Simmconn AWE64 Adapter
Reply 140 of 550, by appiah4
Hey dont get me wrong Im really grateful that you would take the time to do this Im just very enthusiastic. I would probably be in for one maybe two of them.
Reply 141 of 550, by firage
The cost matters, but if it's close to the SIMMConn solution and takes less space, I'm sure 30-40 would move in a second and more over time.
My big-red-switch 486
Reply 143 of 550, by kithylin
betamax80 wrote:
Hello I would be in the market for one of these, whether onboard memory or socketed. However I would need to make payment pretty soon.
Then you've got a long time to wait. No one has officially stepped up and said they'll create this or even mass produce it.
It's just "Theory crafted" or in the idea phase right now pretty much.
Reply 144 of 550, by dexvx
386_junkie wrote:
I will make a batch, either myself or as part of a team, but as a project it could take months. There does not seem to be many people interested so I imagine the batch would be fairly small... i.e. 10 to 20 pieces.
Although its hard to translate forum interest into actual money, I would imagine the interest to be more than just 20 pieces, unless the price was extremely high. I'd say go Kickstarter or something, where people have to put money where their mouth is.
Reply 145 of 550, by the Goat
I find myself late to the Simmconn party. I wish they would make more or somebody else would make a comparable unit for a reasonable price.
(Subscribing to this thread in the hope that it happens some day.)
Reply 147 of 550, by dreamblaster
Hi,
I logged into circuitmaker but could not find 'SIMMCONN_GOLD'
is it still there ?
Thanks for your support !
Reply 148 of 550, by cyclone3d
dreamblaster wrote:
Hi,
is it still there ?
Here is a direct link. Double checked that it was accessible without logging in.
https://circuitmaker.com/Projects/Details/Eth … -Queen/SimmConn
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 149 of 550, by dreamblaster
Hi
ok found the project now 😀
but could not find the circuitmaker files ?
-> is it only altium designer
Reply 150 of 550, by cyclone3d
dreamblaster wrote:
Hi ok found the project now :-) but could not find the circuitmaker files ? -> is it only altium designer […]
Hi
From the web page, you can only download the original and the Altium files.
To get to the Circuitmaker design, you must install Circuitmaker, run it, log in and open the project from within Circuitmaker.
https://workspace.circuitmaker.com/
There is a download button up on the top right hand of the screen to download and install Circuitmaker.
Once it is installed, run it, log in, and then search for simmconn. Open the project and then select "Open Design"
The project is set to Public Read so anybody should be able to open it.
YMF7x4 Guide
Reply 151 of 550, by dreamblaster
cyclone3d wrote:
... The project is set to Public Read so anybody should be able to open it.
Yeah it says 'modified and locked by someone else'.
I'll pm you.
Reply 152 of 550, by dreamblaster
a small step closer, generated gerbers, validated at eurocircuits
(not 100% sure it is all correct, do you see problems ?)
98.36 KiB
Reply 153 of 550, by kithylin
I'd have to dig out my old Athlon dos system and see but I thought the original design had some sort of "chip" between the two interfaces and the memory slot? am I wrong? I don't even know what the chip did, just thought it had something there.
EDIT: Yeah.. is on the other side of the PCB though. I knew it had something on it.
Reply 155 of 550, by dreamblaster
okay, going to make a few prototypes, at least 😀
Reply 156 of 550, by dreamblaster
will use 22 deg SIMM adapter instead of straight up.
there's some stock of PALCE16V8H7 here and there...
so will buy a suitable programmer for PALCE16V8H7 (https://www.kanda.com/products/wellon/VP-598.html)
Reply 157 of 550, by dreamblaster
Could someone send me some SIMM modules that should work ? http://simmconn.tripod.com/manual.htm
(pm me)
Reply 159 of 550, by the Goat
(pm me)
I'll check to see if I have any in the "old parts" bin. But I'm gone this weekend. So I wont be able to get back to you until next week.
