Sound Blaster LIVE! Versions
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Sound Blaster LIVE! Versions
Postby Anonymous Coward » 2015-5-13 @ 10:13
I seem to recall the first version of the SB Live! had some kind of design flaw related to it hogging the PCI bus and possibly causing problems with other PCI cards that do bus mastering (SCSI?). I stuck with an AWE64G, so I'm not intimate with this card. Does anyone know of the problems I am referring to? Were they able to get around them with a driver update?
If gold plated connectors is such a concern, why not just buy any card you want and solder them in?
Will the highways on the internets become more few?
User avatar
Anonymous Coward
Postby elianda » 2015-5-13 @ 10:30
Actually it is not that much of a problem. Probably all Emu10K do the requests to gain control on the PCI bus. It got a problem with the KT133 chipsets since VIA used another logic to do PCI arbitration. You can make this visible by plugging a SB Live! and a BT878 based TV-card. If you play e.g. midi music random green stripes will appear in the image transferred when watching some video from the TV-card.
On other chipsets which do PCI arbitration right this is not an issue. If you have cards that are prone to loose performance due to the PCI hogging then you can just set the PCI burst cycles in BIOS to 64. For those early VIA chipsets (KT133 to KT600) you may want to try George Breeses PCI latency patch.
For a while I had used 3x SB Live! on one KT600 board with kx drivers and had no issues.
As for the different SB Live! versions: A rather unnoticed difference is that cards with the same CTxxxx number can have different AC97 codecs. I have some with 1.0 and 2.0, which differ most noticably on supporting additional features, like 3D enhancement, inputs, gain a.s.o..
Youtube Channel
User avatar
elianda
Postby silikone » 2015-5-13 @ 19:01
What's this i hear about poor 44.1KHz audio compared to 48? Does this affect all Live cards?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
User avatar
silikone
Postby swaaye » 2015-5-13 @ 19:14
Live's DSP operates at 16-bit 48KHz. All source audio is resampled to this rate for mixing and other processing. This is how many cards work. Unfortunately EMU10K1's resampling algorithm isn't great and it causes some minor distortion in some cases. You can feed it specific synthetic audio signals that expose its weaknesses and it is audible, but this isn't very realistic. In typical listening I'm not sure it's perceptible. I have tried to listen for it, and experimented with software resampling but I can't hear it. The quality of the front output is more of an issue.
User avatar
swaaye
Moderator
Postby silikone » 2015-5-13 @ 22:49
So in order to avoid distortion, everything should be resampled to 48KHz in software? What happens in DirectSound3D games that use a multiple of 11KHz audio samples (every game ever?)?
User avatar
silikone
Postby alexanrs » 2015-5-13 @ 23:00
They'll get distorted, but you won't usually notice unless you try hard... And maybe not even then.
alexanrs
Postby silikone » 2015-5-14 @ 00:27
I'd give it a good old udial.wav, but that may only reveal clipping. Is there another test signal floating around designed for audio resampling?
User avatar
silikone
Postby swaaye » 2015-5-14 @ 00:59
Why not listen to some music with and without software resampling and see if you can hear anything. I was never able to.
Audigy has the same problem. Again without something like udial, I couldn't hear anything.
User avatar
swaaye
Moderator
Postby chrisNova777 » 2016-8-25 @ 17:23
any of you guys know about the hacked E-MU APS Drivers for SB LIve!?
im collecting info here :
http://www.oldschooldaw.com/forums/inde ... 63#msg3263
but i seem to have found teh downloadable files to hack/patch the drivers on a japanese site (linked on page)
User avatar
chrisNova777
Postby Enigma776 » 2018-2-18 @ 20:06
I have one of the original cards and mine has the gold plated ports, yet mine is a ct4620 which I thought didn't have the gold
No Tears Please. It's A Waste Of Good Suffering.
User avatar
Enigma776
Postby Stretch » 2018-2-18 @ 22:42
I have the SBLive SB0100 installed in my Asrock 775i65G mobo using VxD drivers. I had to disable the SB16 emulation from installing, in order to prevent a BSOD.
PC1: Win98SE - Via Apollo Pro Mobo - Pentium II 233 - 256 MB - Voodoo 3 1000 - Soundblaster 32
PC2: Win98SE - ASRock 775i65G R3.0 - Celeron 2.2 GHz - 2048 MB - Geforce FX5700 - Vortex 2 - SBLive SB0100 - YMF744
Stretch
Postby Gahhhrrrlic » 2018-3-07 @ 21:07
Seems like various members have had different versions of this card (myself included) but is there any unanimous agreement as to which cards are "pretty good" as opposed to "pretty bad" ? From the link posted earlier with all the model codes I would be inclined to think the 0060 and 0100 models are ok but that's just based on what those cards are titled. As we all know, there's no correlation between how fancy the name sounds and how well the card works. The video I watched on Phil's Computer Lab showcased the 0100 and he seemed to think that one was ok. Are there any better models? Since he had a 0060 for reference, why didn't he use that one if it's part of the Platinum series?
Gahhhrrrlic
Postby JSO » 2018-11-10 @ 10:19
I have a CT4620 with CT4660 daughter board but I cannot find the drivers for Windows 98SE. It's the gold plated version of 1998. Which .iso should I download for installing?
DOS IS THE POWER OF OUR CHILDHOOD MEMORIES!
User avatar
JSO
Postby janskjaer » 2019-2-13 @ 17:54
JSO wrote:I have a CT4620 with CT4660 daughter board but I cannot find the drivers for Windows 98SE. It's the gold plated version of 1998. Which .iso should I download for installing?
For the sake of closure, I should probably state that I ended up purchasing the CT4760.
For Windows 98SE, I used the Live!ware v3.0 drivers at vogonsdrivers: http://vogonsdrivers.com/getfile.php?fileid=780
Ensure you've uninstalled all other audio device drivers AND utilities.
Once installed, I had no audio from my Live! because the mixer utility from my onboard audio was still installed. This caused no audio output at all. Once uninstalled, the Live! worked fine.
Occasionally, I do see the odd VXD error /BSOD on this system and the only ever happens when the Live! is installed. Ah, like the good 'ol times! ;)
sblive_ct4760_02
sblive_ct4760_01
DELL Dimension XPS M200s
:Intel Pentium MMX 200MHz
:64MB RAM
:MS-DOS 6.22 / Win95b
:3D Blaster PCI (Rendition Verite 1000-E)
Chaintech Apogee 7VJL Apogee
:AMD Athlon XP 2800+
:3GB RAM
:Win98SE / Win2000 SP4
:Elephant Rendition Verite V2220 PCI
User avatar
janskjaer
Postby Intel486dx33 » 2019-2-13 @ 20:20
The "sound blaster live SB0200" is commonly found on eBay for little money.
Creative labs website had the DELL drivers for this sound card.
User avatar
Intel486dx33
Postby gdjacobs » 2019-2-13 @ 20:47
The SB0200 is a cut down, feature stripped version. The SB0220 is better as it has EAX support.
User avatar
gdjacobs
Postby Burrito78 » 2019-5-08 @ 16:29
Same exact problem here. I tried LiveWare, LiveWare 2.0, LiveWare 3.0 and current downloads from creative.com. Spend a whole day now troubleshooting this card but nothing. And it doesn't help if you don't know exactly what driver version is the best for Win98SE. So you are troubleshooting and switching driver versions which makes matters only worse...
User avatar
Burrito78
Previous
Return to Sound
Who is online
Users browsing this forum: PARUS and 1 guest
