Reply 3900 of 4961, by Ydee
MMaximus wrote on 2022-09-07, 09:18:
Nice score
can't believe some people still trash valuable parts like these 🤷
Everyone has no idea what it's worth - for some it was simply old, today useless keyboards. That doesn't make him an idiot.
Reply 3901 of 4961, by Lylat1an
Ydee wrote on 2022-09-07, 09:44:
Nice score
I admit I shouldn't have used that term.
Reply 3902 of 4961, by BetaC
Well, work worked out for me once more. I managed to find some 72 pin ram, which is cool and all. I also managed to find an 8100 HPV card that can accelerate my 7100’s video at the cost of not that great AV capabilities going away.
The attachment 63F61C6A-479A-43E9-B7D5-4EA02D156764.jpeg is no longer available
That’s cool, but, you know, this Radius Thunder IV that was underneath it was far more interesting.
The attachment A7C637E5-085D-48D5-B4AB-7CDEF43B9531.jpeg is no longer available
The attachment 8E143454-1DE6-4FA8-BC20-6C8B104343DD.jpeg is no longer available
Sure, it’s not the hyper expensive 1600, but who am I to complain about a high end NuBus 90 card, especially when it has a Photoshop Accelerator
Reply 3903 of 4961, by digger
So a month ago I found a Compaq Athlon 64 dual core system outside by the "grofvuil" ("Bulky waste"), including a wide-screen monitor. Although I really don't have the room for it in my apartment, I couldn't help myself, and grabbed it.
The screen was in reasonable condition, and worked well, with a crisp image, even though it had only VGA input for video. It did have integrated speakers, so I ended up using it for my test/hobby system.
The case was absolutely disgusting, both inside and out. It felt grimy all over, and there appeared to have been some kind of fluid damage inside. I don't even want to know what caused it.
I decided to gut the case, taking out all the components (including the backplate and even the Windows Vista license sticker), and then I got rid of the case. The system was lacking a hard drive, but was otherwise complete.
I tested the components and everything appears to be working fine. I installed everything in a (clean) ATX case, and it's a complete and working system again. I'm just not sure what to do with it now. I don't really need it, and I'm not sure if anybody else would be interested in it. I've opened a dedicated thread about this. Curious to see if anybody would be interested in what appears to be a fairly unremarkable system from around 2008.
Reply 3904 of 4961, by weedeewee
Found a TL866II-PLUS eeprom reader/programmer with 18 adapters today.
tested reading a 25f80, works.
also several other electronic boards
4x esp12e
2x esp32-cam
3x nodemcu base
esp32-wroom-32
4x aht10 (temperature and humidity sensor)
neje lasermodule tester v1.0 & neje module 20W
3.8v 250mAh li ion battery
5x rcwl-0516 (Microwave Proximity Sensor)
5x gy-bme/p 280 (pressure or humidity sensor)
apdc-16k (with remote)
15x lz12v4-9x1w (still packaged like it came from an aliexpress seller)
and a DB9 female to female adapter 😀
I can't help wonder what the reason was for someone to throw all this out, most of it is still in the sealed antistatic bag. 😐
Do not ask Why !
Reply 3905 of 4961, by BitWrangler
The nodeMCUs can be made into wifi serial modems for old systems pretty easily... there's probably ESP32 versions as well now, but no advantage to using them for that probably.
Reply 3906 of 4961, by Babasha
Something blurry and rusty found 😉
Need help? Begin with photo and model of your hardware 😉
Reply 3907 of 4961, by Black6spdZ
CelGen wrote on 2018-06-14, 03:02:
Another strange BCM brand device with a "Whizpro" BIOS has surfaced in the trash.
The previous one a socket 370 board that was older than this one) I nailed together that BCM, Whizpro and Gtech are all something to do with lottery machines or kiosks. That LCD screen touts an ELO touchscreen on an internal serial port and there is a barcode reader on the underside. In fact the BIOS reports there are no less than six serial ports present in the machine. It all hangs off a rather heavy duty mount of some sort. Has all the usual I/O fixings and peripheral interfaces and the riser card for PCI has solder pads for one ISA slot. There's also oddly a Mini-PCI slot on the motherboard. 😕
The BIOS like the other one is locked and a battery pull does not clear it. Likewise the manual for the motherboard does not appear to be available online so no idea where the CMOS clear jumper might be. 🙁
if you recall were you ever able to get into this motherboard?
Reply 3908 of 4961, by CelGen
Black6spdZ wrote on 2022-09-27, 05:31:
I was not able to. Sorry.
Reply 3909 of 4961, by holdencars11
Athlon XP +KM266
Interesting Thermaltake fan control and huge copper HSF..
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
Reply 3910 of 4961, by BitWrangler
Looks like the fan on a Volcano 9 but the bottom looks like a Volcano 7+ ... but there were hald a dozen variations, somewhere in that range probably.
Reply 3911 of 4961, by holdencars11
BitWrangler wrote on 2022-10-03, 14:40:
Looking like it's a Volcano 12 with the fan from the X-Blower attached to the Heatsink instead.
Reply 3912 of 4961, by BitWrangler
Intercepted an Iris Video Phone (desktop phone) that was destined to be thrown out/recycled... It has been shown they run Doom, so while not PC hardware per se, it's got game. Thinking/hoping I will get it set up for 16bit console emulators, and make it into semi arcade cab, countertop style. This kind of nonsense... https://cassettepunk.com/large-projects/phonetendo/
Phase 1: Hack t3h Gibson, get telnet access, pivot root, install debian.
Phase 2: ???
Phase 3: Profit.
Edit: Nobody was mentioning the hardware specs, finally dug them out to find it might only be a 400Mhz single core ARM, though I have an updated version of the phone, that hopefully isn't extra locked down, but might have a faster core. Anyhoooo, that means 16bit emu might be a bit optimistic, at least under MAME2000 which on a 600Mhz ARM CPU in a Leapfrog handheld tended to have stalls and frame drops. 8 bit stuff was smooth and playable though. Possibly there are standalone machine specific emulators that are a lot faster on ARM.
Reply 3913 of 4961, by Half-Saint
I just rescued a 19" Iiyama Vision Master 450 from the trash this morning. It weighs somwhere between 25 and 30 kg and apart from slight yellowing looks good on the outside. I still have to test it tho, keep your fingers crossed!
Reply 3914 of 4961, by Thermalwrong
That's an excellent find and I hope it works 😀 I used to have one and it was a superb monitor that I really wish I'd not let go, but it did weigh a ton - it made my desk sag and sucked to drag to LAN parties.
Reply 3915 of 4961, by maestro
holdencars11 wrote on 2022-10-04, 12:36:
I think you're right, I seem to remember 11 or 12, I have the same heatsink. It's a beast, hopefully you can clean up that rust and use it. Funny, it looks like the previous owner applied TIM to the whole CPU package and not just the die, 🤣.
Reply 3916 of 4961, by holdencars11
Trash picked this Asus P5E and huge Zalman cooler "Optimised for nVidia nForce" whatever that means 🤣.
http://ixbtlabs.com/articles2/cpu/zalman9700nt.html
Looks like it will be a nice motherboard for Core2Quad! Incredible amount of heatsinks on Voltage section...
Reply 3917 of 4961, by Kahenraz
That's a great find! Dual PCI-e as well for SLI.
Reply 3918 of 4961, by ODwilly
I had that exact mobo with an "Alienware" bios. $15 ages ago with a dead top pcie slot. Got a Pentium 670 up to 4.3ghz with a similar HSF and it was a blast with a 512mb 8800gt.
Reply 3919 of 4961, by holdencars11
ODwilly wrote on 2022-10-24, 05:45:
It's alive! On first boot too which is always a bonus. It came with SupremeFX II sound breakout card which I assume is just HD Audio on a PCI 1x card
