was expecting this trick from Intel. The PPro CPU just do not allow the mobo to start. Though battery trick helped to turn back normal power sequence , the board locks with 88 code with P3-450 & P3-667.
Reply 146 of 185, by Mentat-vvo
Got newly-made ones.
702 KiB
1.42 MiB
Reply 147 of 185, by H3nrik V!
Mentat-vvo wrote on 2020-08-20, 10:00:
Looks good!
You may want to consider not having the silk screen text copied also; might give copyright issues?
Reply 151 of 185, by Mentat-vvo
Hello again. I was finally able to launch a couple of 200/512 PPros and then black tops in Tyan Tiger 133D S1834. It was extremely hard to beat Award 6.0PG BIOS and find all problematic places. The mobo supports multipliers 2x and 2.5x and also B21 trick to launch the CPU at 100 MHz. I had also to tie VID1 to ground in order to get stable 250 MHz, but that causes excess heating of VRMs. Now system is stable at 2x100 without overheat.
Reply 152 of 185, by maxtherabbit
Mentat-vvo wrote on 2020-12-09, 12:21:
Can you elaborate on this?
Reply 153 of 185, by Mentat-vvo
maxtherabbit wrote on 2020-12-09, 15:03:
Nope.
Pentium 3 450 / i820 was beaten by 2x Black Top at 220(2x110Mhz) in Memory Read competition.
Reply 155 of 185, by Mentat-vvo
feipoa wrote on 2020-12-10, 11:24:
Do they work in dual CPU mode?
I think test runs in single CPU mode, but WinXP is definitely SMP-capable. The memory bandwidth Gain is the result of SDRAM overclocking to 146 MHz 2-2-2-6 and 2-way interleaving ON.
There are the results of the same test with single CPU(512k) @ 95 MHz with Asus P3V4X.
Reply 157 of 185, by Arctic
@Mentat-vvo
Ist it still possible to get one or two of these adapters?
Reply 158 of 185, by BootROMError8046
Mentat-vvo wrote on 2020-12-10, 11:53:
Hi there! I got a slotket8 clone from you and I gotta ask, where do you find the microcode and how do you add it to the bios binary? I have some knowledge in bios customization but I didn't mess with old award bioses before.
I have an asus P3B-F and an MSI MS6119 BX2. Thanks in advance!!
Reply 159 of 185, by Mentat-vvo
There’s not a microcode problem . If you have bought the slotket on eBay from me, post your question there and I will provide a link for bios download.
