Reply 4480 of 4612, by eisapc
- Member
DerBaum wrote on 2023-11-18, 17:33:... now i need a ton of drives :D 11 caddys are for 300gb 10k sas drives and 2 caddys are for 146gb 15k sas drives. The system a […]
now i need a ton of drives 😁
The system also takes regular sata drives... so i have a wide range of drives to choose from.
Of course i want the drives that are labeled on the front of the caddys! 😁
These SAS-drives are hard to find and often costly.
Most of them were used in professional installations and so data security is often an issue.
Second point is these drives often have hundreds of working hours allready and tend to fail soon.
I successfully use SATA SSDs as replacement for the 2,5" SAS-drives in my Proliant server.
Faster, bigger, cheaper, more reliable, lower power draw.
