Reply 1780 of 4609, by bjwil1991
Mine has the Cirrus Logic CL-GD5428, Motherboard revision: PB450M (according to my findings and the BIOS screen). The board has 2 IDE ports, 1 FDD port, and jumpers everywhere. It's the board in the first photo on your post.
Reply 1781 of 4609, by Flakchak
Understood. Unfortunately, the PB450 does not support PCI.
Searching for a Packard Bell 15" CRT Monitor - 1511SL or 1512SL
Reply 1782 of 4609, by bjwil1991
Dang. That's unfortunate. My plan is to get a cached IDE controller card for the Packard Bell since the OS takes a long time to load sometimes. Also, it's my 1,000th post for close to 5 years running! Here's to 1,000 more.
Reply 1783 of 4609, by Synoptic
I found a 5150 in my in-law's basement.
It has an aftermarket 80286 upgrade card. This upgrade requires to short two pins on a specific IC on the motherboard. Does anyone have any information about this?
I still have the original cpu though.
It came with a 5151 monitor. It has no hdd but the cables are there. It also has two 5 1/4 drives.
The case is very rough because some liquid got spilled on it and made a very big patch of rust.
The inside is good. Dusty but good.
I also have a box full of IBM books and floppies.
List of HW found inside :
Hercules video Card
Unknown brand 80286 upgrade with RAM. Full sized card.
AST SixPackPlus
MFM and Floppy Controller
Two 5¼ drives (might be 1.2Mb drives, as they look "modern".
5151 Monitor
And it does boot !
Reply 1784 of 4609, by sf78
Synoptic wrote:
And it does boot ! https://i.imgur.com/VriNQc7l.jpg […]
And it does boot !
What are the error codes on the screen? If it boots all the way, it should go to a basic screen (built in basic). If you see a 201 error code you have faulty memory or memory dip switches have wrong settings.
1.78 KiB
Reply 1785 of 4609, by Synoptic
sf78 wrote:
And it does boot !
1701 (04)
Not sure if the Basic will start with the 80286 upgrade card...
Reply 1786 of 4609, by bjwil1991
1701 means there's no fixed disk (hard drive) present.
Reply 1787 of 4609, by Ozzuneoj
Might be worth it to try the steps on this site:
http://www.minuszerodegrees.net/5150_5160/hdd … ssibilities.htm
If there is no hard drive in the computer connected to the MFM interface, you may have to disable the MFM interface portion of the card installed in the system. It probably has a jumper for this, though with all those aftermarket parts, you're going to have to do some digging to find the jumper settings. This is a good place to look: https://th99.bl4ckb0x.de/
Congrats on the find though! I have a 5150 that I've upgraded significantly. I installed an Orchid Tiny Turbo 286 card in mine and it works great. Almost everything I've run on the system works perfectly with the 286 enabled. Mine has a switch on the back I can flip which toggles between the 286 and the original 8088.
Reply 1788 of 4609, by bjwil1991
Ozzuneoj wrote:
Might be worth it to try the steps on this site: http://www.minuszerodegrees.net/5150_5160/hdd … ssibilities.htm […]
So close to turbo mode? That's interesting that you have that in your system.
Reply 1789 of 4609, by Synoptic
My friend has an MFM drive. I would like to try it. Can I use almst any MFM drive or a specific model only ?
I'm also planning on using the XT-IDE Glitchy thingy that I ordered in case I cannot use an MFM HDD.
Reply 1790 of 4609, by MMaximus
Synoptic wrote:
https://i.imgur.com/VriNQc7l.jpg https://i.imgur.com/HUlumu3l.jpg […]
Great find! It looks like 2 different monitors though. Is the one in the boot of the car a LCD in a 5151 casing?
Hard Disk Sounds
Reply 1793 of 4609, by TheAbandonwareGuy
Synoptic wrote:
I can boot DOS !
Now I need to find a XT keyboard... I can't type anything with my current AT keyboard.
Don't they make adapters for that?
Reply 1794 of 4609, by King_Corduroy
Formulator wrote:
King_Corduroy wrote:
Sure yeah I need to get back to doing some videos so maybe I'll do a video on restoring this one (Or one just like it since I've got a stack of PB machines). But yeah the riser cards should be swappable as long as it's the same height.
If you do a full restore of this system, it would be a nice touch it you could produce a reproduction spec label for the case. Since it is not a Nintendo cartridge, perhaps it would not incite too much disapproval.
Funny you should say that actually cause I was discussing that in a Packard collecting group yesterday. Lol
I have a few systems with messed up stickers I wouldn't mind making new again, eventually I'd like to print up repro sales floor display signs based on various photos also. But that will have to wait till my finances are a bit more stable and I also have room to display them all. Lol
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 1795 of 4609, by eisapc
TheAbandonwareGuy wrote:
Synoptic wrote:
I can boot DOS !
Better look for one of these keyboards that have this little switch on the bottom to change between AT and XT protocol.
Reply 1796 of 4609, by Synoptic
Synoptic wrote:
I can boot DOS !
Original keyboard found in the basement 😀
Reply 1797 of 4609, by King_Corduroy
Found another machine!
Neat case, probably not going to keep it but it seem to be complete so I'm trying to get it to boot right now. Seems to have a Pentium 150 in it and it's running Windows 95.
Reply 1798 of 4609, by cyclone3d
Found another machine! […]
What sound cards does it have? Looks like one is ISA and one is PCI.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1799 of 4609, by bjwil1991
The bottom one looks like the Sound Blaster 16 WavEffects CT4170 (I have one, and I detest the CQM synthesizer). The other one, I've never seen before (PCI cards had the jack on the opposite side than the ISA cards). Great find, no doubt.
