Reply 4460 of 4612, by EvieSigma
smtkr wrote on 2023-11-09, 00:26:
"VCR doesn't work."
Challenge accepted.
In my experience, VCRs in TV/VCR combos are very fixable...if you can actually get the VCR mechanism detached from the rest of the unit to repair it.
Reply 4461 of 4612, by bjwil1991
I've done VCR repairs on a TV/VCR combo unit before. It's probably a bad belt for the load/eject mechanism and I have spare belts from the dead VCR from the Orion unit (the VCR stopped working one day and I was unable to get it going again after many attempts, but it served me well).
Reply 4462 of 4612, by Tiido
Caked up lubricants and sometimes dirty optic sensors are a problem aswell.
Reply 4463 of 4612, by bjwil1991
Well, I got the stuck tape out. And I have one small piece that slipped out from somewares, but I don't see where. Gotta get me a service manual to find out where the part goes and go from there. It also has purity/color issues that I need to fix, which could mean a lot of things from capacitors to potentiometers.
Reply 4464 of 4612, by Lutsoad
Are you tired of your boring old Aztech 2X CD-ROM but can't afford a new one? No problem, just spray-paint your drive to give it a much needed makeover!
Courtesy of my friend who gave me this Aztech CDA 268-031 2X drive. Surprisingly it can read a new Verbatim 700 MB CD-R written at 52X speed, it took 40 minutes to complete the test and the read speed never dropped below 1,97X or 290 KB/s.
    1.57 MiB
Reply 4465 of 4612, by twiz11
Lutsoad wrote on 2023-11-12, 17:56:
no cap i found a nice 52x cd burner in the trash and it worked and thats how i was able to backup files
RETIRED
This user is no longer active on VOGONS.
Reply 4466 of 4612, by DerBaum
had a similar problem recently.
I have scrubbed it with water, soap and steelwool and the corners very lightly with tweezers.
its not perfect but accaptable.
1.14 MiB
939.28 KiB
But be prepared to find a very yellow drive. I have 2 Aztech cd roms and they are yellow like cheese.
FCKGW-RHQQ2
Reply 4467 of 4612, by twiz11
DerBaum wrote on 2023-11-12, 18:29:
had a similar problem recently. I have scrubbed it with water, soap and steelwool and the corners very lightly with tweezers. […]
if you squint really hard them aztech cd roms/floppy drives look like the aztech temples if you put them on each other like a 3d temple pyramid
RETIRED
Reply 4468 of 4612, by dormcat
At the usual site of bulk trash drop-off, I noticed two plastic bags among some furniture. There were many CD and DVD inside; most were junks of B movies and CD-R, but I found something nice: XIII and the movie Spartacus, plus an empty multi-disc case that holds 12.
840.89 KiB
Judging from the price tag, this box was in a bargain bin after August 2016. I wonder how many people would buy an 2003 vintage game for NT$58 in or after 2016 and threw it away a few years later (us vintage gamers would never trash a box like this).
989.74 KiB
The MSRP was NT$269.
828.36 KiB
Both bags were taken away by an elder scavenger a few minutes later. 😅
Reply 4469 of 4612, by ediflorianUS
The yellow stuff you can make white (snow-white) with a UV lamp + watter&bleach/peroxid (let it sat for a few hours or overnight).
My 80486-S i66 Project
Reply 4470 of 4612, by Jasin Natael
Not technically a dumpster find but.....rescued this Dell Dimension XPS from going to the scrapper.
Has had the CPU upgraded with a PIII 850mhz at some point. Also has a Vortex 2 sound card and a Geforce 3 ti200.
Pretty good score.
Reply 4471 of 4612, by gerry
Jasin Natael wrote on 2023-11-15, 16:29:
Pretty good score.
it is indeed! looks ready to plug in and go, PCs like this in good shape are becoming rarer
Reply 4472 of 4612, by Jasin Natael
gerry wrote on 2023-11-15, 16:37:
Pretty good score.
Yep, it powered right up and booted into Win98 without issue.
I did rob the CPU for my other slot 1 build, replaced it with a PIII 700.
The Geforce 3 will likely go to another build as well, but my Voodoo 3, or Geforce 2 GTS will likely find a home in this one.
That black optical drive has got to go though.
Reply 4473 of 4612, by twiz11
Pretty good score.
freaking lucky what are you going to do with it?
RETIRED
Reply 4474 of 4612, by theamtrakvirus
Pretty good score.
Replace the few electrolytic caps on the motherboard around the cpu if you end up getting an issue with it not starting and displaying the CPU error code on the diagnostic LEDS. I nabbed one of these a few months ago myself but it didn't work at first and that was the issue. These old Dells are surprisingly well built and nice to work on.
Reply 4475 of 4612, by Repo Man11
Pretty good score.
Nice! I've a generic ATX case that looks very similar to that Dell case, I guess it was the style at the time.
Reply 4476 of 4612, by BitWrangler
Repo Man11 wrote on 2023-11-16, 01:03:
Pretty good score.
Perfect for burning mix CDs for the CD walkman in the back pocket of your JNCOs as was the style at the time.
Reply 4477 of 4612, by Jasin Natael
twiz11 wrote on 2023-11-16, 00:33:
Pretty good score.
Add it to the collection. Might end up being my dedicated VIA C3 machine, not sure yet.
Reply 4478 of 4612, by DerBaum
Some years ago i got a Fujitsu Server for free.
The place i got it from gave it to me without the HDDs and the caddys.
I just got some place holder caddys wich can not hold a hdd.
I bought a frame used online and it was way too expensive for my experiments.
So i asked the place i got the sever from if by any chance they still had the drives.
And yes they still had them because nobody took the time to destroy them for several years... But they cant give them to me because of data security...
I asked if i could just have the caddys without the drives... And they said yes. Awesome.
So i got 13 fitting frames for my system for free.
1.58 MiB
now i need a ton of drives 😁
11 caddys are for 300gb 10k sas drives and 2 caddys are for 146gb 15k sas drives.
The system also takes regular sata drives... so i have a wide range of drives to choose from.
Of course i want the drives that are labeled on the front of the caddys! 😁
FCKGW-RHQQ2
Reply 4479 of 4612, by smtkr
Jasin Natael wrote on 2023-11-15, 16:53:
Pretty good score.
mismatched colours are period correct though
