Reply 2200 of 4609, by Tiido
It is Western Design Center 😜
I got a WD90C30 not so long ago and it is very good, the fastest ISA video card I have, sligtly faster than the TVGA8900D I was using earlier in one of my machines.
Reply 2201 of 4609, by xjas
Haven't picked up anything in a while, but today I rescued this Gateway tower on the hope that it might fit my Gateway/ALR 7200 server board. It's missing the top piece of plastic (big whoop) but is otherwise in great shape. I'll have to dremel out the I/O shield area (there's no shield, the ports are just stamped into the case) unless I get extraordinarily lucky, and almost certainly have to remove the internal 3.5" HDD bays, but if it fits I'm not complaining.
205.72 KiB
185.63 KiB
293.12 KiB
The board extends past the top of the I/O shield area which makes it incompatible with 95% of standard cases. This is the first one I've come across in ages that actually gives me some room up there.
I also snagged this Chicony-built Samsung keyboard. No idea what it came from, but it feels (& sounds) like a buckling spring(!) or some other kind of mechanical mechanism, and it has an AT/XT switch on the bottom, so I figured it was worth grabbing. The cable was cut off but I can fix that easily.
299.76 KiB
194.91 KiB
Reply 2202 of 4609, by SW-SSG
Tiido wrote:
It is Western Design Center :P ...
Wrong, it actually is Western Digital.
They were a much more interesting and varied company before they switched to specializing in HDDs... kind of like how AMD was before they became CPUs-only.
Reply 2203 of 4609, by Baoran
Is there anything that can be done about all this corrosion on this AT case to make it more shiny again?
The painted cover is fine, but all shiny parts inside and outside have corrosion like this.
Or should I just throw the case in the bin?
1.87 MiB
Reply 2204 of 4609, by liqmat
Baoran wrote:
Is there anything that can be done about all this corrosion on this AT case to make it more shiny again? The painted cover is f […]
I know a guy who just did amazing metal restoration work for me on a furniture piece. Let me see what he says about that photo before you toss it.
He said, "if he's going to try to restore it I would say light soap and a very fine stainless steel wire brush...and test it in an unseen area first..."
he also said "be gentle" not too hard.
Reply 2205 of 4609, by Tiido
SW-SSG wrote:
Tiido wrote:
It is Western Design Center 😜 ...
Oh wow, now I know. Somehow I remember that logo being of WDC, who made the 65x line CPUs and I assumed they were doing these chips too (but seems they only do CPUs). And WDC's logo is completely different too...
Reply 2206 of 4609, by Baoran
liqmat wrote:
I know a guy who just did amazing metal restoration work for me on a furniture piece. Let me see what he says about that photo b […]
Something like this? https://www.ebay.co.uk/itm/WIRE-BRUSH-SET-SMA … PC/323513080554
Would a dremel with polish tip do anything? I might be able to borrow one.
Reply 2207 of 4609, by liqmat
I would not dremel anything to start. start slow and easy in a small area by hand. as far as the type of brush I would experiment on another piece of metal and see. luckily i haven't had to deal with something quite that oxidized yet.
Reply 2209 of 4609, by tayyare
Sand blasting and recoating (electroplating - hard, or painting - easier) is the only realiable way. Maybe some auto repair shop can help you with that.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 2210 of 4609, by gdjacobs
PC Hoarder Patrol wrote:
Maybe try and get hold of some of that super-fine wire wool used by wood restorers (works great on metals too)
#000 or #0000 grade is pretty fine. If the steel was originally galvanized, you might have to apply another finish (maybe clearcoat) when you're done.
Reply 2211 of 4609, by appiah4
I would just sand it down with fine grit sand paper then spray paint it with an appropriate mettallic paint.
Reply 2213 of 4609, by tayyare
Baoran wrote:
It might be an aluminum case and not steel one because it is rather light if it makes difference in how I should deal with it with it.
It's not aliminum, I'm sure it's zinc plated steel. The zinc plating göne bad.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 2214 of 4609, by Merovign
It must be the season for getting rid of that specific era Gateway. I recently got two, one of which I intend to house a PPro board (rather anachronistically). The other one is fully functional and I'm not sure what I'm going to do with it.
*Too* *many* *things*!
Reply 2216 of 4609, by PARKE
Agree with this advise.
Drilling and sanding etc. of oxidized zinc plated stuff presents a potential hazard to your health - at least that is what I seem to remember.
It's a nice case and worth having it restored in a professional way imo.
Reply 2218 of 4609, by chinny22
End of year clear outs = Christmas for me
Didn't get a pic of before but stripped out a pair of faulty HP 3135 Micro Towers
Grabbed the SATA DVD-RW, 500GB HDD, USB Card reader, chipset heatsinks from both and a PSU from one of them, also grabbed the 90mm case fans for one of my cases only to find I need 80mm
More interesting is from another site where I scored 4 servers in total
DL140 G2 Single 2.8GHz CPU, 1GB RAM (unracked not in pic)
DL360 G4 Single 3.40Ghz CPU, 3GB Ram
DL360 G5 Fails to POST (unracked not in pic, probably BECASUE its dead)
Could only get one of the Dell 1950's as the other is acting as a shelf, Still grabbed its CPU+Heatsink, RAM, PSU from it. Didn't bother with the HDD's as only 80GB
Annoying thing is the one I got fails to post due to a controller error, probably fixable but wish I checked if the other worked and used the faulty one for parts.
No plans yet they'll join my other post P3 era servers in long term storage
Reply 2219 of 4609, by liqmat
chinny22 wrote:
End of year clear outs = Christmas for me […]
What does the big red dial in the yellow shroud on the wall do? 😀
My best guess is it opens a time portal, but please correct me if I'm wrong.
