Reply 2360 of 4626, by appiah4
x0zm_ wrote:
appiah4 wrote:
If you have any 3.5” ones for Dell Dimension Xps D series (they are not standard) please let me know 😀
Got any photo of the exact one you're after? I can try sort through it and see.
I will get you a photo next weekend if you can hold on until then 😀
Reply 2361 of 4626, by chinny22
Got these off freecycle last weekend
The post just said 3 working computers, hard drives removed. It was the beige dell that got my attention but the pic in the post wasn't clear enough to work out model numbers.
So what did I get?
Dell Inspiron 530s
I liked the case but it doesn't turn on so its getting parted out.
The motherboard gets power so will sell the PSU, someone might want that. DVD drive is going to my XP PC as its drive died last month. Also keeping the 2 sticks of 1GB RAM, the E4500 CPU and the card reader as they sell cheaper then shipping but may be useful
The Fujitsu is even more boring but maybe slightly more "useful"
Socket 478 Celeron 2800, 256MB ram, Asus P4GE-FSC motherboard.
It turns on and has a AGP slot so will probably just dump it in storage for now.
and best for last the Dell 4100
P3 1Ghz, 2x 128MB ram, ES1373 Sound, NEC D720101GJ USB 2.0 card with internal USB port, Ati Rage 128 Pro AGP, Realtec Nic, and a 20GB HDD?
oh and dust
Starting that up was a real step back in time. Looking at the WinXP logs looks like it was used till 2006 and had the typical software back then. Office XP, LimeWire, dial up ISP software, jokes in powerpoint you would email each other. Guess he thought anything over 10 years old doesn't matter anyway. After 5 minutes of poking round I was board and started stripping it down to clean.
Also got a pair of those Cambrige Creative speakers every OEM were giving away back then a 4:3 15" no name and a 16:9 or something dell screen. I'll keep the dell as I'm still using 5:4 17" on my desk, but the 15" and cheap filthy keyboards will get chucked
Reply 2362 of 4626, by Merovign
SSTV2 wrote:
Dug up today a PCChips M912 V1.4 motheboard with AMD 486DX-40 CPU and SIMM30 memory at the same thicket where I've found IBM XT clone PC. Looks like it'll have to undergo some serious forensic examination 🤣
Great, now I'm going to be staring suspiciously at thickets everywhere I go.
*Too* *many* *things*!
Reply 2363 of 4626, by luckybob
Reply 2364 of 4626, by liqmat
I once found an Amiga 500 bundle at a garage sale years ago for $50. As far as I'm concerned, forever that street's name is
6.71 KiB
and now I have magic pie bushes to worry about. Wonderful.
Reply 2366 of 4626, by detritus olentus
Found what I think is a G5 Proliant in municipal recycle today.
    1.06 MiB
https://archive.org/details/@detritus_olentus
Philly Burbs.
Reply 2367 of 4626, by gdjacobs
Score! ML350 G5? Load it up with FreeNAS and SATA drives. Don't use the SmartArray controller -- either stick with onboard or find a used LSI SAS HBA that allows raw JBOD access.
Reply 2368 of 4626, by detritus olentus
ML350 indeed! Already switched to onboard because I followed the diagrams inside the case and it appeared redundant not to! Drive trays were gone so I slid a spare sata drive in loose just to test it out and it runs nice.
    607.8 KiB
Philly Burbs.
Reply 2370 of 4626, by chinny22
What was the add on card? I'm assuming must off been some reason for it? more RAM, battery backup or something. Although even the on board can do this.
I've just about finished my ML350 G5 build as well 😀 I went with Windows 2000, overkill I know but it is still officially supported 😀
Reply 2371 of 4626, by detritus olentus
The card appears to have a 256mb ram module attached to it though I'm really not well versed in the arcane art of servers yet.
Philly Burbs.
Reply 2373 of 4626, by chinny22
Ah that'll be it.
The onboard E200i only supports 128MB. You can see it's battery in the slot right at the bottom of the motherboard marked with 01/07 Rev 1
I'm guessing the card is a Smart Array P400 or P800 which will give faster I/O but doubt even the onboard will be a bottleneck on a home network.
If you configure iLo, the virtual DVD drive works really well for installing whatever OS you choose. Think of it as daemon tools but at the bios level
Reply 2375 of 4626, by Turbo ->
These speakers were intended for dumpster, until I came along and saved them.
    482.61 KiB
Reply 2376 of 4626, by HanJammer
I didn't really found them, but they were donated to me by my coworker... around two hundred of 5,25" disks he used in 80s/early 90s (only a bunch from a big box presented on the photo)... supposedly some interesting software on them... some of them are original driver disk for some 286 motherboards and isa video cards (hopefully not overwritten).
Reply 2377 of 4626, by keenmaster486
Hey @x0zm_, I just now noticed you got a Thinkpad 600E at almost exactly the same time as I did.
My approach to the finish was to scrape off the old, then apply 5 or 6 heavy coats of PlastiDip. Did the trick nicely.
World's foremost 486 enjoyer.
Reply 2378 of 4626, by Merovign
(eyes bug out)
(pulse races)
I shouldn't complain, while it's untested and still in the car I found a Dell Precision 420 Dual Pentium III today, looks complete, weighs like 6.5 metric tons ('swhy it's still in the car).
I can never find floppy lots that aren't insanely priced or gone when I get there. I had to buy a few boxes recently.
Edit 420 no power. Some sign of metal corrosion, probably stored in a damp place. Mobo looks clean, probably (proprietary) PSU. Meh.
Reply 2379 of 4626, by xjas
Been a while since I went on a good recycle safari. Last weekend I scored these:
381.99 KiB
an ASUS TX97-E with the north & southbridge removed, for some reason, and a huge burn mark (WTF) underneath where the 2032 battery holder used to be:
352.71 KiB
273.96 KiB
...and an ECS P6BX-A+ with a missing clip from one DIMM slot, the ATX power header neatly de-soldered, and an interestingly-shaped row of front panel connectors:
209.99 KiB
I'm actually fine with this; I can sacrifice the ASUS to save the ECS which is a pretty nice board, and harvest its ISA slots for a different project. I have precious few Socket 7/AT spare parts, but Slot 1 CPUs and ATX cases are coming out my ears, so I can make the ECS into a solid little machine. I might even swap it in place of my P2L97-S (LX) if it runs well, since I have an underclocked 100FSB P3 in there anyway.
Looks like it has a PC/PCI (SB-Link) header too, so bonus win.
283.44 KiB
This was actually the first part of a bigger haul with some choice goodies. More to come later. B)
chinny22 wrote:
and best for last the Dell 4100 [ ... ] P3 1Ghz, 2x 128MB ram, ES1373 Sound, NEC D720101GJ USB 2.0 card with internal USB port, […]
oh and dust
When I got my XPS T550 (same case) it was totally clogged up with dust too. Not quite as bad as yours, but pretty gross; I had to do a complete teardown and vacuum-out before I even let it into my apartment. Something about that case design just cakes it in everywhere it can & never lets it go.
