The last few days were good days for rubbish:
On the right a Toshiba T1200 I received from a local old lady who spotted it while out walking the dog. It's one of the first recognizable laptops (as opposed to huge luggables). This one dates from late 1987 and comes with an 80C86 CPU two FDDs and no HDD. It supposedly has all kinds of nifty features such as built-in LIM EMS support for the upper 386kB of RAM, and the option to use this as a battery-backed RAMdisk, which allowed instantaneous launching of (small) apps. That also reduces the impact of not having a HDD- DOS boots from ROM and something like WordPerfect can be loaded from RAMdrive. In fact it's probably good that it's the version without HDD, as Toshiba used a completely unique one-off proprietary drive+interface for the high-end T1200, so if it's not working perfectly, you're effectively screwed. Unfortunately an ominous LED flashes red at me when I hook up power, and it doesn't do anymore than that. Apparently these things are notorious for (leaking) battery problems, with three separate batteries (main system battery, reputed to die within a year of sale, CMOS battery and a separate battery for the RAM. Haven't opened it up yet, sort of dread what I might see...
On the left one I saved myself, a Sun LSA800 18" TFT. It has a pretty decent (I believe IPS, in any event not TN) panel with standard 1280x1024 5:4 resolution. Apart from the cool Sun branding, the outstanding feature is that it is probably the only TFT with a 13W3 connector and the electronics to display legacy Sun display modes. Now I don't currently have any of those, but who knows when I might come across one. In the meantime it also does a very good job with DOS VGA
